Old Jul 22, 2010, 08:32 AM
Scooter0509 is offline
Find More Posts by Scooter0509
Scooter0509's Avatar
Long Island, NY
Joined Mar 2006
Thanks Rob, after the right wing was done I kinda got a better feel for applying them and had very few bubbles on the rest. Honestly there really isn't that many bubbles in the right wing but I am very picky. Really not hard to install at all. You did a great job on the decals. Thanks again.
Scott
Scooter0509 is offline Find More Posts by Scooter0509
Old Jul 22, 2010, 09:57 AM
weaser42 is offline
Find More Posts by weaser42
House of Paine
weaser42's Avatar
United States, AZ, Gilbert
Joined May 2007
Sweet, love the yellow/black checkerboard as well os going cowless
weaser42 is offline Find More Posts by weaser42
Old Jul 22, 2010, 11:07 AM
mattk0 is offline
Find More Posts by mattk0
mattk0's Avatar
United States, MN, Apple Valley
Joined Jan 2004
Sweet - liking the yellow/black checkers. I'm still debating going the vinyl route someday on this plane but so far still liking the 'plain' look too
Got 3 flights on my 70" Slick and 3 on my 57" Extra SC. Man, these make for an awesome combo. I'm really liking all the awesome characteristics of the Slick and it made for a perfect larger plane for me coming from 47" size. Now, I totally understand the "bigger flies better!"
Got home almost giddy last night because of how awesome those two planes are.
mattk0 is offline Find More Posts by mattk0
Old Jul 22, 2010, 12:35 PM
Long Island, NY
Joined Mar 2006
Thanks guys, since my SHP and my AJ Extra were yellow I realized that bright yellow just looks great in the air. I like the fantasy blue scheme but just wanted to add a bit to the yellow. Rob was great to deal with and very accomodating to my wants. Great service.
Scott
Old Jul 22, 2010, 04:07 PM
Brill 1 is offline
Find More Posts by Brill 1
Artillery! King of Battle!
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
Spinner Gap Too Larger
I was test mounting my Hacker A50-14L on the Slick today and noticed that I have a rather large gap between the spinner backplate and the cowl. I'm using a Tru-Turn spinner and wonder if that has something to do with it?
Thoughts? Did I over-looking something very obvious while mounting the motor?
Brian
Brill 1 is offline Find More Posts by Brill 1
Old Jul 22, 2010, 04:55 PM
akschu is offline
Find More Posts by akschu
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
Brian,
Pull the blind nuts, put them on the front side of the motor box, then mount the X mount on the back side. You will need longer screws between the motor and X mount but I was able to get those at the local hardware store.
Schu
akschu is offline Find More Posts by akschu
Old Jul 22, 2010, 05:05 PM
Brill 1 is offline
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
Originally Posted by akschu View Post
Brian,
Schu
Ahhh! Great idea! That should make it line up perfect!
Brian
Old Jul 22, 2010, 06:26 PM
3D-Dabbler is offline
Find More Posts by 3D-Dabbler
Just "hanging" Around
3D-Dabbler's Avatar
Richmond, VA
Joined Oct 2009
Brian
It seems you have a 1.0 version of the 70" slick. The 2.0 batch has the motor box about 13 mm shorter to accommodate the A50-12L and a50-14L. I have both versions.
3D-Dabbler is offline Find More Posts by 3D-Dabbler
Old Jul 22, 2010, 06:36 PM
Brill 1 is offline
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
Hmm, just ordered it a couple of weeks ago, must have been a version 1.0 hanging around.
No worries, I will move the blind nuts and x-mount. Besides I'm still waiting on my batteries to arrive.
Brian
On another topic. What settings do I need to change on the Castle ICE 100 for the Hacker A50-14L with a Castle BEC Pro?
BW
Old Jul 22, 2010, 06:41 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Brian
BW
No settings to change using a BEC, but you must pull the red wire out of the plug from the ESC to the receiver. If you don't know how to do that, just carefully lift up on the plastic tab that holds the brass contact in the plug, and gently pull it out. Fold it back and put some tape over it, or as I do, I pull all of them, fold the wire back and put some heat shrink over it, and then put the other wires back.
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jul 22, 2010, 06:48 PM
Brill 1 is offline
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
Thanks!
Old Jul 22, 2010, 06:57 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Thanks!
No problema....
One note is that a lot of people will pull the wire out on a servo extension, rather than the actuall ESC plug, as that way you are still able to program your ESC with-out having to re-insert the wire.
SteveT
Old Jul 22, 2010, 07:25 PM
3D-Dabbler's Avatar
Richmond, VA
Joined Oct 2009
I use the servo extension technique as my sacrificial connector.
Old Jul 22, 2010, 08:08 PM
Brill 1 is offline
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
Yup, the servo extension was a great idea. I have the Castle BEC Pro programmed to 6.0 volts. Should I change from auto-calibrate throttle to fixed endpoint? Also should I change the cutoff from hard to soft and volt from 3.0 to something lower?
Old Jul 22, 2010, 08:12 PM
RotorJockey is offline
Find More Posts by RotorJockey
Fly Low-Crash-Rebuild-Repeat !
RotorJockey's Avatar
Jackson, MO
Joined May 2009
Soft cutoff and instead of auto-lipo at 3.0 volts per cell, I set mine at the lowest allowable voltage. (which I believe is 4 volts)
I do that because I'd rather ruin a battery than lose my plane to an LVC.
Fred
RotorJockey is offline Find More Posts by RotorJockey
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
