Latest blog entry: Lil repair work.
Use your Watt meter and try 8s and then find a prop that gives you the power you want. You could stay at 6s but may have to go to prop so large that it has to much torque or to heavy for hard 3D Dennis |
Just as a matter or mentioning....I got another batch of carbon fiber in, and if anybody else wants some of the fuselage braces, I am going to make up another batch....
SteveT. |
Latest blog entry: My hangar...
I was doing some research trying to find out if anyone else has the same issues with there DLE and this guy had posted this back in 2009. Do you guys think this could be my issue???
Re: DLE 30cc engine by rcign » Tue Oct 27, 2009 1:59 am I guess the whole world now knows about the problem with the DLE30..The engine quits when tilted at idle...The fix is rounding off the square edges of the rear crankcase casting and rounding the internal corners...Gas pools in the corners and gets ingested killing the engine because of the extra fuel...Happens only at a slow idle....Can't take a picture, just go in there and look.... RC Ignition |
See my last post...
SteveT |
SteveT. |
Well, I wouldn't say I was "the one", but I took my power set-up (Hacker A60-6XS, 6S 65C 5000mAH Thunder Power packs, Castle ICE100 and BEC Pro) out of a 70" Slick that balanced perfectly with it, and put it in my 71" Slick, which yes, had to have the servo put in the tail to balance it.... A few others have commented their Slicks have coming out a bit nose heavy also.
SteveT. |
| Thread Tools | |
| Poll 3D hobby shop 51" slick or 55" SHP? | appleflyer | 3D Flying | 24 | Mar 24, 2009 06:29 PM |
| Video 3D Hobby Shop's AJ Slick | Clark Warfel | Electric Plane Talk | 3 | May 08, 2008 07:31 AM |
