Old Oct 10, 2012, 02:41 PM
ryan_m is online now
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
Originally Posted by Maxmannnn View Post
So after lurking through nearly 1000 of the past pages I finally took the plunge and got the 71" slick. I slapped a a60-6xs on the front after reading Steve's comments. I live at 7500ft, and it seemed pretty gut-less for this morning's maiden. It will pull out of a hover, but not by much. I've got a 20x10 on it and a 60c gens ace 5300 6 cell pack. I'm barely pulling 1300 watts at 60amps. Any suggestions for the next step? A bigger prop like a 21x12?
At that altitude a higher KV would probably be very good. That would give you more room to prop up. For us at lower altitudes a higher kv (400-450) lets us start to run an 18-19" prop, which would let you prop up to 20-21 to get the same power.
ryan_m is online now Find More Posts by ryan_m
Old Oct 10, 2012, 03:25 PM
Maxmannnn is offline
Find More Posts by Maxmannnn
Joined Jun 2006
So, at my altitude (7500ft), which Motrofly would be the most ideal?
Maxmannnn is offline Find More Posts by Maxmannnn
Old Oct 10, 2012, 03:31 PM
doh!
ryan_m's Avatar
Joined May 2006
Don't rightly know... I've just seen others that post on here have good success with being able to prop up. There area few, if you go back through this thread you'll find some that live in Denver and other areas up there. If it were me I'd probably try a 4325-450 and spin a 19x10 prop and see that that does for you. I would shoot for watts in the 2000-2300 range.
That is just a guess.
You would probably be best to email Subsonicplanes.com and get their recommendation... undoubtedly they would know more than me. Or you could also try the Hacker a60-5xs, it's a higher kv too and should let you run a 19-20" prop. Would be a direct replacement to your a60-6xs.
Old Oct 10, 2012, 03:35 PM
Irg is offline
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
pretty sure Joe Smith is running a 21x10 on the A606XS. iirc, he was even considering a 22" prop. just saying you might have some room to prop up before selling your motor.
Irg is offline Find More Posts by Irg
Old Oct 10, 2012, 03:49 PM
DaaBears is offline
Find More Posts by DaaBears
Santi
DaaBears's Avatar
United States, MO, Clayton
Joined Nov 2003
I keep nicking my wood props on my very short, uneven, and paved runway. What stronger prop options could I run on a hacker a50-12l on 6s...? I need something durable that wont bust at the slightest contact...
DaaBears is offline Find More Posts by DaaBears
Old Oct 10, 2012, 03:51 PM
Irg is offline
Irg
Irg
Irg's Avatar
Joined Apr 2009
bigger wheels.
Old Oct 10, 2012, 03:52 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
If I were in your shoes I would email ken at subsonicplanes.com and see what he thinks.
going4speed is offline Find More Posts by going4speed
Old Oct 10, 2012, 04:27 PM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
hmmm, I'd start with working on the landings, a nice 3 point! For me sometimes a 1 point then drop the other 2.
robj is offline Find More Posts by robj
Old Oct 10, 2012, 05:10 PM
garrettt04s is offline
Find More Posts by garrettt04s
3d Master in Training
United States, PA, Tunkhannock
Joined Dec 2011
My 71" slick arrived today. As well as my equipment. My setup is as follows:
Tacon Bigfoot 110 295kv
JXF 19x9 prop
AeroModel 3" CF spinner
Turnigy 120A-HV-OPTO Esc
2 Zippy 4s 4000mah 40C packs in series
Turnigy 15a UBEC
Turnigy 620DMG+HS High Torque Digital Servos (MG) 10.6kg / .13sec / 52g
Spektrum AR8000 receiver
Not sure what size receiver pack to run on this setup though.
Also these wheels seem very hard, what is everyone running? Suggestions on my setup?
garrettt04s is offline Find More Posts by garrettt04s
Old Oct 10, 2012, 05:34 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
You don't need another motor, just a different prop. You are at a higher altitude where the air is thinner, you need a prop with more bite...
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Oct 10, 2012, 05:57 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
JXF 19x9 prop
Turnigy 15a UBEC
They guy I bought my slick from had these wheels on it. They are nice and squishy.
http://www3.towerhobbies.com/cgi-bin...?&I=LXD763&P=7
zmonster97 is offline Find More Posts by zmonster97
Old Oct 10, 2012, 06:02 PM
SteveT.'s Avatar
San Jose, CA
Stock wheels are fine....(IMO.....YMMV)
SteveT
Old Oct 10, 2012, 06:06 PM
dentalpain is offline
Find More Posts by dentalpain
dentalpain's Avatar
United States, FL, Marianna
Joined Apr 2011
As ken about the new 4330. Love mine on a 20x10.
dentalpain is offline Find More Posts by dentalpain
Old Oct 10, 2012, 06:15 PM
zmonster97's Avatar
Joined May 2011
Do you have one on this plane? What's your amps and watts?
Old Oct 10, 2012, 06:18 PM
SteveT.'s Avatar
San Jose, CA
A60-5XS is 420KV, according to Mike at Aero-Model, this motor is designed for 16X10 to 17X10 props (at nominal sea level) on 6S. However, he told me I could run an 18X8 Xoar (I am at sea level). I have one of these in my new 70" Velox, and should have some numbers on it in just a little while. At higher altitudes you would of course be able to use a larger prop.
SteveT
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
