Old Sep 02, 2009, 09:19 AM
blucor basher is online now
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
On my 100CC sized electrics, I have to use a 24" extension from Rx to ESC. No issues so far.
blucor basher is online now Find More Posts by blucor basher
Old Sep 02, 2009, 11:29 AM
Threshold is offline
Find More Posts by Threshold
Threshold's Avatar
London UK
Joined Jul 2004
Originally Posted by ronrandle
Threshold, where do you get them from?
From a fishing shop, for course fish, ie carp etc they also have the best closed loop wire especially for smaller planes. Very fine and bendy so the rudder centers better.
Threshold is offline Find More Posts by Threshold
Old Sep 04, 2009, 04:14 PM
brucewsb is offline
Find More Posts by brucewsb
brucewsb's Avatar
Santa Barbara
Joined Apr 2008
What are going to be the recommended angles on the different control surfaces for high and low rates?
brucewsb is offline Find More Posts by brucewsb
Old Sep 04, 2009, 04:34 PM
Joined Jun 2003
Very similar to 51" Slick throws.
Old Sep 04, 2009, 05:03 PM
brucewsb is offline
brucewsb's Avatar
Santa Barbara
Joined Apr 2008
Thanks.
Went and grabbed them from the Slick 51" manual.
Ailerons: Low 15 degrees High 30 degrees
Elevator: Low 15 degrees High 45-50 degrees
Rudder: Low 30 degrees High As much as possible.
Use Exponential on all controls. We recommend starting with 25% on low rates and 70% on high rates. Adjust as needed to obtain the control feel you want.
Old Sep 04, 2009, 05:26 PM
Joined Jun 2003
Yep. I'm 15/35 on ailerons, as you can see on my video, 35 is just a wee bit much for me on high rate ailerons.
Old Sep 05, 2009, 10:58 PM
jadamian75 is offline
Find More Posts by jadamian75
jadamian75's Avatar
Fort Collins Colorado USA
Joined Oct 2007
I'm programming my Scorpion 120 Amp controller for the Slick to be used with 6s lipo 5000mah. What are the suggestions for:
1.Low Voltage Cutoff. I don't care about the batteries as much as the plane. I would like to still have enough power for my servos. (using a CCBEC off the main battery)
What should I set the voltage to for LVC. I can choose 5 volts to 23 volts in 0.5 volt increments. I have it currently set to 18.0 volts. That should be low enough to not hit LVC in a low hover. Is something else suggested?
2.What should I set my program cutoff type to? my options are:
A. Cut 50% maximum power.(Factory Setting)
B. No Cut (Just LED Warning)
C. Pulse Warning
3.Motor Start Booster (Not sure what this is Maybe how fast the power goes to the motor?)
A.Soft (factory setting)
B. Medium
C.Strong
4.Motor Acceleration Timing
A.0.15 seconds
B.0.3 Seconds (Factory Setting)
C.0.45 Seconds
Thanks For the info
Joe
jadamian75 is offline Find More Posts by jadamian75
Old Sep 05, 2009, 11:12 PM
Fig Jam is offline
Find More Posts by Fig Jam
I am UNIQUE!
Fig Jam's Avatar
Kentucky
Joined Feb 2008
What Motor will you be using Joe?
Fig Jam is offline Find More Posts by Fig Jam
Old Sep 05, 2009, 11:18 PM
jadamian75's Avatar
Joined Oct 2007
Reaper 60XL
Old Sep 05, 2009, 11:32 PM
Fig Jam is offline
I am UNIQUE!
Fig Jam's Avatar
Kentucky
Joined Feb 2008
Joe,
LVC of 16~17 Volts will effectively disable the LVC on 6s, that's what I'd use. I've highlighted my choices in RED. I program the cut off to just flash the LED, that way it never going to cut on me even if I forget to set my timer.
C. Pulse Warning
3.Motor Start Booster (This setting helps to get high pole count motors to start up i.e. reduces screeching)
B. Medium
C.Strong
A.0.15 seconds
C.0.45 Seconds
Old Sep 06, 2009, 01:21 AM
jadamian75's Avatar
Joined Oct 2007
Do you mount your LED so it can be seen from outside?
If there is no cut off is it possible that the lipo can get so drained that the power to the servos get eliminated? I had that happen once on a receiver 123 battery and would like to avoid that ever happening again.
Joe
Old Sep 06, 2009, 01:49 AM
brucewsb is offline
brucewsb's Avatar
Santa Barbara
Joined Apr 2008
I experimented with the settings on mine but haven't flown it yet (except a test flight on the helicopter).
What I did set it to was:
1. 15V LVC - I had it at 19V on an old FP battery in my Logo500 and it triggered LVC so decided to go lower since I would rather it not trigger.
2. Went with the pulse warning like on my Align ESC in my Edge540 and Trex450 but might set it to No Cut. Thought about mounting the LED up in the cockpit. I like pulse warnings on the T450 because it makes the tail twitch, which is easy to see. Usually never go into LVC except when a battery is going bad - fly by timer only.
3. Left starter boost at default but might try others. At first I thought this was only for the helicopter modes.
4. 0.15 seconds. Liked the faster response.
Old Sep 06, 2009, 09:42 AM
Fig Jam is offline
I am UNIQUE!
Fig Jam's Avatar
Kentucky
Joined Feb 2008
Joe
I leave the LED inside the fuselage and place it so that I can see it through the canopy. ALWAYS fly with a timed flight, if you land when the timer goes for you never need to worry about the LVC, the BEC will provide power to the Rx and servo's down to 7 Volts so running out of power should not be a problem .
Old Sep 06, 2009, 10:42 AM
BoneDoc is offline
Find More Posts by BoneDoc
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Yep, mike is right. Since we're running 6S, the plane will quit flying loooong before you ever loose power to the servos.
BoneDoc is offline Find More Posts by BoneDoc
Old Sep 06, 2009, 11:06 AM
jadamian75's Avatar
Joined Oct 2007
Thanks for the info. I think I'm going to like the programming remote control on the Scorpion. I set them as you recommended Mike.
Joe
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
