Old Dec 17, 2012, 01:38 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by goflyhighrc View Post
About 8 rows up from the bottom of the 1st page of of the attachments for the 70 thread there is a pic of a pilot fiqure in the 70, would anyone know what size that would be and where I may find one. Great looking pilot and it fits great.
http://static.rcgroups.net/forums/at...G?d=1255314109
Probably this one from Horizon/Hangar 9..
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Dec 17, 2012, 01:59 PM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
Heading out to fly my 70" gasser
3DNater is offline Find More Posts by 3DNater
Old Dec 17, 2012, 02:05 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Ok guys much happier. Got the props in today. 7580 rpms with a 20x8 and 7510 with a 19x10. Also my motor temps went down. I ran the packs down in under 5 minutes to only 7% left in the and the motor was only 110 degrees. I was on that left stick too . Getting ready to check amp draw now.
losifanatic is offline Find More Posts by losifanatic
Old Dec 17, 2012, 02:07 PM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
What prop were you using and what do you have now? 7% of 80% or 7% in the whole pack?
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Dec 17, 2012, 02:11 PM
Sippin the Koolaid!
Joined Oct 2007
Running the 20x8 and yeah only 7% in the whole pack left in under 5 minutes
Old Dec 17, 2012, 02:15 PM
Joined Oct 2011
Wood, plastic, or Carbon? Wooh, when I run 3D with 12s 2600, I get 6-6.5 min. Even with mostly WOT flying around I get 5 min. 20x8 prop. I know you run pretty hard, but man that's not good flight time at all.
Old Dec 17, 2012, 03:14 PM
goflyhighrc is offline
Find More Posts by goflyhighrc
Just go with the flow
goflyhighrc's Avatar
Joined Nov 2006
SteveT
I think it's the right pilot but maybe the 25-28% size which is 4 3/8 tall vs, the33% which is 5 1/16 tall, what do you think?
goflyhighrc is offline Find More Posts by goflyhighrc
Old Dec 17, 2012, 03:47 PM
Sippin the Koolaid!
Joined Oct 2007
Wooden prop. Oh with the 20x8 xoar l am only pulling 2746 watts peak. Apparently the 4330 doesn't like a heavy cf prop as l am pulling less wattage with a wooden 20x8. I have a xoar 19x8 to test out later this week too.
Old Dec 17, 2012, 04:20 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
Yeah, I believe it's the 25-28% one.
zmonster97 is offline Find More Posts by zmonster97
Old Dec 17, 2012, 04:33 PM
Joined Oct 2011
With my 112 gram apc I got more RPM and more wattage then my 61g xoar... Spool up was noticeably slower though.
Old Dec 17, 2012, 04:57 PM
wamsy55 is offline
Find More Posts by wamsy55
Fly Low
wamsy55's Avatar
Nashville , Tennessee
Joined Jan 2009
The main problem with an APC propeller is that it flexes more than a xoar so while you may get more RPM with an APC prop you will lose power overall, IMO. This is much more apparent with larger props with diameters over 15".
wamsy55 is offline Find More Posts by wamsy55
Old Dec 17, 2012, 06:02 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Yeah...I would think the 25-28" Size...but I have never measured the canopy height/width...
SteveT
Old Dec 17, 2012, 06:04 PM
zmonster97's Avatar
Joined May 2011
Well the 71" slick is 25% so the 25-28% pilot would be the one.
Old Dec 17, 2012, 06:08 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Funny thing....I was talking to Mike Donovan at Aero-Model on Friday about props, as I was considering changing out the Xoar 20X10 PJT gas prop for a lighter Mejzlik or Falcon prop. One thing he told me was to be careful doing hard 3D, I.E. Blenders, Knife edge spins etc, with the lighter carbon props are they are not designed for 3D, but rather for pattern flying. He says he has seen the lighter Mejzlik props break in mid-air, when used for 3D. That would be scary, as throwing a blade at full throttle would, I am sure destroy a plane before you could even get off of the throttle....
SteveT
Joined Oct 2011
And maybe that's where the extra 65 RPMs came from... IMO it wouldn't effect performance to much unless I was seeing significantly less amps/watts which were more. The real deal breaker for me was spool up time of the APC. So I think flexing has some effect but nothing too significant... however, the weight of the prop is what does it in at least for me.
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
