Old Dec 29, 2009, 10:02 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
excellent!thank you!!
Manta1 is offline Find More Posts by Manta1
Old Dec 29, 2009, 10:08 PM
blakevan is offline
Find More Posts by blakevan
Ta-dah!
blakevan's Avatar
United States, TX, Richardson
Joined May 2007
Matt, I hate to ask but which ESC and any ideas on why/how it failed?
Condolences
blakevan is offline Find More Posts by blakevan
Old Dec 29, 2009, 10:28 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
I was running the ice100 from castle.dont know why it failed.carma?who knows.the capaciters were still in the unit,the thunderpower battery has 66%still in it,voltage went in,none came out to rx.electronics,it happens..i make my living on vehicles that their electronics fail so i can only bitch so much.solders were good,all connections were good.powered up rx with separate battery pack then she came alive.i think bec went toast...985 servos all around that worked great.tis one hurts tho..
Old Dec 29, 2009, 10:57 PM
cayars is offline
Find More Posts by cayars
cayars's Avatar
Bridgeton, NJ
Joined Mar 2009
Originally Posted by RotorJockey View Post
I guess it's just a matter of preference.
I have many different aircraft with the electronics powered many different ways.
I feel most secure with my 2s A123's and 2s LiFo's (same as A123s).
No electronics (BECs or Regulators) to fail. Fast charge rate. Very flat discharge rate. Redundency, 2 packs on my 9100, 1 pack connected to 2 channels on my 7000. After 4 hard flights, only 300mah used out of a 2100mah pack. If my flight packs fail or eject or my ESC cooks, I still have electronics.
I always charge my Rx at the field before the first flight (only takes 10 minutes) and regularly check throughout the day which is no different from checking a flight pack before you take off.
Fred
I take a semi different tack then what's been mentioned here. On semi bigger planes (or more expensive) I'll add a 2nd receiver and UBEC. I'll setup the left half on the 1st receiver using stock BEC and the right side on the 2nd receiver and UBEC.
I feel, for the minimal weight gane, this gives me many advantages. I'm splitting servo load across two radios ($50-70) and I can still have control over the plane if one radio dies. If it happens to be a twin engine plane (many of mine are or 4 engine) I use the BEC on each speed controller if built in or just use two UBECs.
Just my 2 cents to muddy the waters,
Carlo
cayars is offline Find More Posts by cayars
Old Dec 30, 2009, 12:43 AM
jadamian75 is offline
Find More Posts by jadamian75
jadamian75's Avatar
Fort Collins Colorado USA
Joined Oct 2007
Thanks for the info Manta. It really helps prevent other losses. I have been running the CC BEC in my 70" Slick with the ice 100 and 5985 digital and same setup in the 68" Velox except using the analog 985 mgs with the CC BEC. If I did it again I would go for even more overhead protection with the CCBEC Pro. It wasn't out when I bought the stuff for those planes.
Joe
jadamian75 is offline Find More Posts by jadamian75
Old Dec 30, 2009, 12:58 AM
G.P. is online now
Find More Posts by G.P.
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
Carlo
I've done that on planes this size too in the past. With one elevator servo on the Slick I thought it wouldn't be worth it though. It was nice on my other gas planes though because I put the ignition on one Rx and the throttle / choke on the other. That way I would at least be able to always kill the engine even if one Rx system went dead.
G.P. is online now Find More Posts by G.P.
Old Dec 30, 2009, 01:01 AM
G.P. is online now
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
Well, I have an Ice on order just so that I can get rid of my Rx battery. I even bought some new 985's to replace my digital servos. Guess that was a waste of money.
I may still go with the Ice just because I hate the spark arrestor circiut on my Hacker X80. It's good in theory, but I've had it short circiut my battery twice while hooking things up.
The Ice doesn't have a spark arrestor circuit........does it? If it does I might as well cancel the order.
Old Dec 30, 2009, 01:04 AM
RotorJockey is offline
Find More Posts by RotorJockey
Fly Low-Crash-Rebuild-Repeat !
RotorJockey's Avatar
Jackson, MO
Joined May 2009
No, it doesn't.
RotorJockey is offline Find More Posts by RotorJockey
Old Dec 30, 2009, 01:13 AM
G.P. is online now
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
Thanks! At least it has that going for it.
Guess I'll try to source out a CC BEC Pro so that I can still get rid of my Rx pack.
Old Dec 30, 2009, 01:16 AM
Jackson, MO
Joined May 2009
Tower has them in stock:
http://www3.towerhobbies.com/cgi-bin...&I=LXYCA6&P=ML
Fred
Old Dec 30, 2009, 01:34 AM
jadamian75's Avatar
Joined Oct 2007
I really like the giant exposed heat sink all around the ICE Controller. I was never a fan of speed controllers covered in shrink wrap. Especially a heat sinks completely covered in shrink wrap.
Old Dec 30, 2009, 01:49 AM
G.P. is online now
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
You should take a look at the Hacker X80....it has it's own cooling fan!!!! It really is a nice esc. I'm going to try one more thing with spark arrestor circuit, but if that doesn't work she's gone for safety's sake.
Thanks for the tip on the BEC PRO's Fred. I haven't read of any problems with them yet....has anybody else?
Old Dec 30, 2009, 03:05 AM
BoneDoc is offline
Find More Posts by BoneDoc
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Manta, if I had to guess, your elevator and / or rudder might be binding. A flat spin is a full down elevator, full left rudder maneuver, so it's entirely possible that if the control binds at the end (trying to squeeze the last couple of degrees), it might have overworked the BEC.
Regardless though, I'm glad that there's only minimal damage to the plane itself. Your Slick have got nothing on mine .
BoneDoc is offline Find More Posts by BoneDoc
Old Dec 30, 2009, 08:17 AM
RC4x4 is offline
Find More Posts by RC4x4
Fly Low or you'll never know!
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
CCBEC Pro and a 2s lipo for me on these big guys.
I wouldn't trust the internal bec. Just my two cents.
Cory
RC4x4 is offline Find More Posts by RC4x4
Old Dec 30, 2009, 08:37 AM
feathermerchant is online now
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
I second what he said. Have y'all bothered to check for binding servos using your Wattmeter or other current measuring device? Analog servos are usualy quiet until they start to strain. Digitals make noise all the time and also draw much more current when bound up. It's hard to tell normal noise from binding.
As I posted before, I observed the receiver lights flashing slowly after a flight indicating a 'brownout' so I reduced the elevator endpoints 10% each way and it has not returned.
feathermerchant is online now Find More Posts by feathermerchant
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
