Old Feb 17, 2013, 03:49 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by hertzrepkeith View Post
Ok you win! I actually dont remember how easy my 71 hovers because it has been soo long since I have been able to fly it! Soon Were you ever able to get those Standoffs made??
I have to go pick up some 1/2" Aluminum tomorrow, and will make them then. I thought I had enough but didn't....and the place where I get my material is not open on Saturday or Sunday....
SteveT.
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Feb 17, 2013, 03:50 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Originally Posted by heritageflyer View Post
The Gyros.....
LOL!!!
SteveT.
Old Feb 17, 2013, 06:28 PM
Dennis C is offline
Find More Posts by Dennis C
Dennis C's Avatar
Grass Valley California
Joined Jun 2004
After talking with Mike at Aero Models I went with the A60-5s an APC 20x11 and 8s 4000
Pull pull on the rudder
Maidend yesterday, with the packs against the wing tube it was just neutral/tail heavy, moved them a half inch forward and it is very close, more flights to come.
Sweet power
So little coupling I can not tell if I need any mixing
Back out for more in a couple minutes
Dennis
Dennis C is offline Find More Posts by Dennis C
Old Feb 17, 2013, 07:43 PM
hertzrepkeith is offline
Find More Posts by hertzrepkeith
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
Os motor
No problem Steve! What a sweet running motor this thing is! I cant fly it with those standoffs but I can sure listen to it run and NOT DIE! Here is a Video from earlier.
OS GT33 (1 min 2 sec)
SteveT.
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Feb 17, 2013, 07:49 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
AWSOME!
OS nailed it with that engine.
Manta1 is offline Find More Posts by Manta1
Old Feb 17, 2013, 08:45 PM
Joined Jan 2012
Hell yes they did!! Hey today when I put the Prop on I realized that is did not fit on the shaft . What do you guys use that will make it snug?? Also Can I not use the Carbon Spinner I got from 3DHS for the DLE Motor with this motor??
Originally Posted by Manta1 View Post
AWSOME!
Old Feb 17, 2013, 08:50 PM
goflyhighrc is offline
Find More Posts by goflyhighrc
Just go with the flow
goflyhighrc's Avatar
Joined Nov 2006
If your saying the hole is to big I think you need to get a new prop. I'm not sure if you can fill it and redrill, perhaps so if the hole is dead center if not, the prop will spin out of wack.
goflyhighrc is offline Find More Posts by goflyhighrc
Old Feb 17, 2013, 08:56 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
if its too big best option is to use a spacer on the prop shaft, like a bushing of some sort. that will keep everything lined up
rcbirk21 is offline Find More Posts by rcbirk21
Old Feb 17, 2013, 08:57 PM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
APC props come with some spacers that may work.. If not use tape as a spacer... it will go around the shaft evenly and hold prop centered until the nut clamps down on it and keep it in place.
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Feb 17, 2013, 09:01 PM
SnowDog1974 is offline
Find More Posts by SnowDog1974
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
Craig sells prop bushings for the OS GT33 that fix this specific problem.
http://www.customstandoffs.com/
SnowDog1974 is offline Find More Posts by SnowDog1974
Old Feb 17, 2013, 09:03 PM
Joined Nov 2006
Don't think I'd use tape on the shaft, bushing of some sort would be better if he can find one to fit the exact size of the hole then drill it out to the prop shaft size. Personally, I'd get a new prop and make sure it fits the shaft or is smaller than the shaft so it can be reemed out.
Old Feb 17, 2013, 09:12 PM
Joined Jan 2012
I thought that I had heard this was a common issue with the OS Motor. That is probaly why some people run the electric Prop because it fits perfect on my 21x10 PJN Xoar Prop. Doug The prop I am using has not been drilled at all the shaft of the OS is just smaller. I ran it today just by butting the nuts up to it....but I know that was causing some vibration from not balancing properly.
Old Feb 17, 2013, 09:16 PM
Joined Nov 2006
If the prop has not been drilled at all how'd you get it on the shaft
Old Feb 17, 2013, 09:19 PM
Joined Oct 2011
Got this trick from theKM.
http://www.rcgroups.com/forums/showp...40&postcount=9
Old Feb 17, 2013, 09:24 PM
Joined Nov 2006
Bingo !
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 07:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 08:31 AM
