Old Mar 07, 2013, 06:41 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Originally Posted by losifanatic View Post
Ok 3dhs had some miss marked boxes. They sent me two gas motor box kits they are taking them back. Well the problem is they are out if electric motor boxes so it looks like my slick is going to be down for a while
That really blows Matt.
turnerm is offline Find More Posts by turnerm
Old Mar 07, 2013, 06:55 PM
Reaper802 is offline
Find More Posts by Reaper802
Reaper802's Avatar
United States, MD, Lexington Park
Joined Jun 2002
Sounds like it's time someone traced out a motor box kit so folks can cut them as needed... Simple stuff like that should never be out of stock if you own a cheap cnc cutter.
Reaper802 is offline Find More Posts by Reaper802
Old Mar 07, 2013, 07:49 PM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
Huge bummer... I have access to a laser... no drawing or material though. Wish I could make you one...
3DNater is offline Find More Posts by 3DNater
Old Mar 07, 2013, 09:00 PM
goflyhighrc is offline
Find More Posts by goflyhighrc
Just go with the flow
goflyhighrc's Avatar
Joined Nov 2006
Well I suppose I better open the 71" Electric Motor Box kit that's been sitting in my office for a few months to see if it's in fact "electric".
goflyhighrc is offline Find More Posts by goflyhighrc
Old Mar 07, 2013, 09:02 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
If it is are you willing to sell it
losifanatic is offline Find More Posts by losifanatic
hertzrepkeith is offline
Find More Posts by hertzrepkeith
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
So that you can send it to Matt????
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Mar 08, 2013, 10:42 AM
rimaarts is offline
Find More Posts by rimaarts
United Kingdom, London
Joined Jul 2011
guys... i have (i think) sahara regulator in my slick and aerotech ibec... and only 3x 2200 2s batteries... can i use a 3s 2200? (i know its weight penalty slight) but wont i fry my servos?
how can i test my sahara regulator output?
rimaarts is offline Find More Posts by rimaarts
Old Mar 08, 2013, 12:04 PM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
Losi, now that I have a DX8, what are your Throttle Curves for the 71 Slick and the 57 SC? Going to INH my old DX7 Throttle mixes.
heritageflyer is offline Find More Posts by heritageflyer
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
Do you have a watt meter? Mine gives the voltage.
Old Mar 08, 2013, 01:33 PM
Joined Nov 2006
I might need it if I let you fly my 70"
Old Mar 08, 2013, 01:57 PM
rimaarts is offline
Joined Jul 2011
thing is that when i hook my life, it does not work... works on lipo! i wanted to know how much woltage does servos get... guess the only way is to make jr-app adapter....
and looking trough sahara manual, looks like it does not take 3s lipos... input voltage seems to be 10v max.. ill shoot them email...
http://www.fromeco.org/Products/02FRCSAH-230/
now when im a bit smarter than when i bought it... it looks like not very good choice? 2x jr input, 2x jr output... means only 6a max current?? 10v max input voltage? so no 3s lipos... sigh... i should have gotten castle bec pro....
Old Mar 08, 2013, 05:47 PM
Joined Nov 2006
Fixing my back up 70" Original Scheme, just found a brand new pair of wings for it.
Old Mar 08, 2013, 07:04 PM
Joined Jan 2012
Ouch!!!!!! So do you want me to fly it
Old Mar 08, 2013, 08:18 PM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Got my Slick ready to fly tomorrow with the 7955's on 8.5v. I'm using an AR7000 rx that says its rated up to 9.6v so I assume I'll be ok?
Can't wait to try it out. I can already see a difference from the 985's on the bench!! These suckers chatter a lot too don't they?
Old Mar 08, 2013, 08:39 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Yes, you might want to cut the voltage back to 7.4 volts. I asked Tony at Hitec RCD about HS-7955TGs and while they were not originally rated for HV, they don't have a problem running on HV, with the exception of chatter around center. There is a way to get rid of the chatter though. If there is room ust put a small piece of the fuzzy part of Velcro between the counter balance and the stabilizers (both vertical and horizontal) and also between the end of the ailerons and the wing.
SteveT.
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
