Old Jan 18, 2013, 03:03 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
PJN is for electrics.
zmonster97 is offline Find More Posts by zmonster97
Old Jan 18, 2013, 08:36 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
Originally Posted by StevePortland View Post
Would you recommend the Xoar PJN or PJE. Local shop allways has the PJN and has been the default for wood props.
what he said. when in doubt, go to xoarintl.com
that is xoar's website and has all the descriptions and abbreviations. for electrics, stick to the PJN's and you will be happy
rcbirk21 is offline Find More Posts by rcbirk21
Old Jan 18, 2013, 09:19 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Working on a winter build of an AJ Slick 71. Great plane!! Just about got everything done, but still contemplating on a motor and prop. Any suggestions? Stick with the recommended Hacker A50-12L V2, or maybe an OS, etc. Was also thing of going with Xoar for the prop. What Im running so far is below:
4 x HiTech 7955-TGs
Castle Ice 100 ESC
Hyperion 6s 5000
Castle Ice BEC pro with Rx Pack (Thunder Power 2s 1350mAh 25C)
Spektrum AR7010 Rx
Spektrum TM1000
The Hacker A60-6XS is outstanding on 6S, and runs very cool. You can use a 20X10 or 21X10 Xoar, with no torque problems. You can run a Castle ICE 100 with no problems at all.
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jan 18, 2013, 11:26 PM
hertzrepkeith is offline
Find More Posts by hertzrepkeith
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
Ok guys I have no clue what to do! I am in complete disgust right now! I have a 71 AJ Slick (Orange Scheme) 7955 Servos/ Ultra Tech BEC/ Gen Ace 1500 2S for Servos Receiver and I have a DLE 30CC Motor. I have been having issues with motor when flying inverted and right when goes back up right. I sent the motor off after replacing Ignition, Carb, Bowman Ring, Reeds, Fuel Tank. Tower then sent me a Brand new motor. I took it out to the field for the first time today and guess what (**IT STILL IS DOING IT!!!!!!!!!) I am ready to just get rid of the thing. I know you guys are going to say (Get a OS motor!) But is it really the motor?? I don't know what the odds of that would be! Sorry for the novel I just don't know what to do anymore.
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Jan 18, 2013, 11:42 PM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
You have gremlins or something in that bird. Sorry to hear about you having so much trouble. I think the odds of having the same issue on two motors is close to zero. There has to be something else wrong somewhere... Could you possibly have an air leak in your fuel line or something? I know you have checked everything a zillion times by now... wish I could help.
3DNater is offline Find More Posts by 3DNater
Old Jan 18, 2013, 11:45 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
does sound like a fuel delivered problem.
Just convert to electric and sell brand new dle30
3drcparts is offline Find More Posts by 3drcparts
Old Jan 18, 2013, 11:48 PM
Joined Jan 2012
I am ready to just sell this garbage!! I love the plane just think I need to take a deep breath and strip everything out of it and start over. I am going to throw another new tank in it and put new fuel line in it again. I have already tried running a different battery straight to ignition, but I have another switch that i am going to just try to see what happens.** Atleast I have a New 74 Edge Electric to fly in the mean time!
Old Jan 18, 2013, 11:52 PM
sk8rob is offline
Find More Posts by sk8rob
3D Wanna Be
sk8rob's Avatar
Oahu, Hawaii
Joined Jul 2009
It might be a dumb question, but did you tune the engine before flying it?
sk8rob is offline Find More Posts by sk8rob
Old Jan 18, 2013, 11:55 PM
Joined Jan 2012
Yes I tuned the engine. I never even flew it. I was running the first tank of fuel on the ground. Engine is running great. Instantly right when I flip the plane over it dies instantly!
Old Jan 19, 2013, 01:48 PM
sk8rob is offline
3D Wanna Be
sk8rob's Avatar
Oahu, Hawaii
Joined Jul 2009
You flip it over while on the ground? It's possible that its starving for fuel. You may want to richen the low a smidgen.
Old Jan 19, 2013, 02:10 PM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Thanks again Steve... Finally got around to installing them.
Description:
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Jan 19, 2013, 02:20 PM
alfabeast is offline
Find More Posts by alfabeast
3D Addict
alfabeast's Avatar
Merrimac, MA
Joined Jan 2006
I went thru the same thing with a dle 20 and a 68-in velox. I sold the engine and went electric after one last dead stick. Electric is a simpler install too, no vibration, better throttle response, etc etc.
alfabeast is offline Find More Posts by alfabeast
Old Jan 19, 2013, 02:33 PM
Joined Jan 2012
Convert Electric
How hard is is to convert to Electric? What all do I have to change?? I had a guy PM this morning on a few things to try and I am going to give it a go. If it does not work I am really thinking of just going Electric if it will not cost me too much. Oh and too answer the other question. I have tried to Richen/ Lean it you name it and I have tried it. I would just get a OS if I knew that would solve my problem, but I am not too sure that is where it is at.
Old Jan 19, 2013, 02:50 PM
rcbirk21 is offline
rcbirk21's Avatar
Joined Aug 2004
you already have the packs for your 74 edge, correct? 6s5000 packs will work perfect in this airframe
Old Jan 19, 2013, 02:55 PM
ronbo111 is offline
Find More Posts by ronbo111
lazy 3D specialist
ronbo111's Avatar
United States, OH, Canal Winchester
Joined May 2007
There is a break in period with any new gas engine , if you want to stay with gas I would use Lawnboy 30 to 1 mix for the DLE for the first 3 to 5 gallions and just fly the plane around with good airflow and tune as you go. This worked well for my DLE 55 and it runs great now.That said ,I seen alot of of pilots have trouble with the DLE 30
ronbo111 is offline Find More Posts by ronbo111
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
