Old Sep 14, 2012, 10:48 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Originally Posted by tominator06 View Post
Good to hear. Might as well get while the getting is good.
exactly what I was thinking.. Be my last weekend with it for a few.
89 slick comes out tomorrow
Manta1 is offline Find More Posts by Manta1
Old Sep 14, 2012, 11:02 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
Ah okay. That is a thick piece of plastic to cut through
Originally Posted by losifanatic View Post
With the long double arm (and cut half off) l get 60 degrees
going4speed is offline Find More Posts by going4speed
Old Sep 15, 2012, 12:47 AM
hertzrepkeith is offline
Find More Posts by hertzrepkeith
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
Guys I am in the processor building this slick. I am putting 7955 in it should I use the arms it comes with or get the aluminum ones. And if the aluminum ones which kind do you prefer ?? ( I think there aluminum !)
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Sep 15, 2012, 01:02 AM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
I like Spot-on arms from Aztech AeroModel.... The problem with any of the aluminum arms, is that they are tapped for M3 or 4-40. I buy the 4-40, drill the hole out to fit these Dubro pull/pull crimps, which have almost a perfect M2 interior diameter. You will have to cut them down to length...but this is easily done.
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Sep 15, 2012, 06:13 AM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
The stock arms provide plunty of throw. I get 50 on the ailerions, maxed out rudder, and 60+ degrees on the elevator. More than enough to huck.
losifanatic is offline Find More Posts by losifanatic
Old Sep 15, 2012, 03:47 PM
Joined Jan 2012
Thanks guys ! If I do decide to use the ones it comes with do I need to shave a side of the arm off? I do think I am going to go with the custom arms as you said Steve. I have top line everything in this plane. I would hate for one of those arms to strip and lose a plane over that.
Old Sep 15, 2012, 05:43 PM
3DHS 'native'
USA, TX, Spring
well the swb's interfered with the ballend. I had installed it with the drilled out thread at 1 1/4" and used the pull pull bushing as above and that worked a charm but anything past 40 degrees caused interference so double arm modified to one sided and its good to go.
Old Sep 15, 2012, 08:45 PM
0gravity is offline
Find More Posts by 0gravity
A tale of two slickies
0gravity's Avatar
United States, IL, Chicago
Joined Feb 2010
tried the protek 24x12 from Amainhobbies. Me likey. The price is right too for a wood prop! about 23 dollars if I remember correctly.
0gravity is offline Find More Posts by 0gravity
Old Sep 15, 2012, 08:46 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
What I always do to give better ball link clearance is to use longer screws and put a nut between the ball and the arm.....gives plenty of clearance.....
SteveT
Old Sep 16, 2012, 12:05 AM
Joined Jan 2012
Thanks Steve that's good to know. Now this might be a stupid question but the protective cover(wrap) that goes over the ignition wire. What is that called?? And do you know where I could get some? I can't find the one for my new DLE engine and I know it has to have it. I was going to order some but I don't know what it is called.
Old Sep 16, 2012, 01:13 AM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Spiral wrap....Radio Shack, Pep Boys, and most other auto parts stores....also Home depot (pretty sure I saw it there)
SteveT
Old Sep 16, 2012, 07:33 AM
3DHS 'native'
USA, TX, Spring
Is it normal to have to install a aluminum arm with the screw? It will not push on like a plastic horn?
Also what vess prop is good on the OS GT33?
Old Sep 16, 2012, 01:04 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
While I do not use SWB arms, so have no experience with them, I have heard some of them go on very tight. So....if you are using SWB arms....yes....I use "Spot on arms, and other than the rudder (dual arms), they go on fine, but as noted the dual rudder arms can be......difficult....
SteveT
Old Sep 16, 2012, 01:21 PM
M Carr is offline
Find More Posts by M Carr
M Carr's Avatar
Eastern, NC
Joined Dec 2007
Yes, that is normal for SWB arms..They have a much tighter tolerance than plastic arms do.
Just draw it down carefully with the servo screw and all should be good.
M Carr is offline Find More Posts by M Carr
Old Sep 16, 2012, 01:23 PM
Hewey19 is offline
Find More Posts by Hewey19
Hewey19's Avatar
USA, MI, Lansing
Joined Aug 2009
Vess 20a on the OS 33GT.
Hewey19 is offline Find More Posts by Hewey19
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
