Old Dec 13, 2012, 01:34 PM
Park_aviator is offline
Find More Posts by Park_aviator
3D, 1D at a time!
Park_aviator's Avatar
United States, TX, Plano
Joined Aug 2010
Originally Posted by jsmith285 View Post
Someone needs to say without pictures it didn't happen
Originally Posted by hertzrepkeith View Post
There is a GOD!! So I called goflyhighrc (Doug) and told him I was ready to throw my 71 Slick in a ditch because I had(Thought) tried everything you can think..Bowman Rings,Reeds, 3 Gas Tanks, New Carb, New Ignition, Different Kill Switch and it was still dieing at lower RPMS when I would flip it from inverted to normal. So he told me to not throw it in the ditch but to throw it in his YARD! LOL(SO I DID!!!) Less then 24 HRS later I get a text saying "ITS FIXED" He took the ignition and flipped it 180 Degrees and it solved the issue! We are not sure why, but it did! I am more then happy and sometimes it shows it is nice to have friends that can look at your plane with a fresh set of eyes!!! I would say I owe him Something Thanks again Doug!
Without pictures it didn't happen!
Park_aviator is offline Find More Posts by Park_aviator
Old Dec 13, 2012, 05:06 PM
goflyhighrc is offline
Find More Posts by goflyhighrc
Just go with the flow
goflyhighrc's Avatar
Joined Nov 2006
Here today gone tomorrow
Had it working perfectly, would flip it inverted hold for awhile back upright ran like a charm, did this a dozen times or better. Kieth came to pick it up, bammo, same cp, flip it inverted roll it back it would die. Had the rpm's up to around 2300 and it would die after holding it inverted for app.45 seconds then flipping it back.
goflyhighrc is offline Find More Posts by goflyhighrc
Old Dec 13, 2012, 05:21 PM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Looks like there's a devil too... Hope you get it fixed.
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Dec 13, 2012, 06:44 PM
3DNater is online now
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
Is there some component close enough to the ignition to interfere with it somehow? Maybe try moving stuff around a bit... that is so freaking weird. I felt like that fix was way too weird to last
3DNater is online now Find More Posts by 3DNater
Old Dec 13, 2012, 06:47 PM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
My guess would still be something inside the carb. just a guess.
robj is offline Find More Posts by robj
Old Dec 13, 2012, 07:50 PM
Joined Nov 2006
Like I said I tried it a dozen or so times, idled it way down and it would not shut off. Got up this morning secured all the wires including the ignition wire, back to it's old tricks. You'd think if there was something interfering it would not matter what orientation the plane was.
Old Dec 13, 2012, 08:28 PM
Joined Nov 2006
He cleaned is original carb, then got a new one, no help.
Old Dec 13, 2012, 08:36 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
Convert it to electric
3drcparts is offline Find More Posts by 3drcparts
Old Dec 13, 2012, 08:47 PM
AeroKen is online now
Find More Posts by AeroKen
3D? I only got two thumbs!
United States, MA
Joined Jul 2012
So if you un-secure the wires does it start working again?
AeroKen is online now Find More Posts by AeroKen
Old Dec 13, 2012, 09:25 PM
Lomchevac is offline
Find More Posts by Lomchevac
AKA Boomhauer
Lomchevac's Avatar
Arkansas
Joined May 2008
Possibly could be a connector issue
Lomchevac is offline Find More Posts by Lomchevac
Old Dec 13, 2012, 09:26 PM
ROLLING CIRCLE is offline
Find More Posts by ROLLING CIRCLE
TEAM TWISTED
ROLLING CIRCLE's Avatar
United States, MD, Middle River
Joined Dec 2011
Just a couple thoughts and sorry if these have been suggested in the past:
1. Be sure the hole in the reed valve absolutely lined up with the hole on the motor and carb. The plane won't run right and will do strange stuff in the mid and upper throttle range if the hole for pumping fuel is not going all the way through to the motor unobstructed.
2. Does the braided ground wire to the plug move around inside the cowl very much? When inverted, could the braided wire to the plug possibly be hitting another wire, like the ignition power wire, and grounding the power out when the plane is moving and the wire sags towards the top of the plane?
ROLLING CIRCLE is offline Find More Posts by ROLLING CIRCLE
Old Dec 13, 2012, 09:29 PM
hertzrepkeith is offline
Find More Posts by hertzrepkeith
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
I Think it is ME
Anyone up for a trade!!!!!!!
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Dec 13, 2012, 10:01 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Sure!! Name: ImageUploadedByTapatalk1355457712.036567.jpg
Description:
turnerm is offline Find More Posts by turnerm
Old Dec 13, 2012, 10:04 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
Lol
Old Dec 13, 2012, 10:51 PM
Joined Nov 2006
Tried that, no help. From inverted as you start to rotate it back to level at just about the knife edge positiion it starts to die, tilt it back towards inverted keeps running, go to level dies.
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
