70" AJ Slick Scorpion 4025-12 Originally Scorpion Commander 120amp ESC, changed to Ice 100amp ESC. Zippy Flightmax 6s 5000mah 20c Xoar 18x8 When I first ran the set-up with the Scorpion ESC it was pretty doggy. It would climb vertically out of a hover but just barely. I decided to change controllers because my 68" Velox with the same motor and an Ice 100 ESC was WAY more powerful with just a 17x8 Turnigy wood prop. After I dropped the Ice controller in with the latest firmware, it was a completely different plane! It will now climb vertically from a hover with authority. My Wattmeter fried during the time I was putting the Slick together, so I haven't watt-metered it yet, but my Velox was pulling 1850 watts at 82 amps. So I figured I'd be fine with the Xoar since alot of others were running the same set-up. I actually wish I'd've found this one before I started buying motors: http://www.innov8tivedesigns.com/pro...roducts_id=539 I think it's actually the perfect 6S motor for this application. But that's just my opinion... Fred |
S-4035-330 motor, 8s lipo, and 18x8 prop: Amps – 88 Watts – 2534 RPM – 8,550 Thrust – 297 ounces (18 pounds 9 ounces) |
3 ounces is just a little more than the weight of a servo. You'll never even know the weight is there except that it is more powerful! Fred |
I just have to figure out if I want the 70 slick, or wait for the 72 extra. |
RotorJockey's post above contains an important point. All of these motors in the 50S/4025 range are very similar. They are good up to about 1800-1850W. That's approx 200W/lb. on the slick. 200W/lb is good vertical. The larger motors, in the 50L or 4035 class, are good into the low-mid 2000's for wattage. This should provide extreme vertical if propped correctly. Make sure you are getting what you paid for, nobody should have less than 200W/lb at full throttle on any of these powerplant choices.
That other Scorpion posted above, the 4035 might be a better choice if you really crave power. The Slick will handle the weight of the motor just fine. The 4025 is about an ounce lighter than the Reaper and Hacker I think, so the 4035 is only going to effectively be two ounces heavier that the other choices. I'm happy with the 4025 though. I suppose the 4035 would give a bit of headroom in not operating at the motors max recommended watts if ran at ~2000-2100 watts. |
-Mike |
| Thread Tools | |
| Poll 3D hobby shop 51" slick or 55" SHP? | appleflyer | 3D Flying | 24 | Mar 24, 2009 06:29 PM |
| Video 3D Hobby Shop's AJ Slick | Clark Warfel | Electric Plane Talk | 3 | May 08, 2008 07:31 AM |
