Old Aug 21, 2012, 06:19 AM
Irg is offline
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
right...
although I thought I read that someone had gotten mike mayberry to say on the record that the 7955 were ok on hv.
Irg is offline Find More Posts by Irg
Old Aug 21, 2012, 06:39 AM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
I thought I read that too
losifanatic is offline Find More Posts by losifanatic
Old Aug 21, 2012, 07:06 AM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Originally Posted by Irg View Post
right...
Yep. That's true. However, if you look at the product specs for the HS-7955TG High Torque Titanium Gear Coreless Servo it shows 6v max. It also isn't listed as one of Hitec's Ultra Premium High Voltage servos. Hitec isn't marketing it as an HV servo but we have all proven it to be reliable as an HV servo and Mayberry acknowledges that as well. That's all I was saying.
cmala is offline Find More Posts by cmala
Old Aug 21, 2012, 07:09 AM
Irg is offline
Irg
Irg
Irg's Avatar
Joined Apr 2009
sorry if my 7am-before-coffee post seemed argumentative. wasn't intended as such .
Old Aug 21, 2012, 07:32 AM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
It's all good
I'm the argumentative one.
Old Aug 21, 2012, 07:44 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Originally Posted by cmala View Post
It's all good
no yur not dernit i am!
Manta1 is offline Find More Posts by Manta1
Old Aug 21, 2012, 08:31 AM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
HV denotes that it can run on a 2S LiPo unregulated which is 7.4 nominal and 8.4v max.
HS7955's aren't actually marketed as HV rated servos but consumers have proven that they are capable of handling 2S LiPo power unregulated.
LiFe is 6.6v nominal and I'm not sure what it maxes out at but it settles back down to around 6.6v pretty quickly and stays there until it's dead. I've been running my HS985MG's on unregulated A123 without issue. Actually, I normally set my BEC's to 6.5 or 6.6volts on most all of my servos except my 7955's which I run at 2S LiPo unregulated.
Does the RX take 2s unregulated ok?
robj is offline Find More Posts by robj
Old Aug 21, 2012, 08:44 AM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
what rx? Spektrum ones are generally rated for 9.0 volts.
ryan_m is offline Find More Posts by ryan_m
Old Aug 21, 2012, 12:26 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
I thought it was on an ATTF episode?
right...
going4speed is offline Find More Posts by going4speed
Old Aug 21, 2012, 07:33 PM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
I'm flying futaba but my 103 has a power expander so the rx gets regulated 5v so I've never looked into it
Old Aug 22, 2012, 11:10 PM
horton is offline
Find More Posts by horton
ExtremeFlightRC.com
horton's Avatar
Joined Jun 2006
Electric 71" Slicks up for pre-order!
horton is offline Find More Posts by horton
Site Sponsor
Old Aug 23, 2012, 03:38 AM
AZAerobat is online now
Find More Posts by AZAerobat
Fly More Crash Less
AZAerobat's Avatar
United States, AZ, Prescott
Joined Sep 2007
Originally Posted by WindGap View Post
Just maidened my 71 slick with an OS GT33. I think it's a groovy engine.
This plane is sick! But that's like announcing that water is good. Everyone knows it. But's it's sick! After my initial maiden, land, check for problems, fly, land, check for problems, I took her up and tried a few 3d moves. Nailed the knife edge spin on first attempt, and on low rates. Wow. So much easier to get it to perform than realflight.
Anyway, didn't go crazy yet. Have to take my time and work out the itty problems that usually arises with a new plane. And need time to dial it in to my preference.
Water is good.
The KE Spin is the one move I am having trouble with on my slick. I can get maybe 2 rotations before it turns into an inverted flat spin. I can nail it almost every time with my other 3DHS planes but not this guy.
That is where I heard it. Not sure which episode. I think it was the last time he was on if that helps any.
AZAerobat is online now Find More Posts by AZAerobat
Old Aug 23, 2012, 08:11 AM
-= GYRO =- is online now
Find More Posts by -= GYRO =-
RC Pilot / Photographer
-= GYRO =-'s Avatar
Joined Nov 2010
Matt, on my 70 the KE spins are not the easiest to enter, but once I'm in I can usually hold it. Are you adding rudder and aileron inputs while it's spinning, to hold it in?
-= GYRO =- is online now Find More Posts by -= GYRO =-
Old Aug 23, 2012, 11:22 AM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
If you start your spin with left aileron and then move the aileron stick to the right as you enter the ke spin, then you are giving too much right aileron if it is flattening out inverted. That is how I exit a ke spin. Add opposite aileron until it flattens out into an inverted flat spin. Ease off your aileron inputs until you find the sweet spot
Old Aug 23, 2012, 01:00 PM
G.P. is offline
Find More Posts by G.P.
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
Slicks need less rudder than most planes to maintain a KE spin. With full rudder, mine fall out. I finally was able to hold mine when I accidentally left my rudder on low rates one day. Ben even mentioned once in the 51" thread that he uses no rudder.
G.P. is offline Find More Posts by G.P.
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
