Old Feb 16, 2013, 10:05 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
74" Edge is easier to hover than the 71" Slick, which is easier to hover than the 72" Extra....at least for me...but I have also never flown a Vyper (other than the Vyper bipe).
SteveT.
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Feb 16, 2013, 10:40 PM
United States, MI, Allegan
Joined Aug 2012
Originally Posted by Manta1 View Post
65 vyper is the easiest plane ive ever hovered. 71 slick and 89 slick very close 2nd.
What makes one plane easier to hover than another?
TimmyC is offline Find More Posts by TimmyC
Old Feb 16, 2013, 10:44 PM
SteveT.'s Avatar
San Jose, CA
Just that.....When you attempt to hover them, they are easier...
SteveT.
Old Feb 16, 2013, 10:46 PM
Team 3DHS
joesmith285's Avatar
United States, IN, Fort Wayne
Joined Nov 2008
Basically the amount of control required to keep them there. Some planes will happily sit in a hover and others take some work to keep them there.
Like Manta said, the 65 vyper is by far the easiest plane I have ever hovered. Once I got it into the hover it basically sat there on it's own.
joesmith285 is offline Find More Posts by joesmith285
Old Feb 16, 2013, 11:05 PM
Joined Aug 2012
I get that part. I was wondering what in the plane's construction makes it hover more easily than another.
Old Feb 16, 2013, 11:23 PM
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
Guys. with my new OS GT 33 Motor. I am running a Ultra Tec BEC with a Badger switch and everything is ran off 1 2S 1500 Lipo. The OS says that I can run from 4.8-7.4 so do I just take the all clips off the Ultra Tec BEC?? In the Manual of the Ultra Tec Bec it show 4 different ways to set it up. 5.0 Volt/ 5.3 Volt/6.1 Volt & 6.6Volt which shows a Picture with no Clip attached. I just dont want to burn up the ignition that is why I am asking. I know that the DLE was 5.3 (I believe) Thanks for the help.
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Feb 16, 2013, 11:26 PM
Joined Jan 2012
I think the 71 is a lot easier to hover the the 74 Edge. Maybe it is because I am running a 21x10 Prop and the amount of Ail input that I need can make it challenging.
SteveT.
Old Feb 17, 2013, 12:54 AM
SteveT.'s Avatar
San Jose, CA
When I attempt to hover, all controls are on high rate....and even with the gas carbon fiber prop, I don't run out of aileron....That said, I'm not all the great at hovering, but for me, the Edge gets it... YMMV...
SteveT.
Old Feb 17, 2013, 01:16 AM
Joined Jan 2012
Ok you win! I actually dont remember how easy my 71 hovers because it has been soo long since I have been able to fly it! Soon Were you ever able to get those Standoffs made??
SteveT.
Old Feb 17, 2013, 06:51 AM
3D or Die
alfabeast's Avatar
Merrimac, MA
Joined Jan 2006
Originally Posted by turnerm View Post
I agree on the 57. Not the easiest plane to hover but awesome in every other way! The 71 is the easiest plane I've ever hovered. The 51 isn't far behind.
I had the 57 with a reaper 60, a little nervous in hover, maybe overpowered and too much torque and P factor. Have the 71 inch slick on recommended set-up - A50-12L, 6s, 20 x10 xoar, 19 x 10 in hotter temps. Easiest plane to hover I have ever owned ... and easier than foamies!
So from my experience, getting the sweet spot on motor and prop combo really helps. Am flying the slick with a forward (precision) CG, once again as recommended by the designers.
alfabeast is offline Find More Posts by alfabeast
Old Feb 17, 2013, 08:20 AM
smithder's Avatar
USA, TX, Pearland
Joined Mar 2005
Anyone know how the little 42 Slick compares to the 71? Seems like a great little practice plane if it retains the flying traits of the 71.
smithder is offline Find More Posts by smithder
Old Feb 17, 2013, 09:10 AM
United States, NC, Hertford
Joined Dec 2012
51
The 51 is a great practice plane
D_racers is offline Find More Posts by D_racers
Old Feb 17, 2013, 10:50 AM
Joined Jan 2012
19x8 Xoar Prop that is Drilled for a DLE motor(4 Bolt Pattern). Is it a big deal to run with my OS GT Motor??
Old Feb 17, 2013, 11:01 AM
Have U Snapped A Slick Today??
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
The Gyros.....
heritageflyer is offline Find More Posts by heritageflyer
Old Feb 17, 2013, 12:17 PM
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
It flies similar if you keep 42" light... IMO, 160g max battery weight when using a 100g motor. Haven't flew it with a 70g motor but I would think it would get doggy with heavier packs too.
bryansifsof44 is offline Find More Posts by bryansifsof44
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
