Old Aug 04, 2010, 06:38 AM
3D-Dabbler is offline
Find More Posts by 3D-Dabbler
Just "hanging" Around
3D-Dabbler's Avatar
Richmond, VA
Joined Oct 2009
Originally Posted by Hypersprint View Post
Some of guys are running 7985MG's all around
Toddsmodels.com has them for $78
Rob
For $79.95 you can have Hitec 7954's which are rated for 7.4 volts, have 400 oz/in of torque and are very fast. They can also be used in Giant Scale if the next model after the 70" is giant scale. Chief Aircraft has them. My previous post has the link.
3D-Dabbler is offline Find More Posts by 3D-Dabbler
Old Aug 04, 2010, 07:19 AM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
the 7955's are better than the 7954's IMHO, just because of the titanium gears. the 7955's will also take a 2s lipo direct with no bad side effects. that is from mike mayberry's posts, so i trust that is true!
rcbirk21 is offline Find More Posts by rcbirk21
Old Aug 04, 2010, 07:50 AM
3D-Dabbler's Avatar
Richmond, VA
Joined Oct 2009
Well in either case, the 7955's are only $10 more per servo than the 7985MGs and the 7954s. So, either one seems like a better deal than the 7985s.
Old Aug 04, 2010, 10:01 AM
rcbirk21 is offline
rcbirk21's Avatar
Joined Aug 2004
well, an advantage to the 7985's is that you do not need to use a seperate rx pack. i know some guys that use the internal bec, and i am just using an external bec. but if you are using either the 7955's or the 7954's it would probably be a good choice to use a seperate rx pack. which if you already have a pack to use and dont mind keeping a second battery charged it would be the way to go anyway just incase something happens to your esc you would still have servo control. but hey, thats why this hobby is so great, so many options!!!
Old Aug 04, 2010, 10:22 AM
akschu is offline
Find More Posts by akschu
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
I decided to go for the gusto and bought 7950's. I got a good deal on them from aero-model since I bought the entire package and got a package discount. I'm running a TP 1800mah prolite RX battery without a regulator. The most I've flown in one day is 4 times and it still had 65% left, so I'm not worried about it.
I spent more money on the servos, but the cost of the battery was cheaper than an external BEC that would do the job. Weight wise the battery is a little heavier.
I think this is the most reliable setup as long as you don't forget to charge the RX battery.
akschu is offline Find More Posts by akschu
Old Aug 04, 2010, 02:51 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Originally Posted by Husafreak View Post
My Motrofly 4325-380 is on it way to me, won't be long now....
you are gonna love it!!!!
Manta1 is offline Find More Posts by Manta1
Old Aug 04, 2010, 08:51 PM
Brill 1 is offline
Find More Posts by Brill 1
Artillery! King of Battle!
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
Slick Repair Process
I started repairing my Slick tonight after receiving the repair parts from 3DHS; Thanks Tyler!
Last night I removed formers 1, 2 & 3. They were pretty well trashed and seared-off almost flush with the battery tray.
I then installed former 3, the landing gear plate, former 2 and former 1. Then I cleaned-up the sheeting and repaired the stringers and finally installed the bottom plate with cowl pin.
I didn't make it the LHS to get the carbon tubing, so I won't finishing this evening. All that is left is installing the carbon tubing, re-enforcing the landing gear plate and installing the sheeting. Hopefully tomorrow!
Brian
Brill 1 is offline Find More Posts by Brill 1
Old Aug 04, 2010, 09:25 PM
RotorJockey is offline
Find More Posts by RotorJockey
Fly Low-Crash-Rebuild-Repeat !
RotorJockey's Avatar
Jackson, MO
Joined May 2009
Looks good man,
Nice work!
Fred
RotorJockey is offline Find More Posts by RotorJockey
Old Aug 04, 2010, 09:41 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
wow,clean fix man!!
Old Aug 04, 2010, 10:05 PM
Brill 1 is offline
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
Thanks! Yet another reason I'm a 3DHS Addict...they provide parts for you to repair your plane!
Old Aug 04, 2010, 10:13 PM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
Yep. We want our planes to be with you for a nice long time so you can get to be good friends with them.
blucor basher is offline Find More Posts by blucor basher
Old Aug 04, 2010, 11:04 PM
Lonelasso is offline
Find More Posts by Lonelasso
Lonelasso's Avatar
United States, TX, Austin
Joined Dec 2006
I sleep with mine
Lonelasso is offline Find More Posts by Lonelasso
Joined Jun 2003
T m i
Old Aug 04, 2010, 11:05 PM
Lonelasso's Avatar
Joined Dec 2006
T m i
lmao !
Old Aug 04, 2010, 11:20 PM
JClark is offline
Find More Posts by JClark
Check Your Bolts!!
JClark's Avatar
Grove, Ok
Joined Feb 2005
I tried to sleep with the 126 but the wife wouldn't share.
JClark is offline Find More Posts by JClark
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
