Old Aug 19, 2012, 02:03 PM
renoglowflyer's Avatar
United States, NV, Reno
Joined Jul 2011
Originally Posted by Dennis C View Post
Do not worry to much about the CG to start. just get it in the ball park.
If you do move things move hardware, you want the tank as close to the CG as possible so that the CG does not change during the flight
Dennis
Thanks Dennis ... Think I am going to move the pull pull servo. Wish I could leave it there but having it in the tail is probably the best. I bet most people would agree to that? Got 3 flights this morning on the extra and the only thing I kept thinking was where is my slick lol. HAving the servo moved back this can help the batteries maybe sit where the pull pull servo is?
renoglowflyer is offline Find More Posts by renoglowflyer
Old Aug 19, 2012, 02:10 PM
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Originally Posted by brathanke View Post
You guys are correct about the nominal voltage but the top of the pack is 7.4
i you are correct as well,but it wont stay that high for long
Manta1 is offline Find More Posts by Manta1
Latest blog entry: Lil repair work.
Old Aug 19, 2012, 02:16 PM
Irg
ol' yellow eyes is back
Irg's Avatar
Brooklyn, NY
Joined Apr 2009
yeah, like less than a minute or two.
Irg is offline Find More Posts by Irg
Latest blog entry: laser repair
Old Aug 19, 2012, 06:29 PM
Don't Eat the Chili Beans !
goflyhighrc's Avatar
Modesto, CA
Joined Nov 2006
What to do !
Using a specktrum recevier, what is the best way to get backup battery redundancy for the 71" Slick. I have a Fail Safe AR 9100 in my 89 just don't want to put a $200 receiver in this size plane. Also plan on using Tech Aero Ultra IBEC with ignition cutoff.
goflyhighrc is offline Find More Posts by goflyhighrc
Old Aug 19, 2012, 07:18 PM
3d NOOBular
brathanke's Avatar
USA, UT, St George
Joined Aug 2010
Fair enough but if the servos aren't rated for high voltage is it not enough of a difference to matter? I don't know everything about this so please enlighten me.
brathanke is offline Find More Posts by brathanke
Latest blog entry: Southern Utah Huckin!
Old Aug 19, 2012, 09:21 PM
Joined Jul 2011
Ok felt sad to cut the pull pull set up... So 3DHS set up and life lol... But I have the servo in the tail and it feels more comfurtable for the cg... More places for the batteries
Old Aug 19, 2012, 09:55 PM
Let me be...Frank with you :-p
going4speed's Avatar
USA, TX, Spring
I just stuck 2 ounces of lead to the back of the servos today to get the gasser to balance and it has two tail servos....that os gt33 is a hog!
going4speed is offline Find More Posts by going4speed
Latest blog entry: smacked the beeeeg slick
Old Aug 19, 2012, 10:57 PM
Joined Jul 2011
I am fealing the hog... I got a post to mr smith to find out how they mthotically figured out the GT33 .. They have been busy with the K50 but hopefully we might get a post with a pic how this should run.. If not we find fun places for the batteries
Old Aug 20, 2012, 04:43 AM
Hewey19's Avatar
USA, MI, Lansing
Joined Aug 2009
I'd love to see the Smith's set up also.
Hewey19 is offline Find More Posts by Hewey19
Old Aug 20, 2012, 07:34 AM
steve400's Avatar
USA, NY, Patchogue
Joined Aug 2009
We use two 1100 a123's with a smart-fly batt share and 2 JR switches. use about 80mah/flight The batt share will draw the two packs equally
steve400 is offline Find More Posts by steve400
Old Aug 20, 2012, 06:28 PM
Irg
Irg's Avatar
Brooklyn, NY
Joined Apr 2009
many servos that are good for 6v will be ok on life, but check to make sure.
hv usually denotes at least capable of 7.4v, nominal 2s voltage. but many hv servos can be runner higher, like my 7955s at 8v.
Old Aug 20, 2012, 06:55 PM
WindGap's Avatar
Joined Sep 2010
I didn't have to add any lead. I simply put two 2000mah life packs under the turtle deck (like many other gassers on this thread), and it balanced out slightly tail heavy at stock cg. Two servos in tail, rudder & elevator. Moved ignition and everything as far back as possible. No spinner, no lead.
WindGap is offline Find More Posts by WindGap
Old Aug 20, 2012, 08:02 PM
Bad Mother Hucker
quadracer's Avatar
United States, IN, Derby
Joined Feb 2012
ghetto subscribe
quadracer is offline Find More Posts by quadracer
Old Aug 20, 2012, 08:56 PM
3d NOOBular
brathanke's Avatar
USA, UT, St George
Joined Aug 2010
Thanks for the clarification
Old Aug 21, 2012, 06:00 AM
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
HV denotes that it can run on a 2S LiPo unregulated which is 7.4 nominal and 8.4v max.
HS7955's aren't actually marketed as HV rated servos but consumers have proven that they are capable of handling 2S LiPo power unregulated.
LiFe is 6.6v nominal and I'm not sure what it maxes out at but it settles back down to around 6.6v pretty quickly and stays there until it's dead. I've been running my HS985MG's on unregulated A123 without issue. Actually, I normally set my BEC's to 6.5 or 6.6volts on most all of my servos except my 7955's which I run at 2S LiPo unregulated.
cmala is online now Find More Posts by cmala
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
