Old Jan 17, 2013, 05:48 PM
joesmith285 is offline
Find More Posts by joesmith285
Game on
joesmith285's Avatar
United States, IN, Fort Wayne
Joined Nov 2008
Originally Posted by bryansifsof44 View Post
Sure same would apply to servos as with our power systems. Increasing voltage without reducing load will greatly increase current (A). Which is why we have to prop down when going up in voltage without reducing KV. Where as no propping down for servos and load will likely go up with less chance of blowback at the higher voltage.
Agreed! Very good explanation.
joesmith285 is offline Find More Posts by joesmith285
Old Jan 18, 2013, 01:13 AM
edf_rookie is offline
Find More Posts by edf_rookie
edf_rookie's Avatar
Australia, QLD, Brisbane
Joined Mar 2011
Thanks everyone, greatly appreciate all your input.
edf_rookie is offline Find More Posts by edf_rookie
Old Jan 18, 2013, 10:31 AM
ellzy_21 is offline
Find More Posts by ellzy_21
United States, TX, Wichita Falls
Joined Nov 2011
Hey guys I'm going to be running a 6s setup (axi 5320 380kv) at about 4000 ft MSL and was originally thinking about the Xoar 20x8.....but I've heard guys generally have to "prop up" a bit the higher the elevation. Would I have to increase diameter or could I essentially increase pitch and run a 20x10 to get similar results? I'm just worried about going over 20" and not being able to counteract such a big prop in hovers Input greatly appreciated!
ellzy_21 is offline Find More Posts by ellzy_21
Old Jan 18, 2013, 11:03 AM
StevePortland is offline
Find More Posts by StevePortland
United States, OR, Tigard
Joined Jan 2013
Working on a winter build of an AJ Slick 71”. Great plane!! Just about got everything done, but still contemplating on a motor and prop. Any suggestions? Stick with the recommended Hacker A50-12L V2, or maybe an OS, etc. Was also thing of going with Xoar for the prop. What I’m running so far is below:
4 x HiTech 7955-TG’s
Castle Ice 100 ESC
Hyperion 6s 5000
Castle Ice BEC pro with Rx Pack (Thunder Power 2s 1350mAh 25C)
Spektrum AR7010 Rx
Spektrum TM1000
StevePortland is offline Find More Posts by StevePortland
Old Jan 18, 2013, 11:08 AM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
Castle Ice 100 ESC
Hyperion 6s 5000
Spektrum AR7010 Rx
Spektrum TM1000
on 6s there are really 4 main motors that everyone seems to be going with. a light setup would be something like the motrolfly 4325-380 (19x10 prop on 6s) or the hacker a50-12L (19x10 or 20x10 prop). for a heavier but a bit more powerful setup the two main motors are the motrolfly 4330 (or the 5320, but recent reviews of the 4330 are very positive) or the hacker a60-6xs. cant really go wrong with any of those setups, but on the 71 slick that is lighter and easier to balance, i highly recommend the lighter motors. the plane just flies awesome when it is kept light and either of those motors will provide more than ample power.
rcbirk21 is offline Find More Posts by rcbirk21
Old Jan 18, 2013, 11:16 AM
alfabeast is online now
Find More Posts by alfabeast
3D Addict
alfabeast's Avatar
Merrimac, MA
Joined Jan 2006
Working on a winter build of an AJ Slick 71. Great plane!! Just about got everything done, but still contemplating on a motor and prop. Any suggestions? Stick with the recommended Hacker A50-12L V2, or maybe an OS, etc. Was also thing of going with Xoar for the prop. What Im running so far is below:
4 x HiTech 7955-TGs
Castle Ice 100 ESC
Hyperion 6s 5000
Spektrum AR7010 Rx
Spektrum TM1000
You may want to ditch the redundant 2s rx pack. I can feel the difference on a few oz when I go from 6s5000 packs to 6s4000's. Using the a50-12L and run xoar 20x10, 19x10 if hot out. Good pullout but not ballistic. Hovers and harriers are super easy at this weight. If you fly in hot climate you may want the bigger engine to manage temps. I usually have to wait about 10 minutes between flights with the a50 if it is warmer than 65 -70 degrees out.
alfabeast is online now Find More Posts by alfabeast
Old Jan 18, 2013, 11:29 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
You may be happy with the 20x8 prop at that kv. But if not I wouldnt be scared to go 20x10 either.
Manta1 is offline Find More Posts by Manta1
Old Jan 18, 2013, 11:48 AM
Joined Jan 2013
Thanks for the recommendation
Old Jan 18, 2013, 11:54 AM
Joined Jan 2013
Thanks, I will keep that in mind.
Old Jan 18, 2013, 12:03 PM
TimmyC is offline
Find More Posts by TimmyC
United States, MI, Allegan
Joined Aug 2012
How long can you fly and how many amps are you pulling on the 6s4000s?
TimmyC is offline Find More Posts by TimmyC
Old Jan 18, 2013, 02:13 PM
collinss is offline
Find More Posts by collinss
United States, FL, Winter Springs
Joined Sep 2010
I'm in the same situation trying to find the perfect 6S setup for my 74" Edge. I have been thinking of the motrolfly 4330 however I think you can run a larger prop on the hacker A60. However, I hear that the motrolfly runs cooler than the hacker.
collinss is offline Find More Posts by collinss
Old Jan 18, 2013, 02:26 PM
3DNater is online now
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
So get the motrofly wound to a little lower kv to run the prop you want
3DNater is online now Find More Posts by 3DNater
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
The 4330 can run just as big of a prop because of the rear bearing. Just get it wound to what ever kv works for the prop you want to use. The 4330 is an awesome motor.
losifanatic is offline Find More Posts by losifanatic
Old Jan 18, 2013, 02:34 PM
ellzy_21 is offline
Joined Nov 2011
Awesome thanks. Maybe I'll just get a few of each and see what feels best.
Old Jan 18, 2013, 03:00 PM
Joined Jan 2013
Would you recommend the Xoar PJN or PJE. Local shop allways has the PJN and has been the default for wood props.
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
