Old Dec 30, 2012, 01:50 AM
ellzy_21 is offline
Find More Posts by ellzy_21
United States, TX, Wichita Falls
Joined Nov 2011
Electric... I'm a little worried about the setup though.. I've already got the motor, esc, and batts for a 6s setup but I think it might be a bit on the heavy side?
This is what I've got:
AXI 5320/18 380kv (at 494g.)
CC ICE 100
CC Bec PRO
Gens Ace 30c 6s 5300 (750g.)
Xoar 20x8
and I'd like to run the HS-7985s in it. I've been cross checking the EF 70" Extra 300 forum and this motor/esc/prop setup is supposed to give solid power for THAT airframe, but 6s setups are supposed to be light and I'm not sure if I've defeated the purpose with this?? I'd love to use the stuff I've already got if I can...
ellzy_21 is offline Find More Posts by ellzy_21
Old Dec 30, 2012, 02:10 AM
bryansifsof44 is online now
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Looks like the setup will work only thing I would change is the prop adapter... Do they have a option for a bolt on adapter? Should produce plenty of power and AXI makes a good quality motor. Plane does awesome with the heavier setup. I've 3Ded 1070g of battery with my motor that weighs about what yours does... Not ideal but it did fine.
bryansifsof44 is online now Find More Posts by bryansifsof44
Old Dec 30, 2012, 02:42 AM
ellzy_21 is offline
Joined Nov 2011
That's reassuring, thanks. Someone mentioned getting this for the AXI...
http://www.hobby-lobby.com/propadap....ueryId=4102957
Is that what you're talking about? Should take it down from a 12mm to 8mm shaft
Old Dec 30, 2012, 03:17 AM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
I mentioned that.... I think Bryan was thinking the motor uses a collet type prop adapter, (which it can), but not used in this instance....
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Dec 30, 2012, 04:06 AM
cookci is offline
Find More Posts by cookci
Joined Jul 2011
CC ICE 100
CC Bec PRO
Xoar 20x8
Looks like the perfect 6 cell setup if you ask me.
cookci is offline Find More Posts by cookci
Old Dec 30, 2012, 04:34 AM
Joined Oct 2011
SteveT
The picture that in saw of the motor showed the collet style, not the bolt on prop adapter.
Ellzy... That is what I was talking about. Does the motor come with a X mount or do you need to buy that separately too.
Old Dec 30, 2012, 12:29 PM
ldhflyguy is online now
Find More Posts by ldhflyguy
FlyGuy
ldhflyguy's Avatar
Batavia, IL, USA
Joined Oct 2007
I suggest you go ahead and use what you've got, especially if it's already used and not returnable. If you don't like the setup, after maybe trying a different prop or two, upgrading to a different motor should be easy. I have the same setup as you have listed, except I have the Hacker A60 and had the A50 12L and thought those were both fine for my flying style, although the A60 with an APC 20x13 is a bit faster.
ldhflyguy is online now Find More Posts by ldhflyguy
Old Dec 30, 2012, 08:20 PM
SteveT.'s Avatar
San Jose, CA
In talking on the phone to one of our more aggressive fliers (who shall go un-named), he mentioned that he has torn the sides out of his 71" Slick a few times, due to where the wing bolt goes through not being very strong. So in an effort to possibly prevent this from happening on my plane, I made up some braces to brace this area....here is what I did....
The length is 4.5" the width 1.75. There is a piece of 1/32" ply to make up for the difference in thickness at the top, which is 1/4" from top to bottom. The hole .3125" and is 1.6875" down from the top, and centered on the width.
SteveT
Old Dec 30, 2012, 08:34 PM
rctc is offline
Find More Posts by rctc
RCTC
USA, MI, Traverse City
Joined Feb 2005
That looks like great setup. I flew that Axi in a 3dhs 72" extra on a 6 cell TP 5000 pack.
Plenty of vertical. I flew that combo for 2 months until a friend talked me out of the plane for his DLE 30 gas motor. You wil be very happy with the Axi 5320-18 in the slick.
rctc is offline Find More Posts by rctc
Old Dec 30, 2012, 08:40 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Wow Steve that's awesome!!!!! l am going to copy that if you don't mind. We have 3 71 slicks at our field right now that could use that.
losifanatic is offline Find More Posts by losifanatic
Old Dec 30, 2012, 09:15 PM
Joined Oct 2011
Have you had issues with that area to losi?
Old Dec 30, 2012, 09:47 PM
Sippin the Koolaid!
Joined Oct 2007
I know of 5 71 slicks that have had issues with that including mine. So l am very very happy to see that.
Old Dec 30, 2012, 09:58 PM
Joined Oct 2011
I guess I better do the same... not that I fly hard enough to bust it but better to be safe then sorry.
Old Dec 30, 2012, 10:05 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
Steve, you selling those? Might need some.
zmonster97 is offline Find More Posts by zmonster97
Old Dec 30, 2012, 10:15 PM
SteveT.'s Avatar
San Jose, CA
In retrospect, I wish I had done them a bit different, and may redo them,(just because I'm a bit picky about some things), but they will certainly work like that...
SteveT
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 07:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 08:31 AM
