Old May 17, 2010, 12:09 PM
500melon is offline
Find More Posts by 500melon
Clearwater, Florida
Joined Apr 2004
Yep, sure was a great price and great service. Got thorugh on the phone
and Ben is sending one out!!!!! I may just get to maiden this thing this weekend. By the way this is my second 70"Slick. The first one was electric
and was totaly destroyed except servos. I was coming in for a landing
on base leg and lost all control. My bet was the bec quit working on the ICE 100 I was using but I'll never Know.
Thanks for all the help guys and i will try not to be a stranger
James
500melon is offline Find More Posts by 500melon
Old May 17, 2010, 01:03 PM
3D-Dabbler is offline
Find More Posts by 3D-Dabbler
Just "hanging" Around
3D-Dabbler's Avatar
Richmond, VA
Joined Oct 2009
I think the same thing happened to me. My best interpretation of the ICE 100 data log is that it rebooted while I was in a harrier pass.
My servos were intermittently getting noisy even though I can't seem to find any binding. So, I suspect that I may have exceeded the BEC current limit momentary and it rebooted.
That is why I lost control and it was completely unresponsive while it was rebooting and then I got some limited control back just before impact which saved the plane frankly. It was going in completely vertical.
3D-Dabbler is offline Find More Posts by 3D-Dabbler
Old May 17, 2010, 01:26 PM
500melon is offline
Clearwater, Florida
Joined Apr 2004
Mine also ended up going in vertical(nose first) I was flying 72mhz
when it happened but no glitches at all just no response.
If i were to do it in electric again, I would use an rx pack because I
also had an incident with a 47" Edge where the battery (zippy 3s2200)
had a cold solder joint from the tab to the circuit board come loose
and it also went in nose first. Oh well out with the old in with the new!!
James
Old May 17, 2010, 01:42 PM
G.P. is offline
Find More Posts by G.P.
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
James
That could happen with the Rx pack too.
I'm running a 2s lipo with a castle BEC to power my servos and Rx, and I can't believe how little power a flight is using. Four 5-6 minute flights is only around 200 mah!
G.P. is offline Find More Posts by G.P.
Old May 17, 2010, 01:45 PM
500melon is offline
Clearwater, Florida
Joined Apr 2004
Very true, I guess no matter what way your setup you can always have a failure.
James
Old May 17, 2010, 05:08 PM
xsubsailor is offline
Find More Posts by xsubsailor
Pants on the ground
xsubsailor's Avatar
exit 26 Jersey
Joined Jul 2007
I've been using a gp lifesource rx pack for $26.00 it's a life battery no need for a regulator lower voltage than a 2s lipo very happy so far
xsubsailor is offline Find More Posts by xsubsailor
Old May 17, 2010, 08:05 PM
jwilson32 is offline
Find More Posts by jwilson32
Loving Life!!!
jwilson32's Avatar
United States, MO, St Louis
Joined Jan 2010
Link?
jwilson32 is offline Find More Posts by jwilson32
Old May 17, 2010, 09:18 PM
Pants on the ground
xsubsailor's Avatar
exit 26 Jersey
Joined Jul 2007
They are made by great planes and sold at tower hobbies lifesource rx batts 2s 1100 mah is what I use
http://www3.towerhobbies.com/cgi-bin...&I=LXYAS7&P=ML
Old May 17, 2010, 09:21 PM
HugoCraft is offline
Find More Posts by HugoCraft
Aerobatic Fanatic
HugoCraft's Avatar
United States, KY, Louisville
Joined Sep 2007
Here:
http://www3.towerhobbies.com/cgi-bin...93p?&C=MCD&P=7
I'm using the 2100mah one but I burned up two throttle servos. First the HS-5245MG digital so then switched to the analog version which is the HS-225MG. Alot of people have had good luck with that one but I burned that one up too. Both just stopped working so I went overkill and got the HS-7940TH since I know it can take the extra .5v since the life battery is about 6.5v charged. Also it has "(8) O-Rings for Water/Dust/Fuel protection" and I have the servo directly behind the carb like most people which does spit fuel sometimes.
But I love flying gas and have no regrets other than my electrics sometimes never make it out of the truck at the field now....sometimes.....
HugoCraft is offline Find More Posts by HugoCraft
Old May 17, 2010, 10:01 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
http://www.hobbico.com/radioaccys/hcam6415.html
these are what I have in my 70 slick and 65 vyper.1000mah.I fly prolly 6 flights then charge,never used half of a pack between charges yet.I get mine from Hodges Hobbies.
Manta1 is offline Find More Posts by Manta1
Old May 18, 2010, 01:56 AM
sk8rob is offline
Find More Posts by sk8rob
3D Wanna Be
sk8rob's Avatar
Oahu, Hawaii
Joined Jul 2009
Got 4 packs through my 70" today....I love this plane. It's so gentle and easy to fly. Everything happens in slow motion.
Anyway, I'm having a problem with my prop nut...it keeps coming loose. I have the A50-16L hacker motor, elite spinner, and 20x10 Xoar prop. There are no grooves on the spinner backplate, so the prop slides when I try to tighten it. Also, the motor turns while trying to tighten it. Any suggestions?
sk8rob is offline Find More Posts by sk8rob
Old May 18, 2010, 02:13 AM
brucewsb is offline
Find More Posts by brucewsb
brucewsb's Avatar
Santa Barbara
Joined Apr 2008
I cut a section of heat shrink then split it length wise and cut it to a circle about the size of a quarter (or diameter of prop adapter washer). Cut a hole in the middle and placed it between the adapter and backplate of the spinner and as it tightens down it builds up enough friction to lock it down. Works great since its difficult to hold the can of the motor through the vent holes while tightening.
brucewsb is offline Find More Posts by brucewsb
Old May 18, 2010, 07:38 AM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
I saw a post once where a guy cut a small disc of sandpaper and glued it to the front of the spinner backplate, and then you could use another on the aluminum washer that goes on the front of the prop. That should stop the turning problems.
Maybe clean the threads of the nut and prop shaft with alcohol and use a drop of blue loctite on it. That should keep it from loosening up.
ryan_m is offline Find More Posts by ryan_m
Old May 18, 2010, 10:12 AM
Scooter0509 is offline
Find More Posts by Scooter0509
Scooter0509's Avatar
Long Island, NY
Joined Mar 2006
I posted this on Sunday night so in case you missed it here is a link. This was the testing for the Motrolfly 4325-340kv on 8S with an APC18x8. I think the numbers were good but I would like some opinions from people with more knowledge on the subject.
thanks,
Scott
http://www.rcgroups.com/forums/showp...postcount=7557
Scooter0509 is offline Find More Posts by Scooter0509
Old May 18, 2010, 10:33 AM
bajajrider is offline
Find More Posts by bajajrider
Team $CRILLA_VILLA
bajajrider's Avatar
sacramento, california
Joined Oct 2006
yep, works great! get that self adhesive sandpaper from the hobby shop,its for the T style sanding bars. i use it on all my motors now.
bajajrider is offline Find More Posts by bajajrider
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
