Old Sep 10, 2012, 10:09 PM
quadracer is offline
Find More Posts by quadracer
No, I won't ship it. Don't ask
quadracer's Avatar
United States, IN, Derby
Joined Feb 2012
It's gonna be ready for this weekend, come hell or high water!
Got a new 20 x 8 Mezj prop coming, along with AirWild's 1.5" aluminum servo arms. I was gonna get Vess' 20A prop, but they were out of stock in wood props, and there isn't anything smaller than a 23 available in carbon. So, I decided to get everything I needed from one place. AirWild has a pretty nice selection of goodies on their site!
One thing I'm slightly concerned about is drilling a 4-bolt pattern on the prop, all the while keeping it balanced. I'll use the washer from the prop adapter to lay out the holes, but still seems like an easily screwed up job to me. Anyone have any tips for this process?
quadracer is offline Find More Posts by quadracer
Old Sep 10, 2012, 10:13 PM
diggity2424 is offline
Find More Posts by diggity2424
Wingman II
diggity2424's Avatar
United States, KY, Louisville
Joined Sep 2011
Drill press.
diggity2424 is offline Find More Posts by diggity2424
Old Sep 10, 2012, 10:21 PM
quadracer's Avatar
Joined Feb 2012
Originally Posted by diggity2424 View Post
Drill press.
Genius. Sheer genius.
I gots me one of them at work, I'll take it in and see what I can do.
Old Sep 11, 2012, 12:16 AM
hertzrepkeith is offline
Find More Posts by hertzrepkeith
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
I could use some help here! I just got my slick. I got a 20x6 prop xoar and it is going to go on a DLE 30cc The prop came Pre drilled. What type of spinner can I get that will fit over this prop??( without cutting on it??) any info would be great!
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Sep 11, 2012, 12:19 AM
Joined Jan 2012
Quad Racer. They make a attachment that goes for the DLE motor. It's 20 bucks at tower hobbies. I would make sure you use a drill press though. I screwed 1 up using a drill!
Old Sep 11, 2012, 07:03 AM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
http://www.3dhobbyshop.com/Omega-3-C...r_p_15693.html
going4speed is offline Find More Posts by going4speed
Old Sep 11, 2012, 07:06 AM
quadracer's Avatar
Joined Feb 2012
I've seen those, but personally I don't see the point in buying a $20 jig when the washer from the prop adapter has the exact same pattern on it. I can slide the prop on the main shaft then mark the 4 holes and drill.
Old Sep 11, 2012, 07:08 AM
keithtsr is offline
Find More Posts by keithtsr
Keith Thomas
keithtsr's Avatar
United States, NM, Portales
Joined Feb 2010
If you want to go cheap....sorry, inexpensive try Esprit Hobbies TY spinners.
http://www.espritmodel.com/ty-nylon-spinners.aspx For grins I bought one and gave it a try and was amazed at how well balanced it was. I now have them on several planes.
There are a bunch of options out there that a pre-cut but the TY spinner carries a lot of bang for the buck.
keithtsr is offline Find More Posts by keithtsr
Old Sep 11, 2012, 09:51 AM
Joined Jan 2012
Thanks guys for the help! I am going to order the carbon spinner!
Old Sep 11, 2012, 06:28 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Looks just like a Great Planes spinner!!
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Sep 11, 2012, 06:34 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
And......I got my second flight on my Slick today (was too darn windy for a lot of flying)....no loss of canopy, and I slid my pack back as it was pretty nose heavy the first flight....Rudder servo in the tail, back about 2" forward of the wing tube, and nose heavy....now back about 1.25" and was just very slightly tail heavy, but I was also at one of those points where one click of up trim it was climbing, one click of down trim it was diving, so, changed my trim step from 4 to 2....should be perfect next time!! Flew for five minutes, only took 53% out of my pack!! Love the motor I have in this plane.....
SteveT
Old Sep 11, 2012, 06:41 PM
keithtsr is offline
Keith Thomas
keithtsr's Avatar
Joined Feb 2010
SteveT
Sure could be. The only thing I can see that may be different is mine takes 4 screws to hold it on. Without seeing the Great Planes in person it looks like there's only has 2 screws.
I originally bought a carbon fiber spinner but could not get it to balance. I put the TY on and it was right on the money. The TY is not a bad spinner but not nearly as good looking as the carbon fiber .....paper weight one.
Old Sep 11, 2012, 06:43 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Yup...Great Planes only two.... but the pic on Esprit looked like only two also.....but you would know....
For myself...Carbon fiber spinners don't really do anything for me, as I like the spinner color to match the plane.....and most full size aircraft don't have black spinners unless of course they have black on the plane, which most of my planes don't other than just black stripes......everybody like different things though.....which is good, other wise things would sure get boring....
SteveT
Old Sep 11, 2012, 07:02 PM
dentalpain is offline
Find More Posts by dentalpain
dentalpain's Avatar
United States, FL, Marianna
Joined Apr 2011
SO my Hacker A50-16L is back at aero model getting to go over. There was some lateral play with the can and it came down boiling hot. Kyle says there is a fix by upgrading it to version 2.1 spec. I was running a 20x10 mezj and liked it. It wasn't the fastest but it was plenty for good 3d.
Now I've got the upgrade itch. Do you guys think a motrofly 4325-280 would be worth the upgrade? I'd like to still use the $80 prop I have but would consider a 20x8 for testing. I figure I can recoup 1/2 the cost by reselling the Hacker. Thoughts?
dentalpain is offline Find More Posts by dentalpain
Old Sep 11, 2012, 07:10 PM
lugnutz is offline
Find More Posts by lugnutz
The Twisted Elf
lugnutz's Avatar
USA, NJ, Trenton
Joined Nov 2010
i just got home from flying my slick with the 4325-280 motor and i love it,20x8 apc prop flying for 6 mins mildly
lugnutz is offline Find More Posts by lugnutz
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
