Old Aug 03, 2010, 03:05 PM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
Hmmm...if I were in charge of that repair, I would not remove anything. I'd trim up the breaks to make straight lines, cut the new formers to match with sharp scissors, and install with ply overlap patches made of the leftover wood.
blucor basher is offline Find More Posts by blucor basher
Old Aug 03, 2010, 03:08 PM
smelyal8r is offline
Find More Posts by smelyal8r
Guerilla Huck Power..activate!
smelyal8r's Avatar
Round Rock, TX
Joined May 2004
+1, my repair was similar to this and I didn't debond anything. A dremel tool helps alot here...just gotta be real careful!
smelyal8r is offline Find More Posts by smelyal8r
Old Aug 03, 2010, 03:15 PM
Brill 1 is offline
Find More Posts by Brill 1
Artillery! King of Battle!
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
Ahh! That is a great idea! I guess that why you're the boss! Glad I didn't start removing stuff already!
Off hand do you know the diameter of the carbon tube? I forgot to bring a piece with me and I want to run by the LHS tonight.
Thanks a million!
Brian
Brill 1 is offline Find More Posts by Brill 1
Old Aug 03, 2010, 03:30 PM
NumbSkull is offline
Find More Posts by NumbSkull
I used to be all thumbs...
NumbSkull's Avatar
United States, KS, Pittsburg
Joined Mar 2005
I don't remember what it was, but I got some from Ihncheol a few months ago. I'm pretty sure he had more.
NumbSkull is offline Find More Posts by NumbSkull
Old Aug 03, 2010, 03:35 PM
Brill 1 is offline
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
Yeah, I will bring a piece with me tomorrow. Tonight I need to take a REAL close look at the damage and see if cutting and doubling is going to work.
Should I remove the sheeting or just piece it together? Also is a scarf joint sufficient on the balsa stringers?
Brian
Old Aug 03, 2010, 04:02 PM
jfv61 is offline
Find More Posts by jfv61
Go guerrilla
jfv61's Avatar
Austin, TX
Joined Jul 2005
IMO, just piece sheeting together and use CF tube for the balsa stringer. My damage was less than yours but I didn't even fix the sheeting at all in some areas. I had a very hard landing on my repair the other day (broke the Xoar prop ) my repairs held solid.
JV
http://www.rcgroups.com/forums/showp...postcount=8354
jfv61 is offline Find More Posts by jfv61
Old Aug 03, 2010, 10:33 PM
jwilson32 is offline
Find More Posts by jwilson32
Loving Life!!!
jwilson32's Avatar
United States, MO, St Louis
Joined Jan 2010
I'm currently running Hitech 7955's all the way around in my slick and need 2 of them for another project. What digital Hitech servo's will work well in the ailerons? And if you know of a cheap place to buy them that would be a plus too!
jwilson32 is offline Find More Posts by jwilson32
Old Aug 03, 2010, 10:43 PM
Hypersprint is offline
Find More Posts by Hypersprint
Lets Make a Deal
Hypersprint's Avatar
Parrish, FL
Joined Apr 2008
Some of guys are running 7985MG's all around
Toddsmodels.com has them for $78
Rob
Hypersprint is offline Find More Posts by Hypersprint
Old Aug 03, 2010, 10:44 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
Rob
thats what im running and i love it. if you want a cheaper alternative the 985's are very popular!
rcbirk21 is offline Find More Posts by rcbirk21
Old Aug 03, 2010, 11:09 PM
Brill 1 is offline
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
Well after reviewing the damage to my Slick, I'm going ahead with replacement of the formers. I'm just not comfortable with a butt joint and a doubler route on the 2 formers that hold the landing gear plate.
I know this is going against Ben's recommendation and I will most likely regret do it...but I really want a solid landing gear area.
I'm going to think on it overnight before starting to apply Acetone.
Brian
Old Aug 03, 2010, 11:11 PM
Joined Jun 2003
mistake, IMO. they're not butt joints, they're double-lap joints. It's true that you can replace the entire thing, but that's only a last-resort for a totally crushed airplane.
Old Aug 03, 2010, 11:34 PM
Brill 1 is offline
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
OK, I will wait until I have the formers, they will be delivered tomorrow.
Should I place a ply doubler on both sides of the former? Is medium CA the glue to use or epoxy?
Thanks Ben for all you help and input. I usually make things harder than they need to be.
Brian
Old Aug 03, 2010, 11:43 PM
Joined Jun 2003
Both sides is fine...so is one. I'd use medium CA to do the repair, then go back with gorilla all around inside.
Husafreak is offline
Find More Posts by Husafreak
Husafreak's Avatar
United States, CA, Livermore
My Motrofly 4325-380 is on it way to me, won't be long now....
Husafreak is offline Find More Posts by Husafreak
Old Aug 04, 2010, 06:33 AM
3D-Dabbler is offline
Find More Posts by 3D-Dabbler
Just "hanging" Around
3D-Dabbler's Avatar
Richmond, VA
Joined Oct 2009
Here is the cheapest place that I have found 7955's.
Although I just got a bunch of 7954's from them as well. They have the same specs as the 7955's at 6 volts but on top of that they are rated for 7.4 volt operation, max out at 400 oz/in of torque and are $10 cheaper per servo.
3D-Dabbler is offline Find More Posts by 3D-Dabbler
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
