Old Nov 08, 2012, 01:51 PM
DaaBears is offline
Find More Posts by DaaBears
Santi
DaaBears's Avatar
United States, MO, Clayton
Joined Nov 2003
Originally Posted by Inverted-I-Fly View Post
I was going to go 6s because I already have 10 2500 gens ace 6s I could double up to make 5000mah packs, but now I'm wondering if I should go 12s
The only reason I love the 6s setup I have now is I get the big 20" disk and still have good forward speed with the 10 pitch... I'm not sure what prop the 12s would need to spin to make it comparable. You would think someone would have done it by now of it was a sought after option.
DaaBears is offline Find More Posts by DaaBears
Old Nov 08, 2012, 02:05 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by bryansifsof44 View Post
Finally pulled the trigger on this bad boy... My LHS placed a order on bunch of pre ordered 3dhs planes and I was able to get one of the extra slicks they ordered for less then 1/2 the normal shipping cost to Alaska. Anyways... I am ordering a power system right now and servos will be a week or two down the road. Have a Ice2 80hv... have a email out to Ken to see what he recommends for a 12s kv on the 4330. He recommended a 200kv on the 4325 for my cooler Alaskan climate before. So as soon as I get the word I will be placing order. Any of you try the 4330 yet? and if so what do you think? I will be using 2 - 6s 2600-3000mAh batteries I run in my helis. For the servos I am leaning towards the HV Hitecs... but I would like to sacrifice a little torque for speed that the HS-7954sh have to offer. 403oz/in way more then enough. On the other hand the alternative is $133 a pop (HS-7945TH) I will most likely will go with the 7954 since I could get 4 for about $300.
HS-7955TG servos will be "more than enough" for this plane and are much less expensive than the HS-7945TH at $89.00 each at Chief Aircraft....
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Nov 08, 2012, 02:10 PM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Wow all the hitecs have a lot of torque. Are the savox 1258TGs enough? I swear that i've heard they were a great servo for this size plane?
http://www.amainhobbies.com/product_...ium-Gear-Servo
hone1er is offline Find More Posts by hone1er
Old Nov 08, 2012, 02:15 PM
DaaBears is offline
Santi
DaaBears's Avatar
Joined Nov 2003
I think I have these in my ailerons, if I do, they are awesome! I'll check when I get home...
Old Nov 08, 2012, 02:19 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Yes, they are fine!! Especially on six volt (don't go any higher as they are no HV servos)
SteveT
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
I have them all around in my 71" Slick and 70" Velox. They are plenty. Wickedly fast as well.
ryan_m is offline Find More Posts by ryan_m
Old Nov 08, 2012, 02:23 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
I believe the align ds610 is the same servo as the savox (correct me if I'm wrong) and this is the best price I could find on those, $225 for 4 shipped
http://www.ebay.com/itm/330697507861...84.m1438.l2649
3drcparts is offline Find More Posts by 3drcparts
Old Nov 08, 2012, 02:29 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
I have another question about HV servos and powering them, if you use a separate 7.4v rx pack directly with out bec, won't your servos be faster when the pack is newly charged and gradually become slower?
Old Nov 08, 2012, 02:36 PM
ryan_m is offline
doh!
ryan_m's Avatar
Joined May 2006
Yes, and this is the reason that Joe and some others use a 3s lipo regulated down. The voltage remains constant always then.
Personally I'm not good enough to tell that difference
Old Nov 08, 2012, 02:43 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Me neither.... I am using two 2S 2700mAH Thunder Power packs in my 89" Slick... I have three sets of flight packs for the plane, and from the first flight to the third flight, I sure as heck can not see any difference, but as noted, I'm not good enough to notice either!!
SteveT
Old Nov 08, 2012, 02:49 PM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
My servos are around 200 oz/in and it is plenty for the 70" slick. I don't think I am getting any blowback.
3DNater is offline Find More Posts by 3DNater
Old Nov 08, 2012, 02:54 PM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
2700= recommend max watts for the 4330 according to motrolfly's website. But I am used to ballistic power... Have a 48" on 4s DM2820 750kv spinning a 14x7, a 60" on 6s DM4315 480kv spinning a 16x8. So this should fall right in line.
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Nov 08, 2012, 02:57 PM
Joined Oct 2011
Oh I'm gonna try the 19x10 which is recommended on the 400kv 6s and 20x8 also... Check numbers and see what I like.
Old Nov 08, 2012, 03:00 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
Originally Posted by SteveT. View Post
Me neither.... I am using two 2S 2700mAH Thunder Power packs in my 89" Slick... I have three sets of packs for the plane, and from the first flight to the third flight, I sure as heck can not see any difference, but as noted, I'm not good enough to notice either!!
SteveT
Thanks guys, that is what I thought.
Steve, do you run two 2s 2700mah for the size or for redundancy
Old Nov 08, 2012, 03:10 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Redundancy, as I am using a "Power-safe" receiver... but it still uses both packs, unless there is a problem, at which time it switches out the bad one and to the good one.
And I forgot to say, the three packs I mentioned were the flight packs....I only have one set of receiver packs....
SteveT
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
