Old Jan 22, 2012, 06:15 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by RCPilot1234 View Post
Great to here that! I've never had any complaints, but some dog walkers say their dogs don't like the planes, haha!
And if you were throwing a Frisbee, the same people would probably gripe, because their dogs wanted to catch the Frisbee!! Some people will complain about any thing...
Case in point....About 40 miles away from me, there is a huge "wind warm' with lot's of wind turbines. People complain about the "swishing" noise from the blades. These same people complain about nuclear powered power houses, coal powered power houses, and natural gas powered power houses. And...they also don't like the looks of "solar farms" and complain about those too...
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jan 22, 2012, 06:46 PM
RCPilot1234 is offline
Find More Posts by RCPilot1234
Joined Jan 2012
SteveT
Haha, that's great! The AJ Slick is coming to about 1000 in total. Im gonna order when they get instock!
RCPilot1234 is offline Find More Posts by RCPilot1234
Old Jan 22, 2012, 07:04 PM
marksextra is offline
Find More Posts by marksextra
Once u go yak u never go back
marksextra's Avatar
Erie, PA
Joined Mar 2005
SteveT
Ya and then they all go home flip on the lights, turn up the heat/air, open the cold fridge and set down in front of the TV. No problems using the juice since they don't even know where it comes from.
marksextra is offline Find More Posts by marksextra
Old Jan 22, 2012, 07:05 PM
Gopedasia is offline
Find More Posts by Gopedasia
Manila, Philippines and Burlingame, CA
Joined Jul 2007
Stevetoo - thanks for the quick reply. Whats your auw? You keeping it under 100 amps?
Losifanatic - what packs you using? What amp draw are you getting?
Gopedasia is offline Find More Posts by Gopedasia
Old Jan 22, 2012, 07:08 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
running the gen ace 4Kmah 25Cs mostly. Run the 4s 5300mah 30C too on occasions too. 90ish amps at WOT
losifanatic is offline Find More Posts by losifanatic
Old Jan 22, 2012, 07:13 PM
tominator06 is offline
Find More Posts by tominator06
Team Hillbilly
tominator06's Avatar
United States, MD, Dundalk
Joined Feb 2009
Goped - Even my 10s setup with an extra battery for the Rx and servos is right @ 10lbs
tominator06 is offline Find More Posts by tominator06
Old Jan 22, 2012, 07:23 PM
Joined Jul 2007
Nice!!!! How many watts? Pack size? Im seriously contemplating on getting a 71 slick. I already have 6pcs 6s 5000mah 25c packs for my 25% and 30%. But if im going hv might as well do 8 or 10s. How many amps you pulling? Would you be able to get away with 10s 3000mah?
Old Jan 22, 2012, 07:31 PM
Sippin the Koolaid!
Joined Oct 2007
If you have the 6s packs already the plane still performs very well with the hacker A60-6xs and the motorfly 4325 380kv for a lite setup.
Old Jan 22, 2012, 07:41 PM
Team Hillbilly
Joined Feb 2009
Actually I'm pulling quit a bit less than Losi's. His 8s setup is a different Kv version of the same motor I'm running. The biggest prop I've ran so far was a 22x10 Xoar. I only got a two flights with it as the second flight was when my batteries ejected through the canopy. I did get the first flight with that setup on video. The 22x10 was around 2700watts @69Amps with fresh packs. I'm flying at that field I was talking about. Nothing special it was just a test flight but you can hear what sort of sound she makes.
Watch in 720p
3dhobbyshop 71" AJ Slick - Motrolfly 5320-200kv on 10s with a 22x10 Xoar prop (4 min 27 sec)
Old Jan 22, 2012, 07:51 PM
Team Hillbilly
Joined Feb 2009
I'm running 3300mah packs in mine. On the 20x10 I could easily get 7 minutes if I wanted to push it. I run a 6 minute timer and have plenty left. I like to be safe.
Old Jan 22, 2012, 08:16 PM
SteveT.'s Avatar
San Jose, CA
Never weighed it, but I'm pretty sure it's under ten pounds, and if I remember correctly, 83 amps. I tried to use a Castle HV-85, but it was limiting the power. I went to an HV-110 and no problems. A lot of guys are using the Ice 100, and getting good results.
SteveT
Old Jan 23, 2012, 11:25 AM
twistedgrim is offline
Find More Posts by twistedgrim
twistedgrim's Avatar
San Antonio, TX
Joined Sep 2008
I still say my tried and true A50-12L / 8s 3700 25C / ICE100 71 is one of the best. Super light, Great power and plenty of flight time with 5 mins. Still the recommended setup, you can do 6s or 8s just fine with a swap of a prop. Although if you were dead set on 8s the A50-14L would be better as you can run a 19" prop instead of 18".
With the 71 though it has so much wing you can load it up pretty heavy and still fly well. Who said Losi's 2700/3000 watts of power wasn't enough right?
twistedgrim is offline Find More Posts by twistedgrim
Old Jan 23, 2012, 12:37 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
Anyone in the market for a Motrolfly 4325-380 BNIB?
going4speed is offline Find More Posts by going4speed
Old Jan 23, 2012, 01:27 PM
lammbn is offline
Find More Posts by lammbn
Hooked on 3DHS
lammbn's Avatar
United States, ID, Boise
Joined Nov 2009
As a matter of fact i am. I see a new 74 in my future with tax returns. Whatcha thinkin for it? Probably shouldn't afford it right now but might not be able to pass up a good deal.
lammbn is offline Find More Posts by lammbn
Old Jan 23, 2012, 01:33 PM
Sippin the Koolaid!
Joined Oct 2007
yeah its something about that 300 watts per pound and over 2 to 1 thrust to weight ratio (22 pounds of thrust on a 10 pound plane )
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
