Old Jan 30, 2013, 12:07 PM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
3/16 in robarts.
Lots of guys like to just use a hot soldering iron tip to melt out the old hinge. Basically you just cut off the hinge flush with the wood. Carefully melt out what is left inside with the soldering iron tip. Use a fairly narrow tip. I have read some guys like to clean it up just a bit with a drill afterward before gluing the new hinges in.
3DNater is offline Find More Posts by 3DNater
Old Jan 30, 2013, 01:18 PM
Dennis C is online now
Find More Posts by Dennis C
Dennis C's Avatar
Grass Valley California
Joined Jun 2004
For right now I will stay with the A50-14l It has been good in the Extra but the 7xs looks sweet.
UPS says Feb 6 for the slick
Dennis
Dennis C is online now Find More Posts by Dennis C
Old Jan 30, 2013, 02:02 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
1/8" Robart hinge points......3/16" are for the 50CC size planes...as to removal, there are a few methods, but, a fine point soldering iron (preferably smaller than 1/8") will melt them right out....if you don't have a soldering iron that small get a piece of music wire and heat it to melt it out.
SteveT.
SteveT. is online now Find More Posts by SteveT.
Old Jan 30, 2013, 02:21 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
1/8th is the stock size but l upgraded all mine to the 3/16ths as l liked the idea of a more robust hinge.
losifanatic is offline Find More Posts by losifanatic
Old Jan 30, 2013, 02:26 PM
ldhflyguy is offline
Find More Posts by ldhflyguy
FlyGuy
ldhflyguy's Avatar
Batavia, IL, USA
Joined Oct 2007
SteveT.
Hey Steve,
I'm curious. In case I need to remove these hinges some day, does "melt them right out" mean that they fall out, come out stuck to the soldering iron tip, get pushed in to inside the wing, or what? I've also heard about cutting around them with a piece of sharpened brass tubing. I think I would prefer not having the hinge point or bits of balsa wind up inside the wing/stab.
Thanks.
Larry
ldhflyguy is offline Find More Posts by ldhflyguy
Old Jan 30, 2013, 06:07 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Hehe ive had a hinge piece or two in a plane before. Heheh made a nice little rattle sometimes
Manta1 is offline Find More Posts by Manta1
Old Jan 30, 2013, 06:36 PM
goflyhighrc is offline
Find More Posts by goflyhighrc
Just go with the flow
goflyhighrc's Avatar
Joined Nov 2006
Originally Posted by ldhflyguy View Post
Hey Steve,
Thanks.
Larry
I've recently replaced hinges in my 89 and 70 Slicks. It's tuff not to get any pieces to drop inside the control surface. I thinks using a sharpened brass piece to cut them out will make the whole a little wider than you'd like, unless you plane on plugging with round stock,not sure though. I melted mine out and it worked pretty goo. The most important thing to do when melting them out is to make sure all the metal part of the hinge is out before melting. If left in it will pushe the soldering iron to one side of the hole a bit, therefore getting the hole off center or a bit larger than you need. If you cut the Robarts out, make sure all the metal part of the hinge is removed, just go real slow when melting, go part way in then back out it will bring some of the hinge with it, the do it again real slow.
goflyhighrc is offline Find More Posts by goflyhighrc
Old Jan 30, 2013, 08:20 PM
SteveT.'s Avatar
San Jose, CA
The only way that usually will not possibly leave a piece in the surface is to use a sharpened brass tube in a drill bit...
SteveT.
Latest blog entry: My hangar...
Old Jan 30, 2013, 09:41 PM
bryansifsof44 is online now
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Using a soldering iron worked great for me... replaced with Robarts.
bryansifsof44 is online now Find More Posts by bryansifsof44
Old Jan 30, 2013, 10:27 PM
FlyGuy
ldhflyguy's Avatar
Batavia, IL, USA
Joined Oct 2007
Thanks Guys.
I'm sure that sooner or later I'll need to replace some hinges.
Old Jan 30, 2013, 10:47 PM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
SteveT.
Have you actually ever done this? Not being ficious either.
robj is offline Find More Posts by robj
Old Jan 30, 2013, 11:18 PM
SteveT.'s Avatar
San Jose, CA
Yes....before I learned the soldering iron trick.
I broke the top hinge on my 89" Slick and fortunately since I made the rudder removable when I built it, I pulled the music wire out and removed the rudder, Fortunately only one side had broken, so I cut the hinge flush with the vertical stab, then used a very small grinding burr in a Dremel tool to grind around the outside of the hinge to bring the diameter of the large part of the hinge down to slightly less than the diameter of the part glued into the vertical stab. I then took a piece of 3/16" brass tubing and again used a Dremel tool with a tapered grinding burr to grind the inside of the tubing to sharpen it, then filed notches into it to make "teeth" in the end. Then I put the piece of tubing into the drill and put the other end over the ground down hinge...I used the high speed on my Dewalt 18 volt battery drill, and ran it in. It did a great job of removing the hinge point....with no pieces left in the vertical stab.
SteveT.
Old Jan 31, 2013, 11:26 PM
StevePortland is offline
Find More Posts by StevePortland
United States, OR, Tigard
Joined Jan 2013
Originally Posted by StevePortland View Post
Steve would not want to put you out, but will take you up if your ok with it. Is a winter build and my first big plane. Not hard up but the basterd is asking to be finished. Love this forum, good people.
Steve got the motor today, again big thanks. Going to be fun this weekend putting a hart in this bird. Know you went out of your way and hope to pay you back some day!!
StevePortland is offline Find More Posts by StevePortland
Old Jan 31, 2013, 11:34 PM
SteveT.'s Avatar
San Jose, CA
No problem...always happy to help, and that one was just being saved until Bigfoot come out...
SteveT.
Old Feb 01, 2013, 05:40 PM
GTOEric is offline
Find More Posts by GTOEric
United States, PA, Nottingham
Joined May 2012
Quick question for everyone.
Pictured below is my current RX battery setup.
I do not run switchs to eliminate a point of failure.
As you can see I have a y harness on each Aileron port.
I am running a GensAce 7.4v 2600mah battery with 2 outputs connected to each y harness for redundancy and not to overload a single connector.
No regulator as both RX and servos are able to handle a full charged 2s Lipo
Is my single battery dual connector setup adequate or should I switch to two smaller (1300-1500mah) batteries?
GTOEric is offline Find More Posts by GTOEric
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
