Old Nov 24, 2012, 12:52 AM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
I definitely love my 74" on 8S....and I am going to take the brand new A50-14L that has never even been flown out out of my 72" Extra, and replace it with the Hacker A60-5S, like the one in my 74"....so, I am going to sell it if anybody is interested...
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Nov 24, 2012, 01:24 AM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Maidened my slick today and got 3 flights... awesome power and definitely a sweet flyer. The 12s setup pulled the plane around nicely. Took it fairly easy. Torque rolls and hovers are very predictable, inverted harriers are sooooo stable, and KE took 7% up elevator and 4% aileron mix for locked in feel. Pretty happy as this is the biggest plane I have flown. My flying partner just maidened his slick with a 4325-380 with a 18x10 (needs to prop up) today also, and it seamed sluggish compared to mine. I really want to try a 20x8.
Setup:
Motor: DM 4330-216
ESC: Ice 80HV
Prop: Xoar 19x8PJN
BEC: Castle Pro set to 8.0 volts
Servos: HS-7954sh
Batteries: Glacer Lipo 6s 2600mAh
Here is a screen shot of a static test on the Castle logging software
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Nov 24, 2012, 10:09 AM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Just had a blast with my Slick again this morning. That plane can really handle some serious wind. It started blowing up around 10mph and the plane just didn't notice the wind at all. I'm starting to get really comfortable with it.
turnerm is offline Find More Posts by turnerm
Old Nov 24, 2012, 10:10 AM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Setup:
Motor: DM 4330-216
ESC: Ice 80HV
Prop: Xoar 19x8PJN
Servos: HS-7954sh
Very nice! Glad you got your maiden done. This plane just keeps getting better and better for me.
Old Nov 24, 2012, 07:02 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Setup:
Motor: DM 4330-216
ESC: Ice 80HV
Prop: Xoar 19x8PJN
Servos: HS-7954sh
2700 watts? wow thats got to be sick on that plane.
Congrats!
Manta1 is offline Find More Posts by Manta1
Old Nov 24, 2012, 09:04 PM
Joined Oct 2011
Congrats!
Just got 3 more flights today... Coming from a 1700 watt 60" EXP... 2700 watts suited me well. How much diff in output do you guys think the 20x8 would have? I tend to like the bigger disk on planes... Around 29% of the wingspan is what I shoot for given I have the clearance... With the slick there is plenty. But I do like the 19x8 too.
Old Nov 24, 2012, 09:13 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
I have 20x8 on my 71
I also have different kv than you and on the 4325.8s
Old Nov 24, 2012, 09:39 PM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
I ran a 20x8 protek on my gasser... sweet prop!
3DNater is offline Find More Posts by 3DNater
Old Nov 24, 2012, 10:18 PM
Joined Oct 2011
Have you ever compared the power draw of the two (19x8 vs 20x8). I probably will just order one to see if it is a option for me.
Old Nov 25, 2012, 05:48 AM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
I just switched from a 19x10 APC to a Xoar 20x8 cf prop on my Motrolfly 4325-280 on 8s and it actually draws just slightly less amps with the Xoar cf prop. I haven't had a chance to fly it yet between crappy weather and my current 7 day week work schedule so I can't comment on how it feels performance wise. Although I'm sure it's going to be an improvement due to how could hear the prop blades flexing under a heavy load with the APC. I hope after this week my work load will get back to normal and I can take a couple of days off with some decent weather to test this thing. But for now it just has to wait.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Nov 25, 2012, 07:27 AM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
I pull about 69-70 amps with my 280 kv and carbon 20x8.. Plenty of room to go up a little if i wanted to but the power is really good so I havent touched it since the first flight with that setup.
Harrier is sooo stable on this plane.i dunno if the 20 prop helps but it def dont hurt.
Old Nov 25, 2012, 03:45 PM
Burke, VA
Joined Sep 2009
Cool, mine was pulling 71 amps so this sounds about right. I know this won't stress the motor, esc, or batteries and should have good power. The 19x10 had good power but the blades would flex and it wasn't holding power.
Old Nov 25, 2012, 05:49 PM
hertzrepkeith is offline
Find More Posts by hertzrepkeith
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
Ok so I am still having issues with my DLE 30CC. I just ordered the Bowman Rings and I think I am going to order a new carb to see if that will fix my issues. What kind of up grade can I do to my reed? I hear everyone talking about it but I do not know a whole lot about it.
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Nov 25, 2012, 06:12 PM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
Basically Frank Bowman just takes your reed block and makes certain it is completely smooth and even. He takes some high grit sandpaper on a very flat workshop table and sands the block a bit to be sure there are no ridges and that the surfaces the reeds go against are on the same plane. You can easily do it yourself. Just don't get too carried away.
Then when you put the reeds back on the block you want to be certain the screws are not putting a twist in them as you tighten them down. Once that is all done you should have as good of performance out of that reed block as you are going to get.
Old Nov 25, 2012, 08:22 PM
SteveT.'s Avatar
San Jose, CA
To do this, use wet or dry sand paper of no more than 800 grit (use it wet) and best to do it on a sheet of glass if you don't have a granite surface plate which is what I used to use to do this.
SteveT
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
