Old Nov 08, 2012, 09:27 PM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
http://www.rcdude.com/servlet/the-17...sh-pack/Detail
Yeah the description of the large says for 6s 5000s.
On another note i got my 4330 in the mail today. What's the easiest way to move the blind nuts to match up with the X-mount?
hone1er is offline Find More Posts by hone1er
Old Nov 08, 2012, 09:34 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Gremlin l have the 5320 on mine and the hv120 with the Bec pro on the side of the motor box and my batts sit up further than yours too. Mine is dead neutral in flight too. Wonder why yours is so different.
Wait where do you have your rudder servo? Mine is in the tail
losifanatic is offline Find More Posts by losifanatic
Old Nov 08, 2012, 09:36 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Remove the firewall and make a new one.....that's what I do....
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Nov 08, 2012, 09:38 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
Blind nut removal
going4speed is offline Find More Posts by going4speed
Old Nov 08, 2012, 09:54 PM
Sippin the Koolaid!
Joined Oct 2007
SteveT
wow
I'm sure that's the prettiest option.
I just popped my blind nuts out with my screw and driver then used a hobby knife to remove the circle. Drilled new holes on the center lines and reinstalled the circles and blindnuts
Old Nov 08, 2012, 10:08 PM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
I squirt a bit of debonder around the small plywood donut.
Take a soldering iron that is nice and hot and stick the iron in from the front, the heat loosens the glue and the blind nut will pop right out. Or (I usually do this) skip the soldering iron and start working a small screwdriver in between the plywood donut and the firewall. It will usually pop out without much work. If the debonder has done it's work they will even come off clean.
ryan_m is offline Find More Posts by ryan_m
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Not to change the subject... but I am on a prop hunt. What are you guys running 19x10 and 20x8 using? Eventually would like to get to Carbon Fiber but may start with wood.
Looking forward to some video with the new slick, Hone1er
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Nov 08, 2012, 10:10 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Originally Posted by losifanatic View Post
wow
What can I say, I'm a glutton for punishment.... see this post.... and this post... It's actually quite easy....
SteveT
hone1er is offline
Team Twisted!
hone1er's Avatar
Joined Dec 2011
Xoar http://www.rcdude.com/servlet/the-Pr.../54/Categories
I got the blind nuts removed but the donuts got messed up
Now i have to find a way to install them without the donuts
gremlin is offline
Find More Posts by gremlin
What?!? I didn't do that!
gremlin's Avatar
United States, NY, Orchard Park
Joined Dec 2002
I'm running a pull-pull rudder setup so the servo is up front, that's probably the difference. In reading back thru the thread I saw a lot of guys running 8s with pull-pull have their packs right on the wing tube so I'm pretty happy with where they sit. I'm still dialing the plane in so there may be a little adjustment to get the sweet spot. The 71 is so forgiving it doesn't hurt if the CG is off a bit.
gremlin is offline Find More Posts by gremlin
Old Nov 08, 2012, 10:13 PM
Sippin the Koolaid!
Joined Oct 2007
I figured it had to be pull pull.
Old Nov 08, 2012, 10:15 PM
Sippin the Koolaid!
Joined Oct 2007
DANG Steve. That looks sweet. I know who to call if l need parts made
Old Nov 08, 2012, 10:18 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Any time....and guys, if you need new firewalls made, I'm happy to make them for you.....
SteveT
Old Nov 08, 2012, 10:21 PM
3DHS 'native'
USA, TX, Spring
Try replace the donuts as the prongs from the blind nuts can go all the way through the firewall if no donuts in place.
Old Nov 08, 2012, 10:24 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Sorry about the donuts getting messed up Joe....
So....for those times when I need to remove blind nuts that are glued in...here is how I do it....
Screw a bolt into the blind nut and then heat the bolt with a soldering iron or soldering gun, then tap the bolt with a mallet to break the blind nut loose.
If there are donuts, then once the blind nuts are out, you can use Golden West Super Solvent to remove the donuts....
Lastly...you can cut some new spacers from plywood, glue them on the back, then when you drill you new holes, just drill through them. To keep the plywood from splintering, hold a wooden block up against the back of the plywood...
SteveT
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
