Old Oct 17, 2012, 09:51 AM
Safety Hawk is offline
Find More Posts by Safety Hawk
Here We Go!
Safety Hawk's Avatar
United States, VA, White Stone
Joined Jun 2005
Better to puff a pack then pile in a plane. Set to custom, set 4v total. Then use a timer. Start off with the timer set low. And then adjust for the next flight. Etc.
Safety Hawk is offline Find More Posts by Safety Hawk
Old Oct 17, 2012, 10:57 AM
94'325is is offline
Find More Posts by 94'325is
94'325is's Avatar
Florida
Joined Jan 2010
That's true, I had an issue with mine original Slick on 8S (battery dropped a cell) and I was able to limp it back on 7S enough to land. Batteries are cheap, airframes aren't!
94'325is is offline Find More Posts by 94'325is
Old Oct 17, 2012, 01:55 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Hey Jay how have you been brother?
losifanatic is offline Find More Posts by losifanatic
Old Oct 17, 2012, 02:53 PM
garrettt04s is offline
Find More Posts by garrettt04s
3d Master in Training
United States, PA, Tunkhannock
Joined Dec 2011
just ordered a hacker a50-16l V2 for my slick and a 19x10 prop. Cant wait to get this bird in the air
garrettt04s is offline Find More Posts by garrettt04s
Old Oct 17, 2012, 06:16 PM
Here We Go!
Joined Jun 2005
Hey Matt....I'm doing good. Just jumping in here to catch up on some forum talk! That's about all the time I have to dedicate to RC right now. You down in OBX again?
Old Oct 17, 2012, 08:20 PM
Sippin the Koolaid!
Joined Oct 2007
Close. I'm down in Elizabeth city off of route 17. I'm on the river.
Old Oct 17, 2012, 08:23 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
wow! Safety Hawk!! theres a name i havent seen in forever.. How goes it?
Manta1 is offline Find More Posts by Manta1
Old Oct 18, 2012, 04:02 PM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
Originally Posted by tominator06 View Post
I would send Ken an email and ask about that new 4330 motor. I believe it has an extra set of bearings in it. Looks like it will be available in 6s and 8s kv options.
Originally Posted by ryan_m View Post
I've got one coming to go onto my 71" Slick. Has a 4325 on there currently, keeping roughly the same kv (about 10kv higher on the 4330). Will be interesting to see the motor differences, and motor temp differences too.
FYI the new 4330 is $189, the 4325's are $169.
Originally Posted by zmonster97 View Post
Can you take a picture of it when you get it? Thanks.
Got my 4330 in today. Just for those curious it looks pretty much exactly like the 4325's, only longer I assume. I haven't swapped out the 4325 on my 71 just yet, will do that probably friday evening/afternoon and get the 4330 swapped onto the plane. I'll take a pic of the two side by side when I have them both off. And weigh them as well.
ryan_m is offline Find More Posts by ryan_m
Old Oct 18, 2012, 04:34 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
5mm stack height on a stator can make a heck of a difference for sure.
going4speed is offline Find More Posts by going4speed
Old Oct 19, 2012, 04:23 PM
ryan_m is offline
doh!
ryan_m's Avatar
Joined May 2006
Motrolfly 4330 vs Motrolfly 4325
Ok, here are some pics of the 4330 and 4325. As well as the weights of each. The 4330 is 560 grams, while the 4325 is 510 grams, so a good 50 grams, or just shy of 2 ounces lighter.
They look visually identical, and use the same mounting bolt patterns as well. The 4330 is just 5mm longer. Haven't flown it yet, will do that sunday.
Old Oct 19, 2012, 05:54 PM
Sippin the Koolaid!
Joined Oct 2007
So the 4330 is about the same weight as the lightened 5320. Nice! Wonder if its just as efficient?
Old Oct 19, 2012, 05:59 PM
Sippin the Koolaid!
Joined Oct 2007
Borrowed a set of hitec7954 servos. Put 8 volts to them. Wow they are much faster than my 7985s at 6.7 volts and faster than the 7955s at 7 volts. Just need to set up control throws and l then can find out how these hv servos are.
Old Oct 19, 2012, 07:58 PM
joesmith285 is offline
Find More Posts by joesmith285
Game on
joesmith285's Avatar
United States, IN, Fort Wayne
Joined Nov 2008
Originally Posted by ROLLING CIRCLE View Post
Got into the link for the Ice 100 last night, switched it to soft cutoff and looked at the cutoff voltage and found it was set by default at 3.2V ... Yikes... moved up to 3.6...
3.2 volts is fine, you definitely don't want to set it to 3.6 volts. I usually set mine somewhere betweem 3.0 volts and 3.2 volts and also soft cutoff and you will be good to go.
joesmith285 is offline Find More Posts by joesmith285
Old Oct 19, 2012, 10:18 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
DUH! Its a Motrolfly..
P.S. knock em dead tomorrow for your demo. I wont tell you good luck cause you dont need it..Just remember,do what you do and have fun.
Old Oct 20, 2012, 12:39 AM
hertzrepkeith is offline
Find More Posts by hertzrepkeith
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
So today i went to the field and fired my 71 up to learn that my choke servo was not working. I am running HT 7955 for all my control surfaces and ht 5665 HV on my throttle and choke. When I got home I pulled it out and opened the bottom up and it smelt burnt. I bought them from Chief air craft a month ago. Will they swap this out for me?? I sent them a email but have not heard back yet. What could have caused this to do this??
hertzrepkeith is offline Find More Posts by hertzrepkeith
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
