Old Sep 11, 2009, 07:59 PM
BoneDoc is offline
Find More Posts by BoneDoc
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Yep, clear packing tape is what I'd use.
BoneDoc is offline Find More Posts by BoneDoc
Old Sep 11, 2009, 08:07 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
ive never put that piece on my planes anyhow
Manta1 is offline Find More Posts by Manta1
brucewsb is offline
Find More Posts by brucewsb
brucewsb's Avatar
Santa Barbara
Joined Apr 2008
So after looking at the cowling, I'm thinking about building some mounting hardware to clamp the cowl to the firewall instead of using screws from the outside. Looks doable if I just reinforce the wooden edge. Might be tricky access but I'll see if some creative spark happens.
Anybody else planning something like that? Just seems too nice looking to blemish with screws.
brucewsb is offline Find More Posts by brucewsb
Old Sep 11, 2009, 08:12 PM
refugeefromcalif is offline
Find More Posts by refugeefromcalif
May the Farce be with you...
refugeefromcalif's Avatar
Duncanville, Alabama. USA
Joined Dec 2006
I don't either.
I also don't use wheel pants because of the places I fly at.
I like, Full access to the gear bolts for an easy replacement.
George
refugeefromcalif is offline Find More Posts by refugeefromcalif
M Carr is offline
Find More Posts by M Carr
M Carr's Avatar
Eastern, NC
Joined Dec 2007
Woooooo Hoooooo, almost finished with mine...
All I have left to do is Install receiver, hook up servos, setup radio and check CG. I could actually fly it tomarrow but it will probably be Sunday as originally planned.
So far I'm at 7lbs 8ozs minus receiver and main battery. not too bad for a 70" airframe.
M Carr is offline Find More Posts by M Carr
Old Sep 11, 2009, 08:15 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
i will put the wheel pants on this one.i put them on my vyper and so far so good,but it lands easy as a sig kadet senior so ive always landed it on the mat.as far as the 70 goes..i imagine it will run on the grass a bit
Old Sep 11, 2009, 09:19 PM
rthorne is offline
Find More Posts by rthorne
Quit Chucking My Wood
rthorne's Avatar
USA, TX, Amarillo
Joined Dec 2003
Good job Mick.
Rich
rthorne is offline Find More Posts by rthorne
Old Sep 11, 2009, 10:59 PM
G.P. is offline
Find More Posts by G.P.
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
Soory, wrong thread!
G.P. is offline Find More Posts by G.P.
Old Sep 11, 2009, 11:08 PM
chimchim is offline
Find More Posts by chimchim
USA, IL, DeKalb
Joined Dec 2003
Is it built yet Manta?
chimchim is offline Find More Posts by chimchim
Old Sep 11, 2009, 11:11 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
its in the airplane shop at my buds house.(local flying field) i havent even gon and got it yet.needed to rest this evening.if i had went and gotton it id still be working on it.lol ive held this couch down and blown my nose all evening lol..sorry
Old Sep 12, 2009, 04:54 AM
jadamian75 is offline
Find More Posts by jadamian75
jadamian75's Avatar
Fort Collins Colorado USA
Joined Oct 2007
Up to build video 4. Its looking good. Today I may go out and get bigger wheels. Maybe kavans. I'd like to keep them lite/durable and need something I can find within a 1/2 hour drive. The bigger wheels are because the back of the wheel pant are almost touching the ground. I already drilled the 2 wood screws per wheel pant so I think the easiest way to get the wheel pants higher is larger wheels. There is plenty of room inside the wheel pants to go bigger.
Joe
jadamian75 is offline Find More Posts by jadamian75
Old Sep 12, 2009, 07:46 AM
callen is offline
Find More Posts by callen
WAR EAGLE
callen's Avatar
Parrish Fl
Joined Apr 2004
Originally Posted by Daloaf
I usually remove the monocote, sand down the edges so it sits flush and then CA the covering back down on the sides. I use some clear packing tape to tape the block into place. That way if I break the gear, I can easily remove the block to get to the gear bolts.
Matt
This is the way to go. Cause you know sooner or later that carbon gear is going to crack.
callen is offline Find More Posts by callen
Old Sep 12, 2009, 07:48 AM
callen is offline
WAR EAGLE
callen's Avatar
Parrish Fl
Joined Apr 2004
I'm surprised it wasn't designed that way since it fits flush. I've been also toying with your same idea. Its the bottom that will be the hard part.
Old Sep 12, 2009, 09:30 AM
Tipover is offline
Find More Posts by Tipover
WI
Joined Mar 2001
I would think Velcro would be a good way to hold the landing gear filler bock in place. Of course the filler block would need to be designed to accommodate the thickness of the Velcro.
Kevin
Tipover is offline Find More Posts by Tipover
Old Sep 12, 2009, 09:32 AM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
just counter since some of those strong earth magnets and stick it to it
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
