Old Oct 21, 2012, 08:00 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
Not for my birds...I would go hv120
Originally Posted by hone1er View Post
So you think the ice 100 with bec pro would be OK on the 4330?
going4speed is offline Find More Posts by going4speed
Old Oct 21, 2012, 08:47 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
it depends on the prop and cell count you are using. If propping for over 100 amp operation then no,if not,rock on.
Manta1 is offline Find More Posts by Manta1
Old Oct 21, 2012, 09:37 PM
ROLLING CIRCLE is offline
Find More Posts by ROLLING CIRCLE
TEAM TWISTED
ROLLING CIRCLE's Avatar
United States, MD, Middle River
Joined Dec 2011
I'm in a situation where I was speculating that our Pheonix ICE100 is faulty. Plane is new to us. I put a video of the problem a few pages back. We had the Low Voltage cutoff at 3.2 and it was tripping the hard shutoff. Recently switched it to soft but haven't tried it out again yet.
I know we need a watt meter to check for sure, but, hypothetically, if our 4325, with the 18x8 is supposed to only pull 89 amps, that wouldn't matter to the ICE 100 in terms of cutoff right? I mean, voltage cutoff is a battery thing and not a problem between the motor and the speed control, right?
Just don't want to spend $140 for two new 4S packs if batts are not the problem and we should be calling Castle.
Also wondering if the ICE 120 would remedy the problem if we were asking for too much from the 100...
ROLLING CIRCLE is offline Find More Posts by ROLLING CIRCLE
Old Oct 21, 2012, 11:07 PM
hertzrepkeith is offline
Find More Posts by hertzrepkeith
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
You did a great job on this plane!!! I will have to say that I am very impressed. It will be my new Plane when practicing for my New 71 that I just got about a month ago.
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Oct 22, 2012, 12:44 AM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
71" ordered, so subscribed
3drcparts is offline Find More Posts by 3drcparts
Old Oct 22, 2012, 12:48 AM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
anyone know what motrolfly motor/esc/pro Joe was running in the 71" slick while filming the video on 3dhs
Old Oct 22, 2012, 01:17 AM
bss_rcg is offline
Find More Posts by bss_rcg
India
Joined May 2009
Ordered 71" Red electric Slick :-)
Going to equip with A60-6XS, 100 ICE, 7954SH on rudder and 7965MGs on other surfaces, BEC Pro, 6S 5000 mah 30C Zippy, 20x10 APC. Can't wait to get the ARF in my hands...
Have been going through posts on this thread.
bss_rcg is offline Find More Posts by bss_rcg
Old Oct 22, 2012, 01:50 AM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
If you can see your way to going a little higher on the "C" rating of the batteries, I would suggest doing so. 30C would definitely be as low as I would want to go...I'm using 65C myself.
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Oct 22, 2012, 03:44 AM
bss_rcg is offline
India
Joined May 2009
wow! I've 4 betteries in transit from HK. All 30C :-( guess I'd have to try them out and dependeing on how they perform I may order higher Cs. Using the setup I mentioned above, where does rudder servo fit? Tail or pull pull? Thanks Steve.
Old Oct 22, 2012, 03:57 AM
RustyT3FT is offline
Find More Posts by RustyT3FT
The Best or Nothing
RustyT3FT's Avatar
United States, IN, Fort Wayne
Joined Feb 2008
45deg out
RustyT3FT is offline Find More Posts by RustyT3FT
Old Oct 22, 2012, 04:31 AM
bss_rcg is offline
India
Joined May 2009
Ok. How many inches from wing tube?
Old Oct 22, 2012, 06:48 AM
tkimbro55 is offline
Find More Posts by tkimbro55
tkimbro55's Avatar
United States, KY, Murray
Joined Jan 2012
3dhs 71" slick?????electric flight times?????
i was wondering about flight times with an electric plane of this size doing full out 3d?
tkimbro55 is offline Find More Posts by tkimbro55
Old Oct 22, 2012, 06:53 AM
RCPilot1234 is offline
Find More Posts by RCPilot1234
Joined Jan 2012
Thanks! Great to hear
RCPilot1234 is offline Find More Posts by RCPilot1234
Old Oct 22, 2012, 06:58 AM
lowkeylaidback is offline
Find More Posts by lowkeylaidback
Custom Crasher
lowkeylaidback's Avatar
USA, FL, Jacksonville
Joined Jan 2010
Wanted 3dhobbyshop 48" EPP Extra 330 Starboard main wing
Each post of this request was meant to target buyers of models from 3DHS that may like most have more then one model from that vendor as many here do and not use the classified adds this seem to be the only way to reach the buyers of this brand. A little dog not mine ruined my wing and I have not gotten a response from 3DHS since 10/9 about getting a new wing, as the wing is the only part that is damaged I am searching for a replacement
I need the starboard main wing for a 3dhobbyshop 48" EPP Extra 330, if you have one I am in the market, please send me a PM
thanks alot
lowkeylaidback is offline Find More Posts by lowkeylaidback
Old Oct 22, 2012, 07:18 AM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
With either 6s5000 or 8s4000 you get about 6-7 minutes depending on your 3d style and throttle usage. I used to get 7:30 doing mostly low and slow hovers and harriers, now I fly more high energy stuff and have moved the timer down to 6:20 and usually put about 4000 mah back into my 5300 packs.
ryan_m is offline Find More Posts by ryan_m
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
