Old Sep 29, 2012, 02:26 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by zmonster97 View Post
XtremeWingRC,
I asked Joe Smith which motor to use in a 71 slick. He said he would use the motrolfly 4325-380 w/ a 19x10 prop. He said the hacker is more suited for the 74 edge.
I know I don't fly like Joe, but I really like the A60-6XS with a 20X10 in my 71" Slick...
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Sep 29, 2012, 02:53 PM
ryan_m is online now
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
XtremeWingRC,
I prefer a 4325-425 on 18x10. Less prop torque, and more forward speed. Great for pop tops and other fast high energy moves.
ryan_m is online now Find More Posts by ryan_m
Old Sep 29, 2012, 03:15 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
This is a socket head screw that's stuck in the servo
going4speed is offline Find More Posts by going4speed
Old Sep 29, 2012, 03:32 PM
SteveT.'s Avatar
San Jose, CA
Ok....should still be easy....heat your soldering iron up, and hold it on the end of the screw for a few moments. The heat will break the Loctite loose....
SteveT
Old Sep 29, 2012, 06:27 PM
RCPilot1234 is offline
Find More Posts by RCPilot1234
Joined Jan 2012
Originally Posted by quadracer View Post
RIP, 70 Slick. In a 500' blender, it decide to eject the left wing, then subsequently, the right wing. Lawn dart from about 300'. Total write- off. Pretty damn bummed right now. The wing bolts managed to find their way to pulling out of the fuse. All I could do to make it hit the dirt in as straight-down attitude as I could.
Sorry to hear that man! If it's any conciliation, that happened to me too
RCPilot1234 is offline Find More Posts by RCPilot1234
Old Sep 29, 2012, 09:04 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
I bet that 425 kv is nice too.
Manta1 is offline Find More Posts by Manta1
Old Sep 29, 2012, 09:10 PM
goflyhighrc is online now
Find More Posts by goflyhighrc
Just go with the flow
goflyhighrc's Avatar
Joined Nov 2006
Originally Posted by SteveT. View Post
My personal opinion, is that you can't go wrong with a Hacker A60-6XS, which is what I have in my 71" Slick. You can use a 20X10, 20X11, or 21X10...all seem to work well...
SteveT
Does the Hacker A60-6xs have a bolt on prop adapter?
goflyhighrc is online now Find More Posts by goflyhighrc
Old Sep 29, 2012, 09:12 PM
Joined Nov 2006
Originally Posted by hertzrepkeith View Post
Well today was the first day that i really got to fly my new 71 Slick. Everything went good until My servo bolt came out of my Rudder on my 7955. My rudder stuck tot he right but i was able to get it on the ground safley by crabbing it in. ( I can say my heart stopped) Loctite it is for now on!! I am a firm believer in it!!!!!!!!!!!
Gas planes are paint can shakers, gotta make sure all bolts are tightened Get that throttle servo tray fixed OK
Joined Nov 2006
Manta -
Have you had the surgery ?
Old Sep 29, 2012, 09:15 PM
Joined Nov 2006
Originally Posted by RCPilot1234 View Post
Sorry to hear that buddy
I've heard putting a small piece of velcro between the moving and stationary surface stops it as the pressure halts the jittering so maybe try that
Hope this helps!
I did that on my 89 Slick, stopped the jittering, worked great
Old Sep 29, 2012, 09:17 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Originally Posted by goflyhighrc View Post
Manta -
yep.today is day 12 post cut..rough recovery but im still toodling along
Old Sep 29, 2012, 09:53 PM
SteveT.'s Avatar
San Jose, CA
No, there is a tapered collet that slides onto a shaft that goes all the way through the motor, which then has a prop thrust washer that slides onto it. . See this page, and click on the photo for a good idea of how it works. It is exactly the same system as used on the Q80 series motors. Very true running....
SteveT
Old Sep 30, 2012, 07:19 AM
Neil_SC is offline
Find More Posts by Neil_SC
Joined May 2004
What happens with a tail heavy plane when landing (From what I remember Ben saying), is that when you slow the plane down, the stabilizer stalls first, which make the tail drop, so, the plane balloons up causing you to have to feed in down elevator to counter-act the ballooning..makes it a lot harder to land...
SteveT
I have a PA Extra MX setup with a more aft CG for 3D and I did experience the same ballooning on landing. It just felt weird having to push down during approach to get it to land. The thing that solved it was to setup the air brake mix. When I'm ready to land I flip on the air brake which pops both ailerons up about 1/4" and also feeds in a little down elevator to counter the trim change. This way, the plane will not balloon, will require a normal amount of back stick during the approach (rather than down) and force it into a normal glide angle. When I get either my 3DHS Edge 540 or Slick, I'll definitely do the same thing.
Neil_SC is offline Find More Posts by Neil_SC
Old Sep 30, 2012, 07:49 AM
doh!
ryan_m's Avatar
Joined May 2006
Try one of the PA Bandits... I just built one for a local buddy. That thing balloons worse than anything I've ever seen. Once you get down to 3-4 feet high it just balloons up. You have to give down elevator to have a chance of landing it, and then it wants to dive into the ground since they tell you to use their carbon long arm things that give you no resolution/feel for small precise movements. That is one of the hardest planes I've yet flown to land smoothly. Wound up configuring about 10 degrees of spoilerons on it in order to help it land. Sinks nicely with those, much easier to land. Just like what you did sounds like.
I'm pretty sure that on the bandit the tail incidence is different than the wing incidence and that causes the ballooning. It's quite noticeable when looking from the rear.
After building 4 PA planes now (all for other people) I definitely appreciate 3dhs and EF kits and their build techniques a lot more. And the way they fly... PA stuff is just too floaty for me.
The Bandit looked like it was going to be similar to a Vyper in the air. Fast, yet 3d capable. I found it to not be fast, and have lots of wing rock in a harrier. It hovered quite easily, but otherwise had some weird tendencies. I did not much care for the plane...
Old Sep 30, 2012, 10:23 AM
XtremeWingRC is offline
Find More Posts by XtremeWingRC
Scobee Field & HTOWN FPV
XtremeWingRC's Avatar
United States, TX, Houston
Joined Oct 2007
I had a pa Extra and the wind tossed it around like a kite. Too floaty, too light, and I felt I had to fight the flying all time.
XtremeWingRC is offline Find More Posts by XtremeWingRC
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
