Old Feb 13, 2013, 05:33 PM
hertzrepkeith is offline
Find More Posts by hertzrepkeith
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
I am glad that worked out for you. I replaced the Diaphram Spring & I had a guy that has been tuning engines for 30 Yrs in RC working on mine and it still died. His efforts did make a difference, but not worth the risk. My new OS has arrived and I am .
Originally Posted by kerwin50 View Post
When the DLE is inverted an dies, it maybe a tuning Issue, a cowling airflow issue , the diaphram spring being too weak, or the diaphram lever not set correctly.
Mine did the same thing an it was a tunning Issue.
I can now roll her over inverted at any throttle setting an never miss a lick
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Feb 13, 2013, 08:21 PM
Joined Jan 2012
Guys, I received my OS motor today and I have already cut the cowl out for it. I know it says 44.5MM for Stand offs. The DLE ones that come with it make the motor Stick out about 1/2 Inch too far. On the DLE I used a Special Ordered throttle arm from Troy Built. Did you guys just use the one that comes with it?? Also can I use a 20x6 to break in motor or do I need to use the 18x8 that is recommended?
Old Feb 13, 2013, 08:30 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
As per my call, just let me know what you need and I'll make them for you.....
SteveT.
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Feb 15, 2013, 08:58 AM
jonathan7x70 is offline
Find More Posts by jonathan7x70
President @ Acadian RC Club
jonathan7x70's Avatar
Lafayette, Louisiana
Joined Dec 2005
Just ordered two ZTW-B's for one 50cc rimfire and one motrofly 4325.... after reading this thread around the 1785 post page.... Seams that the ZTW's work fine... I hope cause that would be a major score vs setting up my other 6 planes all on Castle... major savings!!! Heck I might have saved enough to by the New 3DHS Edge!!
jonathan7x70 is offline Find More Posts by jonathan7x70
Old Feb 15, 2013, 12:49 PM
Joined Jan 2012
OK Guys I have a question and concern. With my DLE 30CC I ran a Carbon Still Rod with Titanium ends. I was out at the field the other day and the guys told me that I do not want to run this with the OS Motor. That I should use a something else for my Throttle Rod. Is this true? Or is it ok to run with my OS Motor?? Also can I break in with 20x6 Prop or do I need to use 18x8 Prop. I hear people say to break in with what you plan on using. I know I have asked a few times and no responses so I am sorry to keep asking.
Old Feb 15, 2013, 01:13 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
They work great!
zmonster97 is offline Find More Posts by zmonster97
Old Feb 15, 2013, 01:22 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Ive heard nothing but praise for those ESC's.
Manta1 is offline Find More Posts by Manta1
Old Feb 15, 2013, 01:45 PM
bryansifsof44 is online now
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
The ZTW ESCs are nice and work great... But the throttle response is not as smooth as the castles I have used. A idle up really helps out for a smooth throttle startup and running.
bryansifsof44 is online now Find More Posts by bryansifsof44
Old Feb 15, 2013, 02:06 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
follow the manual. Break it in with a 18x8. You dont want the load of a 20x6 on a fresh motor. I dont know about the throttle rod but making it as close to one piece as possible is the rule I follow.
going4speed is offline Find More Posts by going4speed
Old Feb 15, 2013, 02:44 PM
Joined Dec 2005
Im glad to hear all the great talk about the ZTW ESC's.... anyone used it on a 50cc rimfire or equivalent?
Old Feb 15, 2013, 03:03 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
What reason did they give for not using the carbon rod and titanium ends? If the ends have been properly epoxied into the carbon rod, I see no reason not to use it. If they can be used on the control surface of a plane which gets lot more force put on them, then I don't see a problem.
SteveT.
Old Feb 15, 2013, 03:08 PM
jsmith285 is offline
Find More Posts by jsmith285
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
SteveT.
Probably just the vibration from the motor. Ball links don't make
bigger holes the more you fly
jsmith285 is offline Find More Posts by jsmith285
Old Feb 15, 2013, 03:14 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Yes, but as I have never seen a titanium clevis, I was assuming that he was using something like this with ball links...
SteveT.
Old Feb 15, 2013, 03:58 PM
alfabeast is offline
Find More Posts by alfabeast
3D Addict
alfabeast's Avatar
Merrimac, MA
Joined Jan 2006
Have experienced the same on some, not all of the ztw's. Before you take off, just trim throttle up so the prop barely spins. I had a 110 amp where the endpoints drifted while flying, so you would go low throttle and the the prop stopped. Have a 60 and 120 that are fine, no issues. I do have a steeper throttle curve dialed in my futaba 8fg. The Castle ICE 100's I run are a little smoother and run cooler.
alfabeast is offline Find More Posts by alfabeast
Old Feb 15, 2013, 04:25 PM
joesmith285 is offline
Find More Posts by joesmith285
Game on
joesmith285's Avatar
United States, IN, Fort Wayne
Joined Nov 2008
It's probably not that the endpoints drifted, it's just that the battery voltage drops which affects the idle setting. If you had the motor constantly spinning before takeoff and then it's stopped when you land, if you wait for a little bit it will probably start spinning again as the voltage level rises. Castle's do the same thing.
joesmith285 is offline Find More Posts by joesmith285
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 07:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 08:31 AM
