Old Jan 19, 2013, 03:05 PM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
herzepkeith, what all do you have in the fuel line? Have an in-line filter by chance? Have you tried without it?
3DNater is offline Find More Posts by 3DNater
Old Jan 19, 2013, 03:08 PM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
Originally Posted by ronbo111 View Post
There is a break in period with any new gas engine , if you want to stay with gas I would use Lawnboy 30 to 1 mix for the DLE for the first 3 to 5 gallions and just fly the plane around with good airflow and tune as you go. This worked well for my DLE 55 and it runs great now.That said ,I seen alot of of pilots have trouble with the DLE 30
He has had this problem with two engines on this plane. He has had tuning help from seasoned gas guys. The problem is really weird and can be repeated at will just by rolling the plane over.
Old Jan 19, 2013, 03:32 PM
ronbo111 is offline
Find More Posts by ronbo111
lazy 3D specialist
ronbo111's Avatar
United States, OH, Canal Winchester
Joined May 2007
Ok ,if the seasoned gas guys cant help ,then yes go electric.
ronbo111 is offline Find More Posts by ronbo111
Old Jan 19, 2013, 03:37 PM
Capt. Roll is offline
Find More Posts by Capt. Roll
Capt. Roll's Avatar
United States, TX, Fort Worth
Joined Dec 2010
Have you pulled the plug after it dies? Is the plug soaking wet or on the dry side. If it's soaking wet there could be fuel pooling in the reed block assembly when inverted. Once you roll upright the fuel dumps into the mix and kills the engine. Is this something that is possible??
Capt. Roll is offline Find More Posts by Capt. Roll
Old Jan 19, 2013, 04:47 PM
hertzrepkeith is offline
Find More Posts by hertzrepkeith
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
I have checked all the above and show no signs of fuel loading up. I will check it again though.
QUOTE=Capt. Roll;23864255]Have you pulled the plug after it dies? Is the plug soaking wet or on the dry side. If it's soaking wet there could be fuel pooling in the reed block assembly when inverted. Once you roll upright the fuel dumps into the mix and kills the engine. Is this something that is possible??[/QUOTE]
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Jan 19, 2013, 04:50 PM
goflyhighrc is offline
Find More Posts by goflyhighrc
Just go with the flow
goflyhighrc's Avatar
Joined Nov 2006
That's kind of the consenus with a few of us at Keith's field, it's really wierd. If it's puddling inverted how do you eliminate it? It only takes maybe a 2-3 seconds inverted then set back uprighte it dies. The plug does not looked soaked or bad at all.
goflyhighrc is offline Find More Posts by goflyhighrc
Old Jan 19, 2013, 05:29 PM
Capt. Roll's Avatar
Joined Dec 2010
Wow........wish I could tell you what the fix was if that would be the problem.
Looking back through everything you've tried, you have an extensive list of what it's not; there's not much you haven't covered or tried. Can any of your flying buds loan you a Walbro carb to try? Maybe that's already been done.
Seems like it has to be something with the carb or fuel delivery through the carb and to the engine.
When inverted and you roll back to level upright it dies. What happens if you're inverted and you push to an upline or pull to a downline and fly that line for several seconds then return to level upright? Does it die?
Where is the pulse port hole on the carb/engine/reed block.....top, bottom or side?
Old Jan 19, 2013, 08:01 PM
GoldCraft is offline
Find More Posts by GoldCraft
GoldCraft's Avatar
United States, GA, Woodstock
Joined Jan 2007
Man thats a real tough one. Ive flown inverted and flipped back to upright hundreds of times with my DLE and never had it die. Its gotta be in the fuel delivery / vent line settup.
GoldCraft is offline Find More Posts by GoldCraft
Joined Jan 2012
Ok if I am inverted and push to a up line it will not die. When I am running the engine at higher RPMS and then flip it back over it does not die.(Only at lower RPM) I have never put the plane inverted and then pointed it towards the ground. I have tried 4 Different Carbs on this Motor. Tomorrow I am going to build a wood stand mount the motor on it with just Motor/Ignition/ and Fuel Tank and see if it still does it. If it does not I am going to start adding componets until it does do it. We will see what happens.
Old Jan 19, 2013, 08:17 PM
GoldCraft's Avatar
Joined Jan 2007
Sounds like a good plan of attack.....keep us posted
Old Jan 19, 2013, 08:22 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Stories like this make me glad mine is electric
losifanatic is offline Find More Posts by losifanatic
Old Jan 19, 2013, 08:48 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
yes and no, I had my 74 electric catch fire, But then again I see countless guys at our field toy and dicker with their gas motors, they get one flight for every 8-10 I get on electrics................and they complain about flight times for electric
but there is a couple of guys with gas that just get it right, first flip and it starts, 10-15 min per flight, refuel and fly again, never a problem, motor runs perfectly. I probably will go gas if I go bigger than 70"
3drcparts is offline Find More Posts by 3drcparts
Old Jan 19, 2013, 08:50 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by bryansifsof44 View Post
Thanks again Steve... Finally got around to installing them.
Attachment 5461973
Glad to see you got them in!!
And on that note.....has everybody except Smithder (whose braces I got back today due to an in-correct address), gotten theirs?
SteveT.
SteveT. is online now Find More Posts by SteveT.
Old Jan 19, 2013, 08:55 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
See... If I KNEW I could fly gas stress free and get those 10-15 minute flights I'd be ALL over it!!
turnerm is offline Find More Posts by turnerm
Old Jan 19, 2013, 08:59 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
it is the rare exception, but I might go with an os gt33 when/if I get bigfoot, that seems to be the ticket in that size, DLE seems ok in the 55 or bigger size
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
