Old Nov 15, 2011, 03:48 PM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
I'll have a red one tomorrow, hmmm, $800, never flown? hehe
I'll probably put my 72 Extra up for sale depending on the Edge. Haven't really decided yet. Last one to fly it was Aaron(thekm). The weather hasn't been the best and I only like flying it with a good runway.
robj is offline Find More Posts by robj
Old Nov 15, 2011, 03:59 PM
rowdyjoe is offline
Find More Posts by rowdyjoe
rowdyjoe's Avatar
Arlington, TX
Joined Jul 2009
Originally Posted by G.P. View Post
I thought that running an Rx pack and a bec was a bad idea because the bec would try to charge the pack if it went bad...possibly letting the smoke out of the bec. Is there something available to isolate the Rx pack if it goes bad?
Been flying electrics for about 3 yrs and never heard of such a thing as a BEC trying to chage a battery. Why would a BEC try to "charge" a battery?
A BEC is basically a step-down transformer used to bring voltage down to 5 or 6 volts from whatever battery you connect it to. (some are limited as to a max voltage). Some are programmable via jumper for 5 or 6 volts. It's not a device used to charge anything.
I'm currently using two 2 cell LIPO receiver packs, each with it's own BEC, to run the receiver and ignition on my gas engined bird. Never a problem. The LIPOs seem to last forever. I can fly all day and not worry about low batteries. I charge them at home so they're ready for the next trip to the field and, after a full day's flying, they generally read about 7.6 volts (full charge is 8.4 volts).
Good switching BECs can be had for very little money. ....OR you can buy a Smart Fly module for about $60 that will do the same thing with two LIPO batteries.
http://smart-fly.com/Products/Regulator/3.htm
RJ
rowdyjoe is offline Find More Posts by rowdyjoe
Old Nov 15, 2011, 05:58 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
RJ
Right you use a RX pack(2s lipo or that other battery type ) is to power the BEC.
Its not to be hooked up in parellel with the RX pack as it would then try to charge the battery and that could cause the BEC to burn out unless you hook up a diod to it to prevent power from going that direction. Thats about the only way to do that but man that just OVERKILL
losifanatic is offline Find More Posts by losifanatic
Old Nov 15, 2011, 06:52 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
If you plug a battery and a BEC into a receiver, since they will both be plugged into a parallel power buss, (as are the servos) the BEC "will" try to charge the battery or burn up the BEC unless as Matt said, you put a diode on both the BEC and the battery to keep the current from flowing to the battery or BEC.
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Nov 15, 2011, 08:39 PM
tominator06 is offline
Find More Posts by tominator06
Team Hillbilly
tominator06's Avatar
United States, MD, Dundalk
Joined Feb 2009
Got a couple Xoar 20x10's today to replace the Apc I have been running. Nothing wrong with the Apc but I wanted to try the Xoar as I like the performance on the 48 edge vs the Apc. The Apc 20x10 thin E prop weights 85.3 grams and The Xoar 20x10 E prop was 61.8. I knew the Xoar was lighter but didn't realize it was 28%. Hopefully I'll get a slight amount of punch increase out of it. I also installed a white EF spinner which was about 5 grams lighter that the blue Dubro I had on here. It's not much total weight loss but every little bit helps.
tominator06 is offline Find More Posts by tominator06
Old Nov 15, 2011, 10:52 PM
rowdyjoe is offline
rowdyjoe's Avatar
Arlington, TX
Joined Jul 2009
SteveT
You guys sure know how to make a mountain out of a mole hill.
Old Nov 16, 2011, 01:22 AM
G.P. is online now
Find More Posts by G.P.
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
...says the guy with the ridiculously long post and bold lettering to inform me what a bec is...
G.P. is online now Find More Posts by G.P.
Old Nov 16, 2011, 05:08 AM
cayars is offline
Find More Posts by cayars
cayars's Avatar
Bridgeton, NJ
Joined Mar 2009
Only a "mole hill" if you want to burn your stuff up. You simply can't run both a BEC and battery without additional protection long term. Simple as that.
Information sharing like this is important so please don't down play it when people try to educate others, especially if you don't understand it thoroughly.
Really not tying to criticize you or anything but you should read up on it,
Carlo
cayars is offline Find More Posts by cayars
Old Nov 16, 2011, 05:09 AM
cayars is offline
cayars's Avatar
Bridgeton, NJ
Joined Mar 2009
"ridiculously long post" Nah, that was a "shorty".
Old Nov 16, 2011, 06:34 AM
Sippin the Koolaid!
Joined Oct 2007
Didnt you get the badge for longest post
Old Nov 16, 2011, 07:50 AM
G.P. is online now
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
Yeah, it's all relative!
Would "overly complicated" be better?
Old Nov 16, 2011, 08:17 AM
94'325is is offline
Find More Posts by 94'325is
94'325is's Avatar
Florida
Joined Jan 2010
I have an 8S setup and run an 1800 mAH 6.6V LIFe Rx pack on my Slick. It's great because my servos see 6 Volts of power and I have had a situation where the main packs departed and I was able to glide the plane down safely. Also the extra pack is nice because it's one more way to get the CG dialed in where you want it.
94'325is is offline Find More Posts by 94'325is
Old Nov 16, 2011, 08:19 AM
94'325is is offline
94'325is's Avatar
Florida
Joined Jan 2010
Also for an 8.5 min flight I take out about 90 mAH from the Rx flight, considering I only have 8 4S batteries I never run into an issue w/ love Voltage on the Rx pack. Plus since it's a LiFe battery I can store it full charged and charge it in the plane w/ worrying about taking it out of the plane.
Old Nov 16, 2011, 08:22 AM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
i dont know if you will get a punch increase, infact i think you will get a tad less punch going from an apc 20x10 to a xoar 20x10. the xoar will be smoother, and may have just a touch more top end, but the apc's do tend to bite a little better
rcbirk21 is offline Find More Posts by rcbirk21
Old Nov 16, 2011, 08:28 AM
cayars is offline
cayars's Avatar
Bridgeton, NJ
Joined Mar 2009
Yea, that's why I said his was a "shorty"
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
