Old Feb 15, 2013, 03:41 PM
jonathan7x70 is offline
Find More Posts by jonathan7x70
Fly, fly, fly, fly , fly more!
jonathan7x70's Avatar
Lafayette, Louisiana
Joined Dec 2005
wow Joe.. Nice answer. I know your a Hacker and Castle sponsored guy BUT... Any idea on rimfire with ZTW?
jonathan7x70 is offline Find More Posts by jonathan7x70
Old Feb 15, 2013, 04:22 PM
joesmith285 is offline
Find More Posts by joesmith285
Game on
joesmith285's Avatar
United States, IN, Fort Wayne
Joined Nov 2008
I just wanted to state the facts. I don't find this to be out of the ordinary as every esc I have tried does the same thing. Run a little higher idle and you'll never know they do it.
I haven't used the rimfire, but I have heard great things about it so hopefully that holds true.
I have used a ZTW though and I honestly found it to be very inefficient compared to a Castle equivalent. The ZTW pulled excess current and ran hotter when compared to the castle but the power output was the same. IMO, the ZTW will be fine to use but I wouldn't put it above a similiar castle.
joesmith285 is offline Find More Posts by joesmith285
Old Feb 15, 2013, 04:27 PM
Joined Dec 2005
Thanks! I do love my Castles but to many planes.... have to shave cost some ware. lol
Old Feb 15, 2013, 04:37 PM
hertzrepkeith is offline
Find More Posts by hertzrepkeith
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
That's exactly what I use! They were saying something about causing interference because of the ignition I believe. But I'm not positive
Originally Posted by SteveT. View Post
Yes, but as I have never seen a titanium clevis, I was assuming that he was using something like this with ball links...
SteveT.
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Feb 15, 2013, 05:04 PM
goflyhighrc is offline
Find More Posts by goflyhighrc
Just go with the flow
goflyhighrc's Avatar
Joined Nov 2006
Who's they ? ---- your info is only as good as the source
goflyhighrc is offline Find More Posts by goflyhighrc
Old Feb 15, 2013, 05:06 PM
Joined Dec 2005
Blaaaaa
Old Feb 15, 2013, 05:20 PM
Joined Jan 2012
Old Feb 15, 2013, 10:55 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Well my day wasn't that good. My son accidently broke the rudder on my 51 slick and my brother crashed my 71 slick. Brother took out the prop, broke the cowl, ripped the landing gear out and everything it was attached to, split the cf gear, and broke the wheel pants. So my 2 favorite planes are broken both can be fixed but its going to take a bit to gather the funds. Makes me wish l didn't sell all my other planes
Just not a good day. Oh my ses light turned on in my truck today and l got a speeding ticket. When it rains it pours.
losifanatic is offline Find More Posts by losifanatic
Old Feb 15, 2013, 10:58 PM
Joined Jan 2012
Man that is a total Bummer! Make your Brother Fix your 71!
Old Feb 15, 2013, 11:06 PM
racerman27410 is offline
Find More Posts by racerman27410
racerman27410's Avatar
United States, NC, Greensboro
Joined Dec 2006
OK Guys I have a question and concern. With my DLE 30CC I ran a Carbon Still Rod with Titanium ends. I was out at the field the other day and the guys told me that I do not want to run this with the OS Motor. That I should use a something else for my Throttle Rod. Is this true? Or is it ok to run with my OS Motor?? Also can I break in with 20x6 Prop or do I need to use 18x8 Prop. I hear people say to break in with what you plan on using. I know I have asked a few times and no responses so I am sorry to keep asking.
I use goldenrod for my throttle linkage because i believe it helps isolate the engine vibration on both ends of the linkage.... from the throttle servo on one end and the throttle shaft where it goes thru the carb (BTW that shaft is hollow and a replacement carb is very expensive)...IMO if properly supported the goldenrod moves just as fast as a solid rod.
I broke my both my OS 33's in with a 19x8 protek RC electric prop on a tip from another OS user (who works for 3dhs) and still run that size since it gives literally electric motor throttle response.... the OS will also whip a 20x6 Xoar around nicely just not quite as quick on the throttle response.
racerman27410 is offline Find More Posts by racerman27410
Old Feb 15, 2013, 11:09 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Sorry to hear this Matt!! But I have to ask.....did the wings pull out???
SES light....what is that?? And....slow down!!
SteveT.
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Feb 15, 2013, 11:18 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
SteveT.
Service Engine Soon
3drcparts is offline Find More Posts by 3drcparts
Old Feb 15, 2013, 11:21 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Originally Posted by Inverted-I-Fly View Post
Service Engine Soon
Got it....Thanks..
SteveT.
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Bummer losi... good luck getting them up and going again. I've had my share of bad luck with the 71". Broke counter balance off elevator hitting the snow... fixed it. Struck the rudder on the ground broke it... Ordered new one (last in stock). Plane doesn't even need to be flying to get beat up. I had a low voltage cutout on a 48" plane that dropped a cell in low rolling harrier... harrier rolled right to the rudder of my 71. Broke rudder and nicked up vertical stab on fuse... fixed old broken rudder that was in better shape since 3DHS is OOS. Now that is has some battle scars I could beat it up now. But I took a lot of pride in this one and it sucks I've had so much bad luck with it.
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Feb 15, 2013, 11:30 PM
smithder is offline
Find More Posts by smithder
smithder's Avatar
USA, TX, Pearland
Joined Mar 2005
That sucks Losi. They always seem easier to fix after a nights sleep and time for the hurt to wear off. I'm sure you will have them going it no time.
smithder is offline Find More Posts by smithder
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
