Old Jul 29, 2010, 01:06 PM
Scooter0509 is offline
Find More Posts by Scooter0509
Scooter0509's Avatar
Long Island, NY
Joined Mar 2006
Belrix, That is pretty much where my batteries sit with the Motrolfly 4325, Ice 100 and BEC-PRO. Sounds like we have our compnents in very similar locations too.
http://www.rcgroups.com/forums/showp...postcount=5679
Note the motor in picture was changed before the maiden, Just didn't feel comfy with the collet.
Scott
Scooter0509 is offline Find More Posts by Scooter0509
Old Jul 29, 2010, 01:16 PM
Brill 1 is offline
Find More Posts by Brill 1
Artillery! King of Battle!
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
I like how you mounted the BEC Pro, I think I will change mine! I have mine mounted inside the fuse on a plate at the bottom, I was worried about it getting enough air flow to keep cool. You idea ROCKS!
Brian
Brill 1 is offline Find More Posts by Brill 1
Old Jul 29, 2010, 01:20 PM
Long Island, NY
Joined Mar 2006
Thanks Brian. I figured with that large hole in the bottom of the cowl, there should be plenty of air flow even in HA manouvers, just from prop air. It seems to be working fine and the temps are barely warm after a flight.
Scott
Old Jul 29, 2010, 03:15 PM
smelyal8r is offline
Find More Posts by smelyal8r
Guerilla Huck Power..activate!
smelyal8r's Avatar
Round Rock, TX
Joined May 2004
Here are some numbers on my 70" Slick setup
Reaper GR60XL V2
18x8 APCe
6s 4000 30c
95 amps
2300 watts
Temps after a 5 min flight were about 130F on both the motor and esc on a 90F+ day. Batts were 100F.
Power seems perfect!!
Brett
smelyal8r is offline Find More Posts by smelyal8r
Old Jul 29, 2010, 03:54 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
Reaper GR60XL V2
18x8 APCe
6s 4000 30c
95 amps
2300 watts
Brett
thats awesome! if you can believe it, im putting about that same setup (but with a 16 or 17x12 prop) in an osiris...can you say overpowered???
rcbirk21 is offline Find More Posts by rcbirk21
Old Jul 29, 2010, 03:57 PM
The Reaper is offline
Find More Posts by The Reaper
www.ReaperBrushless.com
The Reaper's Avatar
Joined Jul 2007
GR60xl v2
hey smely
glad you like the new motor sorry about the wait.
Scott
Reaper GR60XL V2
18x8 APCe
6s 4000 30c
95 amps
2300 watts
Brett
The Reaper is offline Find More Posts by The Reaper
Old Jul 29, 2010, 04:11 PM
rcbirk21 is offline
rcbirk21's Avatar
Joined Aug 2004
hey scott-
what are the v2's rated for? how many amps can we push them to? an apc18x8 seems like it is drawing an awful lot of current when the motor is supposed to take upto a 18x10
Old Jul 29, 2010, 04:22 PM
The Reaper's Avatar
Joined Jul 2007
under rated
hey rc
we have them under rated i will never give up what i pushed it too. woory more about flying less about the motor fly it under my specs and it will last a long time.
Scott
Originally Posted by rcbirk21 View Post
hey scott-
Old Jul 29, 2010, 05:05 PM
Long Island, NY
Joined Mar 2006
Any chance of an 8S version of this motor in the future?
Scott
Old Jul 29, 2010, 05:08 PM
The Reaper's Avatar
Joined Jul 2007
8s
hey scooter
sorry no this will be a 6s motor only i think 8s would be to heavy for this size planes.
Scott
Scott
Old Jul 29, 2010, 05:32 PM
goflyhighrc is offline
Find More Posts by goflyhighrc
Just go with the flow
goflyhighrc's Avatar
Joined Nov 2006
Landing Gear Plate --
Just wondering if most of the 3DHS junkies are adding Gorrila Glue to the landing gear plate to make it stonger. Working on my 2nd 70" Slick (1st Slick may you rest in peaces) I added GG glue to my first, but it made it difficult to repair when I tore my landing gear off in my first little mishap.
goflyhighrc is offline Find More Posts by goflyhighrc
Old Jul 29, 2010, 05:43 PM
Long Island, NY
Joined Mar 2006
I did on mine then I read about a few guys having gear pull outs on rough landings. BTW I am good at those. So I dug it out where the bolts come through and popped the t-nuts out and added 1"x1/16th" aluminum plates to the gear plate (3 of them) and drilled it out for 4 mm bolts and lock nuts. I have had several landings that were not so good and have not had an issue yet. Now I don't know that I would have had a problem if I didn't do the mod but I was waiting for batteries and I tend to over think things so I did it.
Scott
Old Jul 29, 2010, 05:49 PM
Long Island, NY
Joined Mar 2006
Originally Posted by The Reaper View Post
hey scooter
Scott
Do you mean the motor would be too heavy or the plane in general? I currently run an 8s setup, as do several others here, and it floats along nicely. I would be interested in seeing what a Reaper with something like 300kv would do.
Old Jul 29, 2010, 05:51 PM
Robert Youens is offline
Find More Posts by Robert Youens
Hovering my 85" Katana
Robert Youens's Avatar
Austin, Texas
Joined Mar 2006
My recommendation is to knock out the blind nuts and tap the plywood with a 10-24 tap. Then harden the threads with thin CA. Then use nylon bolts to hold on the gear. I did not put a nut on the bolt, just used the threaded plywood. You may want to use a nut, if it makes you feel more comfortable or if you feel the plywood in your plane is not capable of holding threads.
After ripping out the gear on my 70" Slick before I made the modification and having to do a major airframe repair. I was told by a friend that this was a good alternative. I have over 20 flights with this set up with no problem. Have not put the plane in a situation where the bolts should have sheered, Yet.
I have the same set-up on my 85" 3D Hobby Shop Katana and the nylons bolts sheered just as they were supposed to when I hit a curb. Saved a major frame repair, just had to patch a hole on each side of the wing where the wheel pants poked a hole in the bottom of the covering as the gear folded. Just put a patch over the hole and ironed in place, no big deal.
On the 70" it is still a good idea to use some epoxy or some medium CA to hit the spots in the landing gear box where the manufacture is way to skimpy on glue.
I agree that Gorilla Glue is way to messy for future repairs. With the nylon bolts you shouldn't have to rebuild a landing gear box.
Robert
Robert Youens is offline Find More Posts by Robert Youens
Old Jul 29, 2010, 05:53 PM
The Reaper's Avatar
Joined Jul 2007
weight
hey scooter
just thought adding two more cells is uneeded weight when you can fly on 6s just fine.
Scott
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
