Old Feb 25, 2010, 01:35 PM
CooHead is offline
Find More Posts by CooHead
Don't watch this...
CooHead's Avatar
Northern IL
Joined Oct 2003
Originally Posted by CFisher1421 View Post
Illeism! Illeism!!!
CooHead is offline Find More Posts by CooHead
Old Feb 25, 2010, 01:37 PM
Safety Hawk is offline
Find More Posts by Safety Hawk
Here We Go!
Safety Hawk's Avatar
United States, VA, White Stone
Joined Jun 2005
Originally Posted by sk8rob View Post
I believe in the insurance when things are questionable, but not when it's unecessary. Has anybody ever had a problem with the ICE100?
For $30 more, I'll get the insurance...
It depends on what servos you chose. I'm running HS-985s off the ICE 100 built in bec. No problems.
Safety Hawk is offline Find More Posts by Safety Hawk
Old Feb 25, 2010, 01:41 PM
ipsmotors is offline
Find More Posts by ipsmotors
3DHS Junkie
United States, CA, Fullerton
Joined Nov 2007
Any of you guys running the ICE100 without a separate BEC? I'm trying to figure out my power setup.
Got a recommendation to use the Hacker A50-12L...any thoughts on this motor?
I've got 2 planes, 68 Velox & 70 Slick, running the ICE100 on the internal BEC. Slick has digital servos the Velox has analog. No issues with either, 200+ flights.
Run what makes you comfortable.
ipsmotors is offline Find More Posts by ipsmotors
Old Feb 25, 2010, 01:42 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Originally Posted by CooHead View Post
MantaMan.
The new Motrofly from Ken is good on 6S for this Slick?
I couldn't wait any longer for one for my Velox...but the SLick is coming to this house sooner than latte.
I have a Motorfly 3625-800 (perfect for 57"SC) sitting here NIB. Ken would be good enough to let me return it, but that aint fair. I'm hoping his newer/bigger 6S motor will be good for the Slick and he will then let me return it (with restocking charges) and put the credit towards the bigger motor for the Slick...and one of his 100+ amp ESCs for it.
Do many run a Motrofly 100amp ESC? They work AOK?
CooHead
Dude,this new wind he put on the motor in my 70 slick is very good on 6s.Stupid power with the 20x10 prop.I'm gonna put a 19x10 on it when it gets here and see if can drop the amps little bit.They are within what the system is rated for,but I need a little less bite in hover hehehe.I still have the other motor in my box,am gonna send it to him and let him rewind it to 383kv also.Then put it in either a big vyper or a velox.
Manta1 is offline Find More Posts by Manta1
Old Feb 25, 2010, 02:01 PM
jfv61 is offline
Find More Posts by jfv61
Go guerrilla
jfv61's Avatar
Austin, TX
Joined Jul 2005
Several of us are very happy with the 12L, you may need to make adjustments to get a spinner gap you are happy with (search the thread for "12L" and you can find all the details). I have the HV-85 and separate CC BEC in the Slick but am using the ICE 75 and internal BEC in my 68" Velox (HS-985) - rock solid so far.
jfv61 is offline Find More Posts by jfv61
Old Feb 25, 2010, 03:33 PM
Jevgeniy is offline
Find More Posts by Jevgeniy
Jevgeniy's Avatar
Joined Apr 2009
Probably I'm wrong, but I can remember some people reported problems with integrated CC ICE100 BEC and digital servos in harsh meneuers, at this thread.
At least that's why I have purchased CC BEC PRO .
Jevgeniy is offline Find More Posts by Jevgeniy
Old Feb 25, 2010, 04:08 PM
NTM is offline
NTM
Find More Posts by NTM
NTM
NTM's Avatar
Lloydminster, AB, Canada
Joined Nov 2005
Originally Posted by Manta1 View Post
will do,think I am gonna sell my 4025-12 and try the 4035-380 myself.now,the 4025-12 pulled my 70 slick with authority for sure,but I want to try the 380.I believe it will be a sweet motor also.
If you run the numbers through scorpion's motor calc program, the 4025-12 is a better motor on 6s. And lighter too.
With the 4025-12 on 6s and an apc 18x10e prop:
8062 g (274 ounces) of thrust at 73.3 mph = 94 amps and 135 degrees (f) motor temp.
With the 4035-380 on 6s and an apc 20x11e prop:
7297 g (257 ounces) of thrust at 64.8 mph = 111 amps and 150 degrees (f) motor temp.
The 4035-380 on 6s and an apc 19x10 prop:
6326 g (223 ounces) of thrust at 61.3 mph = 100 amps and 136 degrees (f) motor temp.
NTM is offline Find More Posts by NTM
Old Feb 25, 2010, 04:23 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
on 6s with 18x8 i got 94-98 amps and temps were around 140 degrees f i dont know what thrust was but watts were around 2300,it is a great motor.
pulled the slick around fantastic yes.
Old Feb 25, 2010, 04:46 PM
cje0114 is offline
Find More Posts by cje0114
cje0114's Avatar
Carteret, NJ
Joined Feb 2006
I have the 4025-12 with a xoar 18x8. I think it was pulling 83 amps and a little over 1800 watts with a 6S Zippy 5000 20C pack. The plane has unlimited vertical and pulls out of a hover very well.
Chris
cje0114 is offline Find More Posts by cje0114
Old Feb 25, 2010, 05:02 PM
Jevgeniy is offline
Jevgeniy's Avatar
Joined Apr 2009
I don't know which programm you are using, but check out their data charts and their scorpion calc.
http://www.scorpionsystem.com/files/...data_chart.htm 4025-12
http://www.scorpionsystem.com/files/...data_chart.htm 4035-380
4035-380 are supposed to be more efficient.
At their charts using 18X10 props they'v got:
236,34Oz thrust @21V;96Amps (2016W);6657RPM with 4025-12
232,81Oz thrust @22V;78Amps (1716W);6564RPM with 4035-380
Which means that using 18X10 prop you get 0,117 Oz per watt using 4025-12 VS 0,136 Oz per watt using 4035-380
Old Feb 25, 2010, 05:38 PM
ambientech is offline
Find More Posts by ambientech
ambientech's Avatar
Central Texas
Joined Jun 2008
The A50-12l is what I am running with a 20x10 xoar. Love it!!
ambientech is offline Find More Posts by ambientech
Old Feb 25, 2010, 05:39 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
yep either motor will work great.my battery pack was further to the front of the battery tray with the 4025 but who cares the battery tray is the most roomy one ive had in a plane.hey for around 100 bucks the 4025 is a winner for sure.and the collet prop adapter has not come off for me yet.
Old Feb 25, 2010, 05:43 PM
brucewsb is offline
Find More Posts by brucewsb
brucewsb's Avatar
Santa Barbara
Joined Apr 2008
You can't compare those motors using the same prop due to the different KV. I'm betting an 18x8 on 4025-12 (440KV) will give about the same power and efficiency as an 18x10 on the 4035-380 (380KV).
brucewsb is offline Find More Posts by brucewsb
Old Feb 25, 2010, 05:48 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
+1 18x10 Id put money it would pull well over 100amps,and the motor would not last long.esp if its an apc prop.
Old Feb 25, 2010, 05:51 PM
Jevgeniy is offline
Jevgeniy's Avatar
Joined Apr 2009
Lighter motor with higher KV will allways be less efficient. Cause of heat.
But 15% difference at their data charts seems a but too much to me.
They have tested these at some strange voltage levels.
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
