Old Sep 09, 2012, 07:33 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
How the heck did you tear it up like that and the gear is still good? That is incredible!!!!
going4speed is offline Find More Posts by going4speed
Old Sep 09, 2012, 07:52 PM
dentalpain is offline
Find More Posts by dentalpain
dentalpain's Avatar
United States, FL, Marianna
Joined Apr 2011
I meet the ground unexpectedly the other day too. My 72 was in a blender and on an upright pull out, I ran out of room. Just kinda pancaked into the ground. Wouldn't believe it but the gear made it fine. It must bend/flex almost flat. I did have it wrapped many months ago with the old fishing line repair. I did rip/break a few elevator hinges. Boy were those fun to replace (with the joiner still attached).
dentalpain is offline Find More Posts by dentalpain
Old Sep 09, 2012, 08:40 PM
The Real Monson is offline
Find More Posts by The Real Monson
SMOOOOKKKKKKEEEE
The Real Monson's Avatar
USA, IN, Avon
Joined Aug 2007
Does anyone have a preference on wing bags? My stock ones have worked great but are ripping at the flaps and are beginning to fall apart. Looking for a set that are a little more durable.
The Real Monson is offline Find More Posts by The Real Monson
Old Sep 09, 2012, 08:46 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
I believe Rob at ADC Hobby Store sells some nice ones made by his wife....
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Sep 09, 2012, 09:03 PM
quadracer is offline
Find More Posts by quadracer
No, I won't ship it. Don't ask
quadracer's Avatar
United States, IN, Derby
Joined Feb 2012
Got a new LG plate cut out of 1/4" ply, and after some maneuvers that would make Brock Lesnar look like a chump, it's in. I'll do some more reinforcing and recover the whole area.
Description:
Description:
quadracer is offline Find More Posts by quadracer
Old Sep 09, 2012, 09:04 PM
3DHS 'native'
USA, TX, Spring
Yea I am very glad they left the whole bottom of the plane white....so much easier to fix a landing mistake. Is this ultracoat white?
Old Sep 09, 2012, 09:07 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
SteveT
+1 Robs wife makes good wing bags
losifanatic is offline Find More Posts by losifanatic
Old Sep 09, 2012, 09:12 PM
quadracer's Avatar
Joined Feb 2012
I assume that is correct. I got a 3' x 6" strip of white MonoKote to patch everything with. I've never done any covering before, so I went with the "peel n stick" patching. It might not match perfectly, but I'm not too concerned with that.
Old Sep 09, 2012, 09:14 PM
3DHS 'native'
USA, TX, Spring
I have a patch from my 3dhs yak. It came with pieces of every color...the only arf I've ever seen like that! But I'm guessing at the rate I'm going I will need more.
Old Sep 10, 2012, 02:38 AM
Huang is offline
Find More Posts by Huang
United States, CA, SF
Joined Sep 2001
Guys, question on re-drilling the motor mount for the Motrolfly. I've knocked all the blinds nuts out and going to rotate them and match to the 4325.
Some of the round ply doublers (behind the firewall) for the blind nuts cracked and tore up when I knocked the blind nuts out. Do I need to remake and re-glue the round doublers for the blind nuts, or can I just leave them out and have the blind nuts bite directly into the firewall?
Huang is offline Find More Posts by Huang
Old Sep 10, 2012, 05:36 AM
Sippin the Koolaid!
Joined Oct 2007
I put new peices behind my blind nuts. If you dont the nuts are to deep and come out the other end of the motor mount
Old Sep 10, 2012, 01:07 PM
SteveT.'s Avatar
San Jose, CA
Next time use CA debonder first.....
SteveT
Old Sep 10, 2012, 01:10 PM
ryan_m is online now
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
If the tines of the blind nuts poke all the way through the firewall then you should use some type of wood backing to keep them from going all the way through, otherwise they will hit your standoffs and keep them from sitting all the way flush. On some of mine when the doughnuts don't come off nicely I just cut a square of 3/32" plywood and glue that to the firewall and drill through it. Then the blind nuts can go through the new plywood square and won't poke out the front.
ryan_m is online now Find More Posts by ryan_m
Old Sep 10, 2012, 01:29 PM
Sippin the Koolaid!
Joined Oct 2007
My Castle HV120 let out the magic smoke this morning when it rains it poors.
Old Sep 10, 2012, 01:38 PM
SteveT.'s Avatar
San Jose, CA
That Sucks Matt....sorry to hear this.....any damage to the plane?
SteveT
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
