Old Oct 09, 2012, 12:07 PM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
Originally Posted by going4speed View Post
yea stock seems REALLY low right now and only back in stock in 2013
Did you make it to Austin? Trying to PM ya but I don't see it on your page.
Rob
robj is offline Find More Posts by robj
Old Oct 09, 2012, 12:29 PM
Eagle34 is offline
Find More Posts by Eagle34
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
I still consider the 71" yours.
The above was in relation to my 40" edge.
Cool. Wasn't sure. Didn't want you to think I backed out on you or anything.
Eagle34 is offline Find More Posts by Eagle34
Old Oct 09, 2012, 01:02 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
Yea I was there Thursday, Friday and Saturday. Did not make it to the meet and greet on Saturday.
Rob
going4speed is offline Find More Posts by going4speed
Old Oct 09, 2012, 03:14 PM
SnowDog1974 is offline
Find More Posts by SnowDog1974
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
Originally Posted by Eagle34 View Post
Not exactly sure but it seemed that the electric 71's were out of stock for almost a year. They had the gas ones, but they just got the electrics back in and now the gassers are out. You will want to contact ADC Hobbystore anyway as they are the worldwide distributors for 3DHS, Rob maight actually have one in stock, never know.
That's why I bought a red 71" Gas Slick earlier this year, even though I knew I wouldn't be able to afford all the internals until this fall...now I'm looking at a really fun winter building project and a really great start to spring flying! The gas 71" Slicks were out of stock for almost six months IIRC, so I bought one as soon as they came back in stock (earlier this summer).
SnowDog1974 is offline Find More Posts by SnowDog1974
Old Oct 09, 2012, 03:48 PM
3DHS 'native'
USA, TX, Spring
yea I need to get a back up for christmas if they come back in stock
Old Oct 09, 2012, 06:00 PM
DaaBears is offline
Find More Posts by DaaBears
Santi
DaaBears's Avatar
United States, MO, Clayton
Joined Nov 2003
Flew the absolute piss out of my newly inherited slick! Wow, just wow! I already loved my 51, but the 70" just blew my mind! Already can't wait for an 89"... I truly understand the slickness sickness!
DaaBears is offline Find More Posts by DaaBears
Old Oct 09, 2012, 06:53 PM
Huang is offline
Find More Posts by Huang
United States, CA, SF
Joined Sep 2001
Canopy latch
Does anyone have issues with the canopy latch pin being too short?
I'm finishing the Slick and discovered my canopy latch pin does not go all the way through the canopy plywood doubler when the canopy is fitted and latched. When fully extended it only goes through about half way in the canopy frame: It latches only onto the balsa part of the canopy bulkhead instead of all the way through the plywood doubler. All my other Slick latch all the way through.
It looks like the latch is glued in the right place and length of the pin is correct, any longer it would scrape when fitting the canopy. Maybe the canopy is a bit distorted so the fit is not perfect. The magnets are holding it very tight and the pin latches, but just not fully.
Am I going to have problems with the canopy blowing off?
Huang is offline Find More Posts by Huang
Old Oct 09, 2012, 06:57 PM
3DHS 'native'
USA, TX, Spring
Use the side bolts and you should be fine.
Old Oct 09, 2012, 07:03 PM
M Carr is offline
Find More Posts by M Carr
M Carr's Avatar
Eastern, NC
Joined Dec 2007
I'm betting all you need to do is file the hole in the plywood former down just a little to the same level of the balsa... Had to do it to one of mine, Just be sure not to file more than needed so it still latches the canopy down tight.
M Carr is offline Find More Posts by M Carr
Old Oct 09, 2012, 07:12 PM
quadracer is offline
Find More Posts by quadracer
No, I won't ship it. Don't ask
quadracer's Avatar
United States, IN, Derby
Joined Feb 2012
My canopy just required a slight wiggle, then the pin would pop all the way through.
quadracer is offline Find More Posts by quadracer
Old Oct 09, 2012, 07:21 PM
lugnutz is offline
Find More Posts by lugnutz
The Twisted Elf
lugnutz's Avatar
USA, NJ, Trenton
Joined Nov 2010
i had to enlarge the hole on all 3 of my planes ,2- 71"slicks and 72" extra
lugnutz is offline Find More Posts by lugnutz
Old Oct 09, 2012, 07:48 PM
Huang is offline
Joined Sep 2001
A bit hard to explain this, it's not the latch is being restricted. The latch pin is already fully extended, but still does not go all the way through the ply doubler. It only has enough reach to go through the canopy balsa bulkhead.
It could be my canopy is slightly warped, or the canopy back plate is glued slightly inner to where it should be. It's just 1-2mm off but the latch can't hook onto the ply doubler when fully extended. Does it need to hook onto the ply doubler?
I'd rather not have to use the thumb screws if possible. Hard to disconnect the battery quickly in case anything happens.
Old Oct 09, 2012, 08:04 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
They do fly great don't they!!!!
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Oct 09, 2012, 08:06 PM
SteveT.'s Avatar
San Jose, CA
Mine did less than 90 seconds into the maiden flight....use the screws!!
SteveT
Old Oct 09, 2012, 08:17 PM
dentalpain is offline
Find More Posts by dentalpain
dentalpain's Avatar
United States, FL, Marianna
Joined Apr 2011
Maybe a washer glued to the back of the hole on the canopy would help
dentalpain is offline Find More Posts by dentalpain
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
