Old Jul 30, 2012, 03:35 PM
-= GYRO =- is online now
Find More Posts by -= GYRO =-
RC Pilot / Photographer
-= GYRO =-'s Avatar
Joined Nov 2010
Originally Posted by losifanatic View Post
Gary is a stand up guy to buy from too. His packaging is very well done. I have been flying the 89 a lot lately too. It's amazing hoe well that thing does slow roller down the runway. Oh it also handles crashing in a corn field well too
Thanks Matt!
Originally Posted by SteveT. View Post
I think you're going to regret selling the 70" Slick, as you won't always feel like hauling the gasser out....but it's your plane....
SteveT
Yes, BUT, I still have a 74" Edge, 60" Edge, getting a 60" MXS, 51" Slick, 48" Laser, and a 42" Slick.
Do I really NEED 4 Slicks?
-G
-= GYRO =- is online now Find More Posts by -= GYRO =-
Old Jul 30, 2012, 03:43 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Originally Posted by -= GYRO =- View Post
Thanks Matt!
-G
I have 3 . need to sell one tho.
Manta1 is offline Find More Posts by Manta1
Old Jul 30, 2012, 03:44 PM
-= GYRO =-'s Avatar
Joined Nov 2010
3 is my target number, and where I'll be when I sell the 70". Speaking of which, the classified ad is up: http://www.rcgroups.com/forums/showt...0#post22308628
Old Jul 30, 2012, 03:46 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Well, I had 4,lol so i gave one to Powerlines. It still hangs in my trailer from time to time.
Old Jul 30, 2012, 04:58 PM
bigroger is offline
Find More Posts by bigroger
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
Guys, I run hs7985mg in my slick and noticed yesterday several of the servo arm screws had worked loose after 10 flights.
Is this normal on these servos?
I put some blue loc tight in there now, but not sure how long it will hold.
bigroger is offline Find More Posts by bigroger
Old Jul 30, 2012, 05:05 PM
joshet89 is offline
Find More Posts by joshet89
MD1 HACK
joshet89's Avatar
United States, OH, Wadsworth
Joined Jan 2010
Loctite isn't the best for the nylon arms (I have done it in the past with no ill effects) I have started putting a dab of welders on top of the screw to keep it in place. Metal to metal should be secured for sure!
joshet89 is offline Find More Posts by joshet89
Old Jul 30, 2012, 05:23 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
I use a dab of zap goo between the arm and the screw. Never will they back out.
going4speed is offline Find More Posts by going4speed
Old Jul 30, 2012, 05:38 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Blue locktite for me. 700ish flights with no issues.
losifanatic is offline Find More Posts by losifanatic
Old Jul 30, 2012, 06:08 PM
renoglowflyer is offline
Find More Posts by renoglowflyer
renoglowflyer's Avatar
United States, NV, Reno
Joined Jul 2011
Slick is sitting at my house now, waiting to get off work and check it out, hopefully Brown didn't step on the box with 2 big boot prints like my 72" Extra. I was freaking out but the boxes are pretty strong.
renoglowflyer is offline Find More Posts by renoglowflyer
Old Jul 30, 2012, 06:32 PM
ldhflyguy is offline
Find More Posts by ldhflyguy
FlyGuy
ldhflyguy's Avatar
Batavia, IL, USA
Joined Oct 2007
Loctite and Karbonite gears
Hey guys,
F.W.I.W. a few years back I learned that Loctite used on the servo arm screws of the the Hitec Karbonite gear servos is not a good idea. The Loctite melts the Karbonite. I had the output shaft on two different Karbonite gear servos in the same plane practically fall out of the servos, although the servo arm stayed put on the shaft. Checking the Hitec website will probably confirm that Loctite should not be used with Karbonite gears.
I did a little research:
Q. Can I use loctite with my Karbonite gears?
A. It has come to the attention of the Hitec Product Service Department that some customers owning Hitec's KARBONITE gear servos are using thread locking compounds on the servo horn screws. Thread locking compounds such as the popular LocktiteTM brand, are for use with METAL to METAL fasteners.
USING A THREAD LOCKING COMPOUND ON KARBONITE GEAR SERVOS WILL CAUSE THE PLASTIC TO FAIL.
Thread locking compound instructions typically warn against their use on plastics, as most plastic material will become brittle and shatter. If you or any of your friends have used thread locking compounds on plastic / KARBONITE geared servos, please cease using them immediately and contact a Hitec dealer for a replacement gear set.
ldhflyguy is offline Find More Posts by ldhflyguy
Old Jul 30, 2012, 06:42 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
Originally Posted by ldhflyguy View Post
Hey guys,
They were talking about metal gear servos.
zmonster97 is offline Find More Posts by zmonster97
Old Jul 30, 2012, 06:48 PM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
Thanks guys.
Blue is in there now.
I'll monitor it for a few flights to see how it goes.
One of my aileron servo arm screws had actually backed out a long way and was only holding on by a few threads.
I broke a pull-pull cable yesterday doing the rudder dance on the runway, that's what go me to having a look at the servos.
Just lucky I did otherwise I might have lost the plane if a servo disconnected.
Old Jul 30, 2012, 06:56 PM
joshet89 is offline
MD1 HACK
joshet89's Avatar
Joined Jan 2010
Eh, you can fly the 71 with one aileron, even if the aileron is locked in a down position, don't ask me how I know
Old Jul 30, 2012, 07:52 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by flyracer View Post
My 71" slick goes in the truck EVERYTIME I go out.... period!
Flyracer
Yup... my 70" went out every time until Gary bought it from me....and I imagine my 71" that I just about have finished will too....
Just out of curiosity....what is the round cowling plane in your picture?
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jul 30, 2012, 08:05 PM
skarface is offline
Find More Posts by skarface
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
Yep, samething with a 42", right aileron was halfway deflected, did not relize it until I could not fight the tourqe in a hover.
skarface is offline Find More Posts by skarface
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
