Old Dec 14, 2012, 11:43 AM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
Originally Posted by Inverted-I-Fly View Post
I just ordered the 4325-380, hope I made the right decision, this is what Ken recommended to me
"For 6s and the Slick most use the 4325-380 and a 19x10 and very happy with it.
You could go to the 4330-400 and the same prop, amps may breach 100 so a 120 amp would be needed.
5320 would be too much I think.
Ken"
you wont be dissapointed. had a hover drag race with a hacker a60-6xs and outpulled it every time on my 4325-380 on 6s.
rcbirk21 is offline Find More Posts by rcbirk21
Old Dec 14, 2012, 11:55 AM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
Originally Posted by hone1er View Post
I have a 4330-435 on 6s with a 19x8 so when you get the Slick ready we can fly together sometime to compare.
that sounds like a plan
3drcparts is offline Find More Posts by 3drcparts
Old Dec 14, 2012, 12:31 PM
ryan_m is online now
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
Don't do it... the 4330-435 is awesome. I've had them on two different slicks and love that motor...it will make you want one! I have mine turning an 18x10 and absolutely love all the speed it gives me on my Slick.
ryan_m is online now Find More Posts by ryan_m
Old Dec 14, 2012, 12:43 PM
smithder is offline
Find More Posts by smithder
smithder's Avatar
USA, TX, Pearland
Joined Mar 2005
Anyone else running the 5320-300 on 8S? I'm going to be building my Slick and wondering what props to go with. (I plan to try 19x8 and 19x10)
Will the rudder servo still be mounted in the front with the bigger motor or should I plan to move it to the tail? I have the lighter X mount so I think the weight is about the same as the 4330.
smithder is offline Find More Posts by smithder
Old Dec 14, 2012, 01:43 PM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
With the 4330 and my and rudder servo in the tail my batteries are hereName: ImageUploadedByTapatalk1355514208.359078.jpg
Description:
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Dec 14, 2012, 01:51 PM
smithder is offline
smithder's Avatar
USA, TX, Pearland
Joined Mar 2005
Cool. I like that better than pull pull. What's the black thing your pack it plugged into?
Old Dec 14, 2012, 02:24 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by bryansifsof44 View Post
With the 4330 and my and rudder servo in the tail my batteries are hereAttachment 5372358
Yup...that's about where mine are...
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Dec 14, 2012, 03:12 PM
Joined Oct 2011
It's my series connector... I'm running 12s
Old Dec 14, 2012, 03:18 PM
smithder is offline
smithder's Avatar
USA, TX, Pearland
Joined Mar 2005
I was going to ask what people are using for 8s. I saw some connectors from MPI that were two Deans in and one Deans out that looked like it would work. Very compact.
http://www.gravesrc.com/MAXX_PRODUCT..._p/max7952.htm
Old Dec 14, 2012, 04:58 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Those are designed for 2X2S packs, I don't know if I would trust them for 3S or 4S, especially if they are larger packs, and you are drawing much amperage. The only way I would even think of using one is to first take the heat shrink covering off and see what they used to join them. I would bet it is nothing larger than 14 gauge wire. MPI MAXX also makes a series wiring harness, but again, they use 14 gauge wire, so, I just make my own using a minimum or 10 gauge wire. The one in the picture was made for a small EDF, so is only 12 gauge wire...but you get the picture I'm sure...
(and yes, each individual wire has has the appropriate black or red heat shrink over it.. )
SteveT
Old Dec 14, 2012, 04:59 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Who makes that, it looks interesting....
SteveT
Old Dec 14, 2012, 05:26 PM
smithder is offline
smithder's Avatar
USA, TX, Pearland
Joined Mar 2005
I called Max products and they said the deans connectors are welded together. They use a buss bar to connect the tabs that aren't touching. He said its rated to as many amps as the deans can handle. The 2S is for two packs not cells. They also make one for 3S or three packs.
I'd like to see inside but it sounds better than wires to me.
Old Dec 14, 2012, 05:31 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
For paralleling I just solder 2 connectors straight to my esc that way l have one less fail point
losifanatic is offline Find More Posts by losifanatic
Old Dec 14, 2012, 05:54 PM
Joined Oct 2011
SteveT
It's a Align helicopter series connector found here: http://www.readyheli.com/HEP00001-Al...r_p_37305.html
Old Dec 14, 2012, 06:44 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Interesting...Thank you!!
SteveT
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
