Old Oct 26, 2012, 06:32 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Weighed my plane today. Man has it gained weight from when l first got it. Its new 10lbs and 8oz. That with the 7954 servos, hv 120 esc, bec pro, 5320 motor, some heavy 3 1/4 wheels from the lhs, and 2 gen ace 60c 4000mah 4s lipos. Oh forgot some repairs too as lm sure that added weight.
It started out at 9lbs 13ozs with the same esc and bec, 7985servos, 4325 motor, stock wheels, an gen ace 25c 4k 4s lipos.
Anyways l have my slick all ready to fly so l can test out the new servos but the dang hurricane his holding me up. Stupid crappy weather.
losifanatic is offline Find More Posts by losifanatic
Old Oct 26, 2012, 07:45 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
I thought you were using an Ice 100. You still think my Ice 100 will be OK with that same setup right??
turnerm is offline Find More Posts by turnerm
Old Oct 26, 2012, 08:23 PM
johnnyrocco123 is online now
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
quick fix
If you have built enough of these planes I am sure you have had the wood breakout where the control horn slots are in one of the surfaces?? When you are installing the horns, the balsa breaks out.....
Whats a good fix for securing the control horns after this happens? On my last build, the control horn kept coming loose after the fact.
johnnyrocco123 is online now Find More Posts by johnnyrocco123
Old Oct 26, 2012, 08:36 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
What kind of adhesive are you using? I use epoxy and I have had no problems with control horns coming loose. Make sure you scuff the sides of the horns before you insert them with 100 grit sand paper..
If you are talking about the sheeting in between the two horns breaking out when fitting the horns, I just CA it back in, then as noted using a good "slathering" of 30 minute epoxy... Once I insert the horns if there is any excess epoxy that has squeezed out, I wipe it off with alcohol....
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Oct 26, 2012, 10:04 PM
You down with EPP?
Houston, Tx
Joined May 2009
I use epoxy and have never had issues except the other time I broke out all of the balsa that the horns slide into. The problem is that the wood broke into tiny pieces. Last time the horn came loose after thick layers of epoxy mixed with milled fiberglass were applied.
I did try this again, though I think I did a more thorough job. Hope it sticks.
Old Oct 26, 2012, 10:08 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
what plane you building?
going4speed is offline Find More Posts by going4speed
Old Oct 27, 2012, 12:47 AM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Oooooh man i need to get some money for my slick. It is awaiting servos and a motor. I'm having a tough time walking by the plane everyday and not being able to finish it. Hopefully i'll get it done before Christmas.
hone1er is offline Find More Posts by hone1er
Old Oct 27, 2012, 02:15 AM
AZAerobat is offline
Find More Posts by AZAerobat
Fly More Crash Less
AZAerobat's Avatar
United States, AZ, Prescott
Joined Sep 2007
Don't worry you will. If I can get my MXS up by then you can get the slick up and running too.
AZAerobat is offline Find More Posts by AZAerobat
Old Oct 27, 2012, 07:05 AM
Sippin the Koolaid!
Joined Oct 2007
My brother flys harder than l do and he has use the ice 100 since he got his slick. So a few hundred flights with the 5320 and before that a few hundred with the 4325. With a 19x8 prop the 4325 pulls more current than the 5320. He has the same esc and 4325 in his velox with the 19x8 prop right now and still no issues.
Old Oct 27, 2012, 09:44 AM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Ok. I feel better now.
Old Oct 27, 2012, 10:47 AM
sparkx38 is offline
Find More Posts by sparkx38
Livin ta fly
sparkx38's Avatar
United States, LA, Shreveport
Joined Apr 2011
Wing Bolts
Any one know what size thread the wing bolts for the 71" slick are?
sparkx38 is offline Find More Posts by sparkx38
Old Oct 27, 2012, 11:40 AM
You down with EPP?
Houston, Tx
Joined May 2009
Orange 71" Slick.
Looks like I got a good bond with the thickened 30 min. epoxy. I filled in the hole with some baking soda and CA.
Old Oct 27, 2012, 12:25 PM
lugnutz is online now
Find More Posts by lugnutz
The Twisted Elf
lugnutz's Avatar
USA, NJ, Trenton
Joined Nov 2010
6mm
lugnutz is online now Find More Posts by lugnutz
Old Oct 27, 2012, 06:16 PM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Anybody know what timing setting I should use on my Castle 100 for my Motrofly 5320?
Old Oct 27, 2012, 06:39 PM
ryan_m is online now
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
low, 8pwm, worked great on mine
ryan_m is online now Find More Posts by ryan_m
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
