Old Sep 08, 2012, 04:12 PM
joshet89 is offline
Find More Posts by joshet89
MD1 HACK
joshet89's Avatar
United States, OH, Wadsworth
Joined Jan 2010
I would not go by the tail wheel, my slick has been stored just like that with the wings off of course on the bigger guy.
joshet89 is offline Find More Posts by joshet89
Old Sep 08, 2012, 07:15 PM
quadracer is offline
Find More Posts by quadracer
No, I won't ship it. Don't ask
quadracer's Avatar
United States, IN, Derby
Joined Feb 2012
Originally Posted by Reaper802 View Post
More importantly I need to solve my storage problem. I'm thinking about hanging the fuse by the tail wheel. Or I could use one of those big bike hangers like I did for the 59".
Ether way she is going to have to hide in the stairwell. Could be tricky to get setup...
I hang mine with bike racks as well, but I hook the gear on the rack, hanging nose-up. If you could find a wide enough rack, you could hang it by the wing tube.
quadracer is offline Find More Posts by quadracer
Old Sep 08, 2012, 08:51 PM
dentalpain is offline
Find More Posts by dentalpain
dentalpain's Avatar
United States, FL, Marianna
Joined Apr 2011
Check out the garageworks stuff. You can score most if the pieces for 50% off and the work great up to 30cc.
dentalpain is offline Find More Posts by dentalpain
Old Sep 09, 2012, 02:47 AM
Huang is offline
Find More Posts by Huang
United States, CA, SF
Joined Sep 2001
Motor choice for 6S
Hi Guys,
A question for the experts that run 6S - Whats a good Motrolfly motor for 6S? I read through the thread and bought the 4325-380 when I got the 71" Slick a few months back. I'm just starting to assemble it and see a lot more choices now with the lightened 5320 and the new 4330. Is the 4325-380 and Xoar 19x10 still the recommended setup for 6S?
I'll be using Gens Ace 6S 5300mah packs that I use in the 62" Osiris and Trex 550E. ESC will be Ice 100 w/ Bec Pro and using BLS451 servos on Ail/Ele and DS8717 on Rudder (already mounted under canopy for pull-pull).
I'm looking for similar power to the old 51" Slick with the Hacker A30-12XL, and hopefully motor will not get too hot or pull too many amps on the Ice 100. Should I go ahead with the 4325-380? Or should I go for something that will give a bit more?
Huang is offline Find More Posts by Huang
Old Sep 09, 2012, 03:20 AM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
While I do like Motrolfly motors, another excellent 6S motor for the 71" Slick is the Hacker A60-6XS, which is what I have in mine....Very efficient, easily turns a 20X10 or larger prop, and has tons of power.
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Sep 09, 2012, 07:15 AM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Yo are going to have to pull a lot of amps on 6s to get the same power to weight ratio as yor 51 slick. This is a 10 pound bird not a 3 pound one. Thats one of the reasons l went 8s. Now my 71 slick has close to the same balistic power my motrolfly powered 51 does.
losifanatic is offline Find More Posts by losifanatic
Old Sep 09, 2012, 09:03 AM
rmr24 is offline
Find More Posts by rmr24
rmr24's Avatar
Joined Jul 2006
OS 33 and 71" Slick is an awesome combo!Name: ImageUploadedByTapatalk1347199391.818102.jpg
Description:
rmr24 is offline Find More Posts by rmr24
Old Sep 09, 2012, 11:54 AM
Huang is offline
Joined Sep 2001
Steve looks like you really like your A60-6XS setup. What prop and what watts/current are you seeing? Did you have to move the rudder servo back to balance?
Losi, thanks again for your advice. You helped me select the Motrolfly on my 42" and 59" Slick as well. I'm probably going to stay with 6S for the 71" so I want to find a setup that will provide best power with 6S without pulling too much current. Would you say 4325-380 work best or go with 5320 or 4330?
Old Sep 09, 2012, 11:55 AM
Huang is offline
Joined Sep 2001
The GT33 is a great engine and I would try it but my club does not allow gas engines over 20cc. They do allow glow and I thought of pairing the Slick with a YS-140. But finally decided to go electric. My Slick is the electric version.
btw, anyone ever put a 4-stroke YS engine in a Slick? It would sound awesome.
Originally Posted by rmr24 View Post
OS 33 and 71" Slick is an awesome combo!Attachment 5142563
Old Sep 09, 2012, 12:52 PM
Dennis C is offline
Find More Posts by Dennis C
Dennis C's Avatar
Grass Valley California
Joined Jun 2004
Losi
You have been such a strong supporter of the Gens Ace batteries, are you changing your batterer options?
Dennis
Dennis C is offline Find More Posts by Dennis C
Old Sep 09, 2012, 12:57 PM
SteveT.'s Avatar
San Jose, CA
Yes, I do....As to watts and amps, quite truthfully, I don't remember, as I originally had this power system in a 70" Red Bull Slick. One thing about the A60-6XS is that it is a 28 pole motor and you can't compare the input wattage with a 14 pole motor such as the Motrolfly or other Hacker motors such as the A50-16S (they will be lower, but the motor will have just as much power). If I remember correctly, though I was getting around 1800-1900 watts, but I am only using a 20X10 APC, and as noted, you can go larger. Joe Smith uses a 21X11 (I believe) on his A60-6XS) As to the amperage, again...if I remember correctly . It was around 87 amps. You can most certainly use a Castle ICE100...as that is again, what Joe is using. I am using an HV110, because I already had it.
And, unlike my 70" Slick which balanced perfectly with a pull/pull setup, I did have to move the servo to the tail...
SteveT
Old Sep 09, 2012, 01:02 PM
tominator06 is offline
Find More Posts by tominator06
Team Hillbilly
tominator06's Avatar
United States, MD, Dundalk
Joined Feb 2009
Originally Posted by Dennis C View Post
Losi
Dennis
Originally Posted by losifanatic View Post
Yeah it was one of my 25c gen aces. They are old though so I'm not surprised
386 cycles and its 2 years old
Time to buy new batteries apparently. Hey look at that the gen ace 4k 60cs are on sale. Guess this happened at a good time
Looks like he plans to buy more Gens Ace so I think he just chaulked it up to old packs.
tominator06 is offline Find More Posts by tominator06
Old Sep 09, 2012, 02:02 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
I'd stick with what i had if I were you..You can always change kv and cell count later if you just hate it. You can get around 2000 watts with your setup which is plenty for the airframe. I run the 4325-280 on 8s on mine and just love it. But I had the 380 with 19x10 prop and it was great too. The amps are just higher..
Manta1 is offline Find More Posts by Manta1
Old Sep 09, 2012, 02:48 PM
quadracer's Avatar
Joined Feb 2012
Pancaked the Slick a bit ago. Coming in on final, about 3 or 4 feet up, I hit a dead air pocket or something. It just lost all lift and SPLAT! Ripped the gear out, and broke the two formers behind the wing tube, and broke the prop. The guys watching said it looked like I hit the spoilerons, it just went straight down.
Old Sep 09, 2012, 02:51 PM
SteveT.'s Avatar
San Jose, CA
Sorry to hear that!! And I know exactly what you mean....I was "dragging in" a 3DHS 55" Yak a couple of years ago, about three or four feet up, nice breeze then gone!! My Yak dropped like a rock and tore the gear out!! I bought a new fuselage from Ben, and put it back together again...
SteveT
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
