Old Feb 11, 2013, 08:16 PM
3DNater is online now
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
Originally Posted by Andrew Jesky View Post
Manta, Thats because you use the ground as your sandpaper.
Hey there
3DNater is online now Find More Posts by 3DNater
Old Feb 11, 2013, 09:07 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
HA! YEP!
Figured I'd monkey with some of the guys.. Hope all is well with you and yours.
Manta1 is offline Find More Posts by Manta1
Old Feb 12, 2013, 01:50 PM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
Originally Posted by losifanatic View Post
And the issue with all the black covering pealing.
On my 74 its not the black, just a thin layer of clear on top of the black.
Maybe it's like a screen protector.
robj is offline Find More Posts by robj
Old Feb 12, 2013, 02:01 PM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
I don't know about the slick but on my little orange and black edge the covering is holding up fine.
kerwin50 is offline Find More Posts by kerwin50
Old Feb 12, 2013, 03:35 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Both Ultracote and Monokote, are basically a thin clear Mylar membrane that has a colored adhesive on it, so what is happening is that the Mylar is lifting off of it. I don't understand why ironing it back down is not curing it for some people. The couple of small areas that I have had lift did stick back down after a good ironing...
SteveT.
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Feb 12, 2013, 05:01 PM
hertzrepkeith is offline
Find More Posts by hertzrepkeith
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
So today I was out at the field and my buddy has a DLE 30 CC on his 71 Slick also. I had him flip it upside down at low RPM..GUESS WHAT.............IT DIES TOO!! Thank God my OS will be here tomorrow!
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Feb 12, 2013, 05:55 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
ya screw the 30cc dle.. i wouldnt waste my money on one..
Old Feb 12, 2013, 08:45 PM
Joined Jan 2012
I wonder how many people have this problem
I wonder how many people have this problem that dont even really know it! Alot of people dont fly Low and Slow so they probaly dont even know that this issue exist. I am still waiting to see if Tower refunds the money for the DLE. I already purchased the OS because I could not wait Because they told me they would take care of it. We will see. regardless I am out a lot of money and time. I have now sent two DLE back at close to 20 Dollars a Pop!
Old Feb 12, 2013, 09:26 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
seen a bunch of them go bad and kill planes..One killed a brand new beautiful velox right in front of me.i had just flown the plane a few minutes before and it could have been me flying it..whew...
os rocks..dle,,bla
Old Feb 12, 2013, 09:51 PM
Joined Jan 2012
I will give a Flight Detail after I fly it. I have heard different things on Props to break it in with. I have a 20x6 that I used on the DLE. Should I break it in with a 18x6 or should I use the prop that I am going to fly it with?? Or what is the best (Lightest Prop)
Old Feb 13, 2013, 09:03 AM
ChrisK7 is online now
Find More Posts by ChrisK7
USA, OR, Stanfield
Joined Jan 2005
Sorry to hear the stories about the bad running DLE 30's. I finished up my 71" Slick this last weekend and it ran absolutely perfect in all attitudes, rpm ranges, transitions, and every 3d maneuver I could throw at it.
I have mine set up all stock except a breather line running from the carb diaphragm to the inside of the fuse. I also have a Bisson pitts muffler on it.
I also left the canister tunnel open and used the vented bottom plate to allow better airflow out of the cowl for better cooling and less chance of unwanted pressure changes within the cowl to mess up the fuel metering.
I tried about 10 different props through out the day and had no issues at all with it.
Here are some pics of my setup if anyone is interested.
Name: 2013-02-12 15.58.02s.jpg
Description:
Name: 2013-02-12 15.56.39s.jpg
Description:
Name: 2013-02-12 15.55.48s.jpg
Description:
Name: 2013-02-12 15.55.25s.jpg
Description:
ChrisK7 is online now Find More Posts by ChrisK7
Old Feb 13, 2013, 01:33 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
thats a very neat and clean setup man. Nice job! i hope it never sputters on ya. Do you not make the big loop around on top of your fuel tank with fuel lines? i didnt see one. Most gassers ive seen do that for some reason i dont remember. ( dont touch it if it didnt mess up on you lol I'm just asking)
Old Feb 13, 2013, 01:52 PM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
It is so your fuel doesn't run out the fuel tank vent line when you are on a vertical downline I believe.
ryan_m is offline Find More Posts by ryan_m
Old Feb 13, 2013, 02:00 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
now that you mention it i believe thats it! Thanks! i got no gas plane so had forgotten.
Old Feb 13, 2013, 04:55 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
When the DLE is inverted an dies, it maybe a tuning Issue, a cowling airflow issue , the diaphram spring being too weak, or the diaphram lever not set correctly.
Mine did the same thing an it was a tunning Issue.
I can now roll her over inverted at any throttle setting an never miss a lick
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 07:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 08:31 AM
