Old Nov 29, 2012, 12:02 AM
DenverJayhawk is offline
Find More Posts by DenverJayhawk
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
lots of good batts. Many use 4s 4000s from Gens Ace, Sky, and Glacier. I'm using Gens in my 74" Edge and 57sc. Also used them in my departed 71 Slick.
DenverJayhawk is offline Find More Posts by DenverJayhawk
Old Nov 29, 2012, 12:05 AM
smithder is offline
Find More Posts by smithder
smithder's Avatar
USA, TX, Pearland
Joined Mar 2005
Are the Gens 25C up to it? My nanotechs are 45-90c but 25c is all I find for the gens.
smithder is offline Find More Posts by smithder
Old Nov 29, 2012, 12:28 AM
Epoxy & CA Investor
Joined May 2010
i'm using 25c Gens in my 74 and 57. They work fine. Watt tested to 2300 watts in the 71"/74" and 1325 watts in the 57sc.
Old Nov 29, 2012, 12:57 AM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
I run 4S 45C 4000mAH Zippy Flightmax packs in mine, and have no problem at all with them,,,
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Nov 29, 2012, 07:04 AM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Im running the gen ace 25c 4ks up to 3000watts and they handle it just fine. Mine are even 2 years old. I also have new 60c gen ace 4ks and yes there is a power difference but its not huge. Those 25cs are great.
losifanatic is offline Find More Posts by losifanatic
Old Nov 29, 2012, 07:28 AM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
Does anyone have any insight as to when the gas 71 will be in stock again?
chop stiX is offline Find More Posts by chop stiX
Old Nov 29, 2012, 08:42 AM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Gens Ace 25c 4000's here and they work great. I use them in an 8s setup on this plane and 4s setup in my 57" SC and couldn't be happier.
turnerm is offline Find More Posts by turnerm
Old Nov 29, 2012, 09:23 AM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
My guess would be mid to end of december.
going4speed is offline Find More Posts by going4speed
Old Nov 29, 2012, 10:55 AM
hertzrepkeith is offline
Find More Posts by hertzrepkeith
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
Does anyone have a 20x6 Xoar Prop that they are interested in getting rid of that is cut for a DLE Motor? Or does anyone know where I can get one? They seem to be out of stock wherever I look.
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Nov 29, 2012, 06:26 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
Originally Posted by bryansifsof44 View Post
Awesome motor... what KV and cell count you running?
With my 4330, I was able to put my rudder servo in the tail like I wanted with the front of my two 6s2600's batteries at the front support for neutral balance.
I will be getting the 400kv and use it with 6s on a 19x10 prop.
zmonster97 is offline Find More Posts by zmonster97
Old Nov 29, 2012, 10:35 PM
ROLLING CIRCLE is offline
Find More Posts by ROLLING CIRCLE
TEAM TWISTED
ROLLING CIRCLE's Avatar
United States, MD, Middle River
Joined Dec 2011
Just got some of these connectors on the batts and the speed control on the 70" slick and no spark on connections whatsoever. Awesome. Saw a post a few pages back about spark arresting and thought to mention it since everyone is talking about electric setups. We are flying 2 x 4S 5000Mah 50C/100C Flight Power batts in the 70" Slick now. Motro 4325, Xoar 18x8 Castle Ice 100, Savox 1268s all around, Orion life batt on receiver/servo power... Anyways, these connectors are pretty cool. You put a silicon tube with 5/16ths i.d. over the negative side on the batts and you have an added safety factor of no arc between sides being possible during transport or flight.
http://www.espritmodel.com/jeti-afc-...mm-150a-1.aspx
ROLLING CIRCLE is offline Find More Posts by ROLLING CIRCLE
Latest blog entry: Joe nall 2016 - epic vid
Old Nov 29, 2012, 10:54 PM
SteveT.'s Avatar
San Jose, CA
Already tried them, but I didn't like them as I like to put the male bullet on the black/negative wire, and the female bullet on the red/positive wires of the batteries. If I wanted to use these, I would have to put one on every battery I use with bullet connectors....too many...
Also....if you get the connector too hot while soldering the wire, the solder holding the resistors will melt, so, you have to make sure to use a heat sink when soldering them...
Of course, this is just my opinion... YMMV...
SteveT
Old Nov 30, 2012, 02:12 AM
Neil_SC is offline
Find More Posts by Neil_SC
Joined May 2004
Since the resistor is inline with the main battery leads, how does this not increase the resistance while the motor is running? I'm not familiar with an 'SMD' resistor.
Neil_SC is offline Find More Posts by Neil_SC
Old Nov 30, 2012, 02:50 AM
SteveT.'s Avatar
San Jose, CA
It's how these things are made.....there are actually two pieces separated by a piece of circuit board, but connected by the resistors. There is an outer ring that makes contact first to charge the capacitors, then as the bullet connector is shoved in father, it make contact with the main body or the female connector completing the circuit without the resistors. It has nothing to do with the type of resistor.
SteveT
Old Nov 30, 2012, 05:57 AM
Capt. Roll is offline
Find More Posts by Capt. Roll
Capt. Roll's Avatar
United States, TX, Fort Worth
Joined Dec 2010
I thought I read somewhere that the spark was actually a good thing as it indicates that the capacitors on your ESC are still working correctly. Any EE's among us that can confirm/dispute this?
For $43, I'll just change my EC5 connectors once a year......they seem to get sloppy over time anyhow............maybe that is the spark causing an issue?
Capt. Roll is offline Find More Posts by Capt. Roll
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
