Old Jan 24, 2013, 02:58 PM
edf_rookie is offline
Find More Posts by edf_rookie
edf_rookie's Avatar
Australia, QLD, Brisbane
Joined Mar 2011
Originally Posted by SteveT. View Post
1mm is a bit tight, but you can add a thin washer behind each spacer. 1mm is a bit close, at .0393", I like about 1/16" (.0625")to 3/32" (.09375") in case of any flexing of the motor shaft/motor/firewall to keep the spinner from rubbing.
SteveT.
Thanks SteveT.
That's what I was worried about in case of the flexing. I run my smaller planes with a bigger gap than this one so it would make sense. Looks like I will need to go find some washers and longer bolts. The stock ones barely make it through to the end of the blind nuts with the motrofly and spacers.
edf_rookie is offline Find More Posts by edf_rookie
Old Jan 24, 2013, 04:16 PM
mdauth is offline
Find More Posts by mdauth
mdauth's Avatar
Canada, QC, Montreal
Joined Sep 2010
I'm using 1/4" washer 1.93mm thick, my spacing between the cowl and back plate of the spinner is 2.2mm. With my bat. placed against the wing tube my CG is at 160 from the leading edge, will test in flight to see if I can set my plane neutral with out adding weight. Also the skies are much heavier then the wheels so it will help wen I switch my gear. Here is a pic of where I put my ESC and BEC Pro.
Originally Posted by edf_rookie View Post
Thank you for sharing the photo. I am currently half way through building mine at the moment and am leaving the rudder till last to see whether I need to go push-pull or remain at pull-pull with the 5320 300kv and 2x4S 4000mah batteries.
What are you using between the wooden spacers and the firewall. I have currently set it up with just the wooden spacers but I only have around a 1mm gap between the spinner and cowl which I am not too comfortable with - unless told otherwise that it will be ok.
mdauth is offline Find More Posts by mdauth
Old Jan 24, 2013, 05:45 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
castle ice 100 directly under the batteries make we worried
3drcparts is offline Find More Posts by 3drcparts
Old Jan 24, 2013, 06:02 PM
mdauth is offline
mdauth's Avatar
Joined Sep 2010
The ESC is about about 1"1/2 in front of the batteries, I could push it on one side.
Old Jan 24, 2013, 07:02 PM
mdauth is offline
mdauth's Avatar
Joined Sep 2010
Ok, I past it on the side, after you brought it to my attention I think its better on the side, wasn't gaining that much anyways not worth taking a chance. Thanks.
Old Jan 24, 2013, 07:21 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
I feel much better after what happened to my ice100
Old Jan 24, 2013, 08:26 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Personally, I think better on the side or bottom of the motor box, for better cooling, and in the case there is a problem, less damage to the plane....but hey...that's just me....
SteveT.
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jan 24, 2013, 09:41 PM
Maxmannnn is offline
Find More Posts by Maxmannnn
Joined Jun 2006
After burning up a couple of escs I put the telemetry temp probe around mine instead of around the batts. Telemetry is da bomb. Now if i could figure out how to make my dx18 a little less excited during an alarm. Wow its loud... even w just the vibe.
Maxmannnn is offline Find More Posts by Maxmannnn
Old Jan 25, 2013, 07:46 AM
jsmith285 is offline
Find More Posts by jsmith285
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
Telemetry would be neat. Heat sensors on engines work well.
Just keep in mind usually when a ESC goes, it usually goes from normal temps to off the charts in less than a second.
jsmith285 is offline Find More Posts by jsmith285
Old Jan 25, 2013, 12:15 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Orange Wings
Anyone interested in two new wings with wing bags and wing tube?
The Fuse was crushed by something.......
But the wings were safe in their bags.
It was a brand new Slick, only had about 10 flights.
The wings are flawless and horns were installed cleanly with precision.
I have pics, the ad will be up this evening, just thought I would give you guys a heads up.
$115 shipped
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jan 25, 2013, 12:50 PM
3DNater is online now
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
that really sux johnnyrocco123. I have to ask what crushed it though...
3DNater is online now Find More Posts by 3DNater
Old Jan 25, 2013, 01:00 PM
Lardog is offline
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
Gravity
Lardog is offline Find More Posts by Lardog
Old Jan 25, 2013, 01:09 PM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
$115 shipped
Bummer, can we guess. But I didn't think you keep these much past 8-9 flights.
I had a deer fall on a plane once and crush, was loading it in the truck and the head flopped. Yep, would fly after the morning hunt.
robj is offline Find More Posts by robj
Old Jan 25, 2013, 01:30 PM
Dennis C is offline
Find More Posts by Dennis C
Dennis C's Avatar
Grass Valley California
Joined Jun 2004
Yes, being able to combine the batteries is definitely a good thing. Have you bought the Slick yet? If not...try the 74" Edge or 72" Extra....the A60-5S combo is killer is them. I just flew my 72" yesterday for the first time with the A60-5S in it, and it is very good in my opinion....
That said....If you don't mind a little bit of weight in the tail, you could probably put a one ounce or 1.5 ounce strip between the landing gear and the fuselage, and balance the 71".....and quite truthfully, unless you like really "light and floaty" you'll never notice it with this plane. I used a Hacker A60-5XS in my 70" Velox, and had to do that...and the plane still flies with a tremendous amount of power.
SteveT.
I have the 72 Extra, actually did the RC Groups review for Ben on it when it first came out. I love it and not sure why I want anything else. It is so preise and long slow rolls are easy peasy. incredible pop tops.
I do like a little more enegery in some of the manovers so a little extra weight is OK. friends have the 71 + DLE 30 much heavier and still great to fly.
Just a change I guess
Dennis
Dennis C is offline Find More Posts by Dennis C
Old Jan 25, 2013, 01:32 PM
SteveT.'s Avatar
San Jose, CA
$115 shipped
If it is an orange or red electric, 3DHS has the fuselages in stock on their website.... orange......red....
SteveT.
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
