Old Jul 27, 2010, 05:52 AM
starzen is offline
Find More Posts by starzen
starzen's Avatar
USA, FL, Stuart
Joined Jul 2009
Originally Posted by dubd View Post
I'm running a A50-12L with a 6S 5000 pack and 19x10E prop and it has great performance. Climbs with authority!
I agree with Steve, ditch the 26 gauge wiring, especially if you're using high torque servos.
hmmm have that setup sitting here NIB twice. One will go in the 72 Extra and for the other one i really need to order a 70 slick i think
starzen is offline Find More Posts by starzen
Old Jul 27, 2010, 05:54 AM
Nicoflyer is offline
Find More Posts by Nicoflyer
Pushing the envelope
Nicoflyer's Avatar
Valatie, N.Y.
Joined Jan 2006
Originally Posted by rcbirk21 View Post
what prop are you using? apc, xoar, something else?
I'm starting out with a Turigny elec. 18X10.Some claim to be the same as Xoar props.
Nicoflyer is offline Find More Posts by Nicoflyer
Old Jul 27, 2010, 07:38 AM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
they are most definitely not the same as xoar. they will give you somewhere around 150 watts less on this size setup. i started with a turnigy 19x10e prop and get 1500 watts on the a50-12l on 6s, and then used a xoar 20x10 and got 2000+ watts. i really think that 1 inch should not make a 500+ watt difference
rcbirk21 is offline Find More Posts by rcbirk21
Old Jul 27, 2010, 08:07 AM
starzen is offline
starzen's Avatar
USA, FL, Stuart
Joined Jul 2009
the watts alone of course dont say anything. without the thrust. would be interesting to see a well done comparison of different props
Old Jul 27, 2010, 08:27 AM
FlyingDreams is offline
Find More Posts by FlyingDreams
FlyingDreams's Avatar
Acton, MA
Joined Sep 2008
Motor timingnoise?
I just recently maidened my 70" at the NJ throwdown. The first few flights, I didn't notice any problems, but now I think I am having some motor timing noise. You can hear the noise in several spots on this video (most of it is out of focus as I gave the person some bad instructions on operating the camera).
Hacker/ICE timing noise (1 min 49 sec)
My setup:
Hacker A50-12L
CC ICE 100
CC BEC Pro
8s (2x 4s, 4000 Mah, FlightMax, 20c)
Xoar 18x8
At WOT I get just under 2700 watts at about 90A. A bit more than I need (or know what to do with). In the future I may go down to 6s, single battery setups.
I have the motor leads soldered to the ESC leads.
I have the USB link for the ICE and that is how I have been programming the ICE. I have fixed endpoints (JR9503), and I had to reverse the motor rotation.
All other settings were at the default settings (outrunner mode, medium motor timing) when the noise started. I have turned off logging, and tried low motor timing. I haven't tried changing PWM from outrunner (I had some trouble getting the Castlelink working at the field this weekend).
You can clearly hear something in the various clips. At 1:10 you can hear a little bleep as I start to apply power. The noise occurs mostly when I am going vertical or in a hover. It doesn't seem to occur when I am in a KE spin, but maybe the normal KE spin noises are masking things.
I hear two different types of noise. One is a static like noise and the other is a bit of squelching or beeping.
Any suggestions? I'll be out this weekend to experiment with PWM settings or whatever else you guys can suggest.
As far as motor temps (it was in the high 80's last weekend), I am measuring anything from 115 to 135 degrees depending on where I point the temp gun. The middle of the can always seems to measure 110 to 115 degrees, even though my fingers tell me it is hotter. The back end of the motor where it is black seems to measure 135 degrees F. Is there something about the color or the coating on the can that prevents accurate measurements? The ESC seems to come down very cool.
Other than the noise, the 70" flies extremely well for me. I've been know to break a few gears on my smaller planes, but even my landings looks pretty decent, as long as I stay out of the cornfields (Yes, I did that, but it is still flying).
John
FlyingDreams is offline Find More Posts by FlyingDreams
Old Jul 27, 2010, 08:25 PM
Husafreak is offline
Find More Posts by Husafreak
Husafreak's Avatar
United States, CA, Livermore
Is anyone using Xoar 20x8 props? I just bought a couple for this plane.
Husafreak is offline Find More Posts by Husafreak
Old Jul 27, 2010, 08:36 PM
Robert Youens is offline
Find More Posts by Robert Youens
Hovering my 85" Katana
Robert Youens's Avatar
Austin, Texas
Joined Mar 2006
Jumping 1 inch on the same pitch prop can make a significant difference in watts. 500 watts in not out of the question. I have tested a bunch of planes, checking watts and thrust. The natural jump if you want to take a smaller step is to go up one inch in diameter and drop pitch by 2 degrees. This will step up watts, but at a lesser amount than jumping diameter and keeping the same pitch.
The comment that thrust is the real difference is the real answer. There are so many variables it is hard to make too general a statement regarding the right power combination.
The Slick is particularly interesting compared to other planes because of its high volume fuselage. Generally it takes a large diameter prop when compared to airplanes of similar weight, to get working prop surface outside of the frontal area of the plane. The Slick also takes about 10% more watts to get similar thrust and considerable more to get similar speed of planes of similar weight.
Search my name in this thread and you will see the results of some of my testing on a number of 70" Slicks and other planes.
I usually fly a Xoar 20 x 8 on my Slick to accommodate my flying style. The Turnigy 19 x 10 is my alternative prop. If I could get a Turnigy 20 x 8 I would.
Hope that helps.
Robert
Robert Youens is offline Find More Posts by Robert Youens
Last edited by Robert Youens; Jul 28, 2010 at 09:35 AM. Reason: change Turnigy 20 x10 to Turnigy 20 x8 on "if I could get"
Old Jul 27, 2010, 08:40 PM
Austin, Texas
Joined Mar 2006
Yeah, the Xoar 20x8 is my favorite prop. I like to fly large diameter props on the Slick to get working prop surface outside the frontal area of the plane. I also like the large diameter to get more airflow over the ailerons.
In depends on the setup, but on my plane it really works well.
Robert
3D*Flyer is offline
Find More Posts by 3D*Flyer
3D*Flyer's Avatar
USA, CO, Longmont
Joined May 2010
Originally Posted by Safety Hawk View Post
This is how I do mine. Works great.
I was thinking about doing this with the 65" Vyper - fly it on two 4000mha 4S 25c packs vs a 6S 5000mha pack. What kind of flight times do you get on the Slick with the 2 packs? I'm going to run a Rimfire 1.20 and an ICE100...
3D*Flyer is offline Find More Posts by 3D*Flyer
Old Jul 27, 2010, 08:42 PM
jfv61 is offline
Find More Posts by jfv61
Go guerrilla
jfv61's Avatar
Austin, TX
Joined Jul 2005
Originally Posted by Robert Youens View Post
Yeah, the Xoar 20x8 is my favorite prop...
Xoar 20x8 has been a fav for me also. Can't justify the Xoar cost, the Turnigy props have been great for me. I do wish they had a 20x10...
jfv61 is offline Find More Posts by jfv61
Old Jul 27, 2010, 08:57 PM
Safety Hawk is offline
Find More Posts by Safety Hawk
Here We Go!
Safety Hawk's Avatar
United States, VA, White Stone
Joined Jun 2005
I'm running a Scorpion 4025-16/ICE 100 on a Xoar 18x8, and I have my timer set for 8 minutes. I put between 1900-2200mah back in when charging. So I could probably do 10 minutes if I wanted to.
Safety Hawk is offline Find More Posts by Safety Hawk
Old Jul 27, 2010, 10:28 PM
rcbirk21 is offline
rcbirk21's Avatar
Joined Aug 2004
i only paid $25 for my xoar 20x10e, thats really not htat much considering how much $$$ is in the plane. especially when the turnigy is about $8, so its only $17
Old Jul 27, 2010, 10:29 PM
3D*Flyer is offline
3D*Flyer's Avatar
USA, CO, Longmont
Joined May 2010
I'm also doing a 18x8 Xoar - that is really good flight times! Maybe I should cancel my 6S 5000mha pack order (that is on backorder). Do you like flying with the two packs better than the one 6S? have you tried both?
The two packs are probably a little heaver?
Old Jul 28, 2010, 07:14 AM
RC4x4 is offline
Find More Posts by RC4x4
Fly Low or you'll never know!
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Mike. The Rimfire only handles up to 6s. Alot of guys are doing 2 x 4s packs to make 8s. You would need to do a Scorpion or Hacker motor. You probably have 4s packs from the 330SC? The Vyper doesn't need 8s though.
I'm gonna be trying a 4035/380 Scorpion on 6s with a 19x8 xoar as soon as my buddy drops off the motor. Should test it this weekend.
Cory
RC4x4 is offline Find More Posts by RC4x4
Old Jul 28, 2010, 08:31 AM
Here We Go!
Joined Jun 2005
I've never flown it on a 6S 5000 pack, so I guess I don't know what I'm missing. But the extra weight of running two 4s 4000 packs hasn't had any negative effects that I can tell. It flies very light and will just float around in a harrier. This plane handles the weight very well.....just ask the guys running the DLE 30. Those are push 10 pounds or more, and mine is only 9lbs 4oz. However, you're talking about a Vyper, which is a smaller plane.
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
