Old Aug 01, 2010, 09:16 PM
Artillery! King of Battle!
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
70" Maiden and Crash!
Finally got my 70" Slick in the air tonight! One click of aileron & elevator trim is the trimming that was required, it flew great! Maiden was pretty uneventful, but managed to get down kind of low and hover a little bit. I will post some video in the next 2-3 days...need to get it from the videographer!
Second Flight was was going great, getting down low; the Slick harriers great! Then I got a little over confident and stalled the Slick in a harrier, the wheel pants caught the grass and BAM! pulled the gear right out!
Damage is to formers 1-3, but the motor box is fine and the stringers are intact
Hopefully it is an easy fix!
Brian
Brill 1 is offline Find More Posts by Brill 1
Old Aug 01, 2010, 09:49 PM
I used to be all thumbs...
NumbSkull's Avatar
Pittsburg, KS
Joined Mar 2005
Brian, sorry to see this!!! You were starting to get comfortable, and getting wild with it.
Don't worry.. I've fixed mine from worse... You'll have it back in the air in no time!!
NumbSkull is offline Find More Posts by NumbSkull
Old Aug 01, 2010, 09:52 PM
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
Tyler is already working on the parts for me...love that 3DHS customer service!
After I peeled the covering back and could take a good look at the damage, I got kind of lucky, the stringers are intact! Now to buy the Acetone and start de-bonding!
Brian
Old Aug 01, 2010, 10:04 PM
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
ouch sorry belrix,Ivestalled mine in harrier before too,and wore your shoes...twice.
it will fly much better if there is such a thing when you gt her back together..
kudos to you for your great attitude over it
Manta1 is offline Find More Posts by Manta1
Latest blog entry: Lil repair work.
Old Aug 01, 2010, 10:09 PM
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
I really loved the way the Slick flew...for the short 10 minutes I got to fly it tonight! My 57" SC has to watch out...I might have a new favorite plane!
Old Aug 02, 2010, 01:30 AM
United States, CA, Northridge
Joined Apr 2004
Some great photos of my slick!!!!!
Love my Slick!
marcwv is offline Find More Posts by marcwv
Old Aug 03, 2010, 11:05 AM
Mis-guided heli guy
Jeff_edge540's Avatar
Austin, TX USA
Joined Mar 2007
Originally Posted by 3D-Dabbler View Post
I did my 10S experiment on the 70" Slick on today.
The setup is a Scorpion 4035-250 on 10S with a 19x10 Turnigy Light Electric prop.
The same setup on 8S weighs 9lbs 6oz.
The lightest 10S setup (2650 mah 30C) is 9lbs 4 oz.
10s 3000mah 30C is 9lbs 9oz
The heaviest was 10S 4000 mah 20C at 9lbs 14oz.
Frankly, I couldn't feel the weight difference at all between all of the setups. It has boatloads of power ~2300 watts... plenty of control in hovers etc.... hits 70 - 75 mph and it seems to pull as hard when my timer tells me it is time to land as when I took off.
Putting it on 10S puts the motor into its sweet spot. It is getting around 86% efficiency.
It is a keeper.
Where are you finding 5S 2650 packs?
Jeff_edge540 is offline Find More Posts by Jeff_edge540
Old Aug 03, 2010, 11:12 AM
Bigger is better
ibange's Avatar
Austin TX
Joined Jan 2001
It is a keeper.
I like that review... I might be going that route with my 72SC so its good to hear that it works out pretty well. I already use 5S 3000's on my 55" shp so batteries are already provided for. Makes it an easy switch.
ibange is offline Find More Posts by ibange
Old Aug 03, 2010, 11:33 AM
You're good!
Safety Hawk's Avatar
United States, VA, White Stone
Joined Jun 2005
Here's some.
http://www.hobbycity.com/hobbyking/s...0mAh_5S1P_40C_
Safety Hawk is offline Find More Posts by Safety Hawk
Old Aug 03, 2010, 01:14 PM
Just "hanging" Around
3D-Dabbler's Avatar
Richmond, VA
Joined Oct 2009
ZIPPY Flightmax 2650mAh 5S1P 40C
3D-Dabbler is offline Find More Posts by 3D-Dabbler
Old Aug 03, 2010, 01:19 PM
3D-Dabbler's Avatar
Richmond, VA
Joined Oct 2009
I like it enough that I am going to convert my second 70" Slick to 10S when I get enough money together to buy a second ICE HV 80.
I plan to play with other props too and see what happens. I plan to play with a APC-E 20x8 and a XOAR 20x10. I probably will not try an APC-E 20x10 because that pulls a lot more watts but I figure why not with the XOAR.
I ordered a Hacker A50-14L for my 72" Extra just for grins. I have a bunch of both 4S and 5S packs.
Old Aug 03, 2010, 02:24 PM
Bigger is better
ibange's Avatar
Austin TX
Joined Jan 2001
Oh... right. HV controllers. Well that does put a bit of a crimp in my style, forgot about that little requirement of 10S.
Old Aug 03, 2010, 02:38 PM
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
Originally Posted by The Reaper View Post
hey scooter
just thought adding two more cells is uneeded weight when you can fly on 6s just fine.
Scott
I'm flying (2) TP 3900 prolite 4S batteries that weigh 725g which is lighter than most people using 6s hobby city batteries. My current draw is much less and the performance is excellent. Also, these batteries work in other planes which is nice.
schu
akschu is offline Find More Posts by akschu
Old Aug 03, 2010, 02:42 PM
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
Brian,
Please post pictures of the repair as you go. I really want to see how you get it together since I've never really repaired anything that broke and I'm really curious about how you debond stuff.
schu
Old Aug 03, 2010, 02:53 PM
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
Originally Posted by akschu View Post
Brian,
schu
WILCO
I should start removing the motorbox and broken formers tonight. Just bought a quart of Acetone! Had to sign a statement saying I wouldn't make meth with it!
Brian
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
