Old Dec 03, 2012, 01:34 AM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
sorry, no, but I can tell you that they are very fast, and very strong.... As noted, I have them in my 89" Slick, and also in my 74" Edge....and they really seem to make a difference over the HS-985's in my 71" Slick....
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Dec 03, 2012, 01:40 AM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
SteveT
Totally... my flying partner has the 985s and there is night and day difference with my 7954s. We compared them side by side and my roll rate is twice his at high speed.
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Dec 03, 2012, 01:58 AM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Originally Posted by bryansifsof44 View Post
Not disagreeing... correcting me. I don't know this, good to know. Do you know the specs on 7.4v?
I run my 7954s on 8.0v regulated are they acceptable at that voltage?
I would guess so, as the "freshly charged" voltage of a 2S pack is around 8.2 volts..
SteveT
Old Dec 03, 2012, 02:43 AM
edf_rookie is offline
Find More Posts by edf_rookie
edf_rookie's Avatar
Australia, QLD, Brisbane
Joined Mar 2011
Originally Posted by turnerm View Post
Well... Lost signal today. Completely.
Devastated. Attachment 5344160
Just catching up on the days posts.
Michael, that is depressing to see. It really sucks especially if it was no fault of your own. And just after just losing the 57" Extra too.
Hopefully when you look at them in a day or two you will be able to repair them both and get them back in the air soon. I know what a great time you were having flying them both around.
edf_rookie is offline Find More Posts by edf_rookie
Old Dec 03, 2012, 04:07 AM
bss_rcg is offline
Find More Posts by bss_rcg
India
Joined May 2009
Originally Posted by bss_rcg View Post
Finally have the slick in my hands. Did few flights yesterday. Maiden went relatively unenventful. Awesome plane . On my third flight broke all the three elevator hinges of one side. Not sure how. May be control rod was binding. Drilled all the six hinges out and put the bigger ones. 3 more good flights today. All on low throws
My setup is A60-6XS on 6S-30C, CC 100ICE, and BEC Pro. 20x10XOAR.
From the logged data 104 amps peak, 2400+ watts peak. After 6 min of moderate flight pumped in around 2600mah back into battery.
ESC was more than warm however motor was quite hot (I have opening at the bottom of fuse for air out). Not much hovering. I think I'm pulling too much amps. I'd like amps to be <=100 at wot. I don't think this setup will survive summers in India.
How good 20x8 APC or XOAR will be on this in terms of pulling lesser amps so that I'm easy on motor and ESC?
Will 20x10 APC draw lesser amps than XOAR? I have few spare APCs.
I'm very happy with the plane... need some more flight time
Thanks.
Any opinion on 20x8 APC on A60-6XS? Also, the recommended switching Frequency for motor is 8kHz, currently my ESC switching is set to "outrunner". Will changing this help in lower amp draw?
Thanks.
bss_rcg is offline Find More Posts by bss_rcg
Old Dec 03, 2012, 08:04 AM
ldhflyguy is online now
Find More Posts by ldhflyguy
FlyGuy
ldhflyguy's Avatar
Batavia, IL, USA
Joined Oct 2007
Originally Posted by hertzrepkeith View Post
Ok I am out of options!!! Here is a video of my DLE 30CC With a Brand New Carb and with the Bowman Ring & Reeds done. Does anyone have any ideas or opions on what I should do at this point. Please let me know.http://www.youtube.com/watch?v=T6fIsd-ZI5U
How about, the idle needle is too rich and when the plane is inverted the carb or crank case loads up? When you go upright the fuel dumps in and floods the engine.
ldhflyguy is online now Find More Posts by ldhflyguy
Old Dec 03, 2012, 09:18 AM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
i cant remember where i saw it, but i do recall seeing the same specs for the 7954SH for the 7955TG on 7.4v. Like I said, basically the same servo except for the gear train, the titanium in the 7955TG being fantastic and ive never had a problem in the over dozen 7955's i have owned
rcbirk21 is offline Find More Posts by rcbirk21
Old Dec 03, 2012, 09:21 AM
Flyer95 is offline
Find More Posts by Flyer95
Sweden, ┼kersberga
Joined Aug 2012
Thanks.
In a 3D plane the motorspeed is changing all the time. APCe is slightly heavy and weak so not the best option for that. They are better for pattern planes.
Wooden Xoar 20x10 or 21x10 seem to be the prop. most people use with the A60-6XS on 6s lipo.
Flyer95 is offline Find More Posts by Flyer95
Old Dec 03, 2012, 01:04 PM
smithder is offline
Find More Posts by smithder
smithder's Avatar
USA, TX, Pearland
Joined Mar 2005
Would the Hacker A50-12L be ok on 8S?
http://www.rcgroups.com/forums/showt...ghlight=hacker
How much performance would I be loosing over the Morolfly?
Thanks!
smithder is offline Find More Posts by smithder
Old Dec 03, 2012, 01:08 PM
DaaBears is offline
Find More Posts by DaaBears
Santi
DaaBears's Avatar
United States, MO, Clayton
Joined Nov 2003
Thanks!
Not a very efficient motor on 8s, better for the 6s guys. Motrofly has much better 8s options with significantly more power and longer flight times..
DaaBears is offline Find More Posts by DaaBears
Old Dec 03, 2012, 01:10 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Originally Posted by ucdme3d View Post
not a very efficient motor on 8s, better for the 6s guys. Motrofly has much better 8s options with significantly more power and longer flight times..
+1!
losifanatic is offline Find More Posts by losifanatic
Old Dec 03, 2012, 01:30 PM
smithder is offline
smithder's Avatar
USA, TX, Pearland
Joined Mar 2005
Sounds like I need a Motrofly...
Anyone happen to have one they need to sell? I'm want to build this bird right, but man it gets pricey!
Old Dec 03, 2012, 01:56 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Thanks.
Not enough prop to load the motor properly...
And here are the settings that "The Smith" (I.E. Joe Smith) uses for his A60-6XS...
Fixed Endpoints
Throttle response Custom 10
Cut off- Auto Lipo 3.2v/cell
Current Limiting- Disabled
Soft Cutoff
Start Power- High (100)
Motor timing- Low
PWM- 12khz
Firmware- 3.27
SteveT
Old Dec 03, 2012, 01:59 PM
Sippin the Koolaid!
Joined Oct 2007
I have a 3 week old 5320 300kv lightened version. Make an offer if your serious
Old Dec 03, 2012, 02:01 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
What??? Losi selling a Motrolfly?? Can it be???
SteveT
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
