Old May 16, 2010, 09:00 PM
ekotil is offline
Find More Posts by ekotil
ekotil's Avatar
Athens, Texas, United States
Joined Jul 2004
Nice job Robert. I enjoyed your most informative thread. I too am running a total Turnigy equipped 70'' Slick although mine is all of 10 pounds with a 5000mah 6 cell. Plane is awesome and flies much like my 87'' Extra that had all the expensive stuff on it!
ekotil is offline Find More Posts by ekotil
Old May 16, 2010, 09:42 PM
Lonelasso is offline
Find More Posts by Lonelasso
Lonelasso's Avatar
United States, TX, Austin
Joined Dec 2006
22 Special
Thought y'all would get a kick outta some 'real redneck' engineering I did on Eddi's Slick The rim acts as a stop on the interior wall. Just CA and kick it off. Oh, had to hand drill at a bit of an angel to fit the brass.
Lonelasso is offline Find More Posts by Lonelasso
Old May 16, 2010, 10:57 PM
CFisher1421 is offline
Find More Posts by CFisher1421
CFisher1421's Avatar
Geneva, IL
Joined Jul 2007
That's just beggin' for the lead to be put back in. Love it!
CFisher1421 is offline Find More Posts by CFisher1421
Old May 16, 2010, 11:10 PM
Lonelasso's Avatar
Joined Dec 2006
lmfao ! Got the idea from the redneck fuse story (which has been 'debunked' )
Old May 17, 2010, 12:08 AM
BoneDoc is offline
Find More Posts by BoneDoc
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Congrats on your Slick fellas!
3DD, post some pics of the belly, and we'll be more than happy to guide you through the repair process. It's really not that hard once you've done this a couple of times.
BoneDoc is offline Find More Posts by BoneDoc
Old May 17, 2010, 12:44 AM
JEFFRO503 is offline
Find More Posts by JEFFRO503
www.rcdude.com
JEFFRO503's Avatar
Joined May 2006
Originally Posted by Manta1 View Post
Well,yes and no.lol I bonedoc'd it.Had my best flight with it ever,prolly best flight ever,period.Few things clicked until I doinked it.Stalled her in a harrier turn.Knocked the LG off,got the holes in the wing covering,battery tray joints knocked loose.I Pretty much got all the wood shored back up this afternoon.Have epoxy drying overnight,then I will redrill the holes a little bigger and use some bigger blind nuts and bolts.Should fly again tomorrow if all goes well.Gotta round up a little white covering tho.
Well , that's good to hear you can get her all fixed up again and flying. I have started flying my 89" Slick again a couple weeks ago after my bad wreck i had in October...WOOHOO!! Damn , I love that bird. I have everything i need for this little 70" Slick now , i just have to find the time to start putting it together , but it sounds like it's going to be a fun little plane to fly.
JEFFRO503 is offline Find More Posts by JEFFRO503
Old May 17, 2010, 05:57 AM
500melon is offline
Find More Posts by 500melon
Clearwater, Florida
Joined Apr 2004
Hey guys, This is my first post and I need a little help setting up
a power system for a DLE 30. I seem to be a bit confused about switches,
batteries and a kill switch. I was thinking about running a 2300mah a123
battery and the Wike battery eliminator for the ignition to keep it simple but
I am not sure what kind of switch I should use. Does it need to have two
outputs to the reciever for amp draw? I keep reading that the Jr style connector can only handle 3 amps is the reason for that question.Also what size fuel line 3/32 or 1/8? I will probrably have more ?s
Thanks for any help, James
My setup so far
70" Slick
DLE 30
4x 985mg
1x 225mg
Hitec Aurora 9
optima 9 reciever
500melon is offline Find More Posts by 500melon
Old May 17, 2010, 06:51 AM
skippy78 is offline
Find More Posts by skippy78
skippy78's Avatar
USA, VA, Narrows
Joined Mar 2009
Any heavy duty switch will work you can make a Y to have two plugs into the rx.
skippy78 is offline Find More Posts by skippy78
Old May 17, 2010, 07:04 AM
3D-Dabbler is offline
Find More Posts by 3D-Dabbler
Just "hanging" Around
3D-Dabbler's Avatar
Richmond, VA
Joined Oct 2009
Thanks for the advice. I am going on a business trip today. Will be back tomorrow night or Wednesday. So, I will post some pictures then.
I was thinking about ways to trace the bulk head pattern on cardboard and then transferring it plywood. One tough part will be figuring out how to cut it all out without wrecking it. Those bulk heads have SOOOO much wood removed.
-Mike
3D-Dabbler is offline Find More Posts by 3D-Dabbler
Old May 17, 2010, 07:39 AM
500melon is offline
Clearwater, Florida
Joined Apr 2004
Thanks Skippy!!
Old May 17, 2010, 10:09 AM
GoldCraft is offline
Find More Posts by GoldCraft
GoldCraft's Avatar
United States, GA, Woodstock
Joined Jan 2007
My setup so far
70" Slick
DLE 30
4x 985mg
1x 225mg
Hitec Aurora 9
optima 9 reciever
I just run the one lead off the switch(heavy duty) to the rx battery port...the otherside goes to the battery of coarse. My Wike BE plugs into the gear port.
I used the 3/32 nygon fuel line.
GoldCraft is offline Find More Posts by GoldCraft
Old May 17, 2010, 11:03 AM
500melon is offline
Clearwater, Florida
Joined Apr 2004
Thanks Goldcraft!!! Do you know where I can source the a123 batteries from
that might have them in stock. I found a place that has it but no balance
connector installed.
James
Old May 17, 2010, 11:06 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
My setup so far
70" Slick
DLE 30
4x 985mg
1x 225mg
Hitec Aurora 9
optima 9 reciever
congrats on a fine first post and your slick
Manta1 is offline Find More Posts by Manta1
Old May 17, 2010, 11:07 AM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
guys - We have the power system bundles in stock with:
2S 2600mah 42% products pack w/ deans and balance
HD switch with Deans's
Deans-to-2 plug receiver connector
Zuess IBEF ignition power
...for $89
blucor basher is offline Find More Posts by blucor basher
Old May 17, 2010, 11:59 AM
GoldCraft's Avatar
Joined Jan 2007
...for $89
Great price for the combo!
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
