Old Feb 08, 2012, 11:25 AM
harddrive8 is offline
Find More Posts by harddrive8
Nothin Ventured, Nothin Gained
harddrive8's Avatar
United States, NC, Maiden
Joined Jul 2011
Just placed an order for more Power Poles and a few of the "locks" that secure them. Does anyone have experience with the regular retention clips as well as the BLOK-LOKs? I've ordered a couple of each to try out and see how they hold.
harddrive8 is offline Find More Posts by harddrive8
Old Feb 08, 2012, 11:28 AM
RCPilot1234 is offline
Find More Posts by RCPilot1234
Joined Jan 2012
Everything ordered! I had to pay at least 100 more than I should as I had to order everything from different places, lol let's hope the deliveries arrive on time as promised!
RCPilot1234 is offline Find More Posts by RCPilot1234
Old Feb 08, 2012, 02:00 PM
XtremeWingRC is offline
Find More Posts by XtremeWingRC
Scobee Field & HTOWN FPV
XtremeWingRC's Avatar
United States, TX, Houston
Joined Oct 2007
If I'm flying 8S on my 70" slick and I wanna buy batteries from hobbypartz....
Should I buy two 4s 3300"s or can I go bigger? I don't want to go to heavy but I don't want a cheesy short flight time. Will two 4s 5000's be too much weight?
Any suggestions will be appreciated.
Casey
XtremeWingRC is offline Find More Posts by XtremeWingRC
Old Feb 08, 2012, 02:18 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
I use mostly 4s 4000 but use 4s 5300s too. 6 out of the 4Ks for me
losifanatic is offline Find More Posts by losifanatic
Old Feb 08, 2012, 02:20 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
Casey
most of us on 8S are flying 4000mah packs, but 4500's would also be fine if you need a little more. 5000's will be flyable, but you'll start noticing the weight in performance for sure.
edit: Losi slides in with the same
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Feb 08, 2012, 02:30 PM
Joined Oct 2007
Ok thanks guys. I'll look at the gens ace or sky lipos. I've never had a problem with them. Should do the trick.
Old Feb 08, 2012, 02:31 PM
Sippin the Koolaid!
Joined Oct 2007
The gen aces are rock solid and perform very well
Old Feb 08, 2012, 02:34 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
I have "heard" Sky Lipos don't get many cycles...no personal experience though...
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Feb 08, 2012, 02:38 PM
Joined Oct 2007
Yeah always rock solid for me. Sky works good too, but blue lipos got puffy a little bit. I quit buying them.
Old Feb 08, 2012, 03:10 PM
lammbn is offline
Find More Posts by lammbn
Hooked on 3DHS
lammbn's Avatar
United States, ID, Boise
Joined Nov 2009
The block-loks rock! They are not hard at all to get on and odd and really ease my mind that its not coming apart. The regular retention clips with just the two posts are ok. Problem ive had is they ate either really loose fitting or really tight and need pliers to grip them because the tabs are kinda small. I have a bunch but have never liked them or trusted them to hold in flight. Plus the block-loks are just way too easy to use. Trick is to hook one end first and just apply pressure until the other side pops in. Takes a bit but not much. Hope that helps!
lammbn is offline Find More Posts by lammbn
Old Feb 08, 2012, 03:19 PM
harddrive8's Avatar
Joined Jul 2011
Casey
I run 8s (2x 4s 5000mah Sky Lipos). I'm getting around 7 min. flight time and burning around 65-70% of the pack in that time. I run the batteries about an inch off the wing tube, and it balances just ever so slightly nose heavy from the wing tube.
+1 -- My first order of Gens Ace (3s and 4s) should arrive tomorrow. I'm replacing some of my blue lipos that I'd been using. I have Sky Lipos for my larger applications at the moment and they are a ton better than the blue lipos. Having the PL8 now, and batteries that won't puff quickly is going to make charging and flying more enjoyable.
Old Feb 08, 2012, 03:20 PM
DenverJayhawk is online now
Find More Posts by DenverJayhawk
United States, CO, Denver
Joined May 2010
i'm using PP on the connection from the motor to ESC. Do they make a blok lok for 3 connections pairs?
DenverJayhawk is online now Find More Posts by DenverJayhawk
Old Feb 08, 2012, 03:37 PM
lammbn is offline
Hooked on 3DHS
lammbn's Avatar
Joined Nov 2009
They make one for four pairs. You could just use an extra set of housings and put the four pairs together. Or even better. You can put all three housings in a row, using the retaining pin between one set so they cant come apart and then use a single set block-lok on the other set. Should work just fine.
Old Feb 08, 2012, 03:58 PM
Joined May 2010
thanks, Brady. What if i just used a large diameter shrink wrap over the connections. I'd assume that would work too?
Old Feb 08, 2012, 06:17 PM
lammbn is offline
Hooked on 3DHS
lammbn's Avatar
Joined Nov 2009
That would work. It would kinda take away the large advantage of being able to disconnect quickly without cutting heatshrink.
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
